Question about Fisher and Paykel 23 in. DD-603 Built-in Dishwasher
My dishwasher top drawer of dishwasher just keeps running and doesnt dispence water and doesnt finish cycle cn you help
  • Fisher and P... Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
Posted on Mar 20, 2011
Top drawer stops, will restart if I push start
Sounds like a micro switch problem to me, telling the dishwasher that the drawer is open when it is not actually open.
Dec 26, 2013 | Fisher and Paykel 23 in. DD-603 Built-in...
Fisher paykel dishdrawer
The controller is detecting some abnormal condition. Clean the interior of the dishwasher with warm water and clean cloth. Remove the base drain plate etc., before cleaning and clean the plate separately. Put back and try again. If no difference, then buy Finish dishwasher cleaning kit and run the dishwasher on one of the hot cycles. (You will have to keep pushing the pause button ). See if it clears everything. If not then call the technician as the controller may need replacement.
Nov 30, 2013 | Fisher and Paykel 24 in. DD603H W Built-in...
I have a Fisher Paykel DD24 dishwasher and when using top drawer after wash cycle is complete there is always water in drawer. Top drawer is unable to drain water after wash cycle is complete...what can I...
If the cycle is complete and dishes are clean, then you need to worry. Try to pull the drain hose up a bit under the sink. Also buy a Finish dishwasher cleaning kit and run dishwasher as per instructions on the kit. That should clean any obsrtuctions in the drain side.
Nov 20, 2013 | Fisher and Paykel DD24DCX6 Dishwasher
My top dishwasher drawer won't finish through the cycle. It runs fine on rinse only but not any of the wash cycles. It stops mid cycles, beeps like it has been paused, then tries to start again
Try to feel the temperature of water inside the dishwasher. If it is normal room temperature for the hot wash cycles then it is likely the heater is faulty.
It is not easy to replace unless you have good experience with repairing dishwashers.
Jan 17, 2013 | Fisher and Paykel 23 in. DD-603 Built-in...
Appliance: Fisher&Paykel DD603 Draining
You may want to check up if the water collects in the bottom drawer when the top drawer is in wash cycle (ie, taking water from the inlet) or during the drain cycle when it is draining water out. Leave the bottom drawer open and check while the top drawer is running.
Jul 27, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwasher keeps flashing F1
F1 on your dishwasher is the fault code for leaking inside the machine. the water has caused the flood switch to activate. have you put any detergent rather than your normal dishwasher detergent into the machine? if you have, the water probably leaked out of your overflow, if not, then you have a leak on the top drawer or bottom drawer. the easiest way to check is to leave the machine off for a couple of days until it drys then turn on the bottom drawer to go thru a cycle.if the F1 comes up again then the problem is on your bottom drawer. if F1 does not come up then try the top drawer. please reply if you require further help.
May 28, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwasher not getting enough water in either drawer, although top drawer gets more. Dishwasher keeps beeping during cycle and reads not enough water and then stops running until you press the start...
This sounds like a hard water deposit problem.
Check your water inlet valve for a screen and see if its clogged. Also it may just be a water valve/solenoid problem. As in, it's too crusted up to float up and down.
Some models have a water fill timer, while others use a water fill/pressure switch. This may also bear inspection.
The beep you hear during your cycle is indicating that your water level is too low to cover the heating element, which can cause cracking and lead to a short.
Mar 07, 2010 | Fisher and Paykel DD605FD Stainless Steel...
Top drawer is ok. Bottom drawer makes lots of noise, but finishes the cycle ok
Can you describe the noise:
Water noise,
Mechanical sound noise.
Motor noise
Rattle noise
Jun 26, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Water in top drawer
I am not a repairman but have installed several duel drawer dishwashers. Most dishwashers have a check valve preventing backflow. Water under pressure will always follow the path of least resistance and in your case it is going into the upper drawer. Be sure the drain is open and flowing easily under your sink whether that be the disposal or a TEE. It may help if the drain line is elevated as high as it can go under the sink just before it reaches the drain. How often do you use the top drawer? Perhaps run a cycle on the hottest cycle without dishes to attemt to clean or force through any contaminants in the check valve through into the drain. Hope this helps, Ken
May 01, 2009 | KitchenAid 23 in. KUDD01DPPA Stainless...
Dishwasher not working
disconnet power to unit....circuit breaker...wait 30 minutes....try again
Jun 02, 2007 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 23 in. DD-603 Built-in Dishwasher Logo
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
