Question about Extech Br200 Wireless Inspection Camera W/ 17mm Head
None of the side buttons work on the monitor - Extech Br200 Wireless Inspection Camera W/ 17mm Head
When i power it up there's just a white screen that has v.200 moving across it and none of the buttons work. also i don't have a remote control so can't try some of the solutions i read which involve...
Check the video interface cable. If there is no video signal input, none of the control at the monitor work. Check the connection for firmness. If found OK, the main board [signal input side section circuit] has the fault. Contact any service technician.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 24, 2014 | Computers & Internet
I am unable to turn the screen off and the Menu button, actually, none of the buttons on the screen works. It constantly shows the Volume in the centre of the screen and I cannot remove it. Please help! ...
If none of the button are working then it could mean that one of the buttons is stuck or there is an issue with the board on the monitor itself.
Unplug the monitor from power and the computer. Make sure none of the buttons are stuck down, plug only power back in to the monitor and see what it shows. Plug it back into the computer and check to see if the problem returns
Mar 07, 2011 | Acer AL1715 (Black, Silver) 17" LCD...
On my monitor W1941S half of area (left side) changed all colours to darker then right side (which is o.k.), What is the problem? Thank you.
Press f-Engine button (it is on the right side of MENU button), select your desired setting, if it doesn't help, select the "X" (none) mode - the half dark screen will reset to full screen OK mode.
Jan 08, 2011 | LG W1941S-PF Monitor
My monitor suddenly has become distorted. It appears scrunched horizontally, from both the right and left sides. The whole monitor image is visible, but it is distorted. I have checked the cables, reset...
Try connecting the monitor to a different computer (desktop/laptop).
If the symptoms persist, it's time to responsibly recycle the CRT, and to replace it with a 19-inch LCD monitor.
Sep 30, 2010 | Dell E771a 17" CRT Monitor
Lcd dislays lock padlock and none of the buttons
To Unlock the buttons, kindly follow the instructions on the Dell support page by clicking this link.
On the page which opens, scroll down to the OSD settings section.
Thanks for using FixYa.
Jul 12, 2010 | Dell E156FP 15" LCD Monitor
Welcome Screen Blinking Gateway Monitor
I would suggest that you re-install the disc. that comes with the screen.
If that doesn't work, check to see that your video card is working correctly.
May 26, 2009 | Gateway FPD1975 19" LCD Monitor
Monitor shows nothing on screen, power button on solid, none of other buttons respond.
plz try by removing the connector of the monitor from the back of cpu while keeping your monitor power on. if you get any message in the monitor then your monitor is ok. then open your side cover and try by resiting the ram, you have to swithch off your pc before opening your side cover. If you dont get any thing in the monitor then *********** board is having problem
Apr 13, 2009 | Computers & Internet
Display window stays on screen, buttons won't work
Sounds like one of the buttons on the monitor is stuck in. See if you can unstick them by pressing them infirmly, but not too hard, several times. Try each one in succession. Hope this helps!
Jan 02, 2009 | Insignia IS-LCDTV32 32 in. Television
Relisys TL766 monitor. OSD menu continually open, wont close. Standby button doesnt always function.
Here is a definite solution to all those having problems with OCS menu on Relisys TL 766 Monitor.
Having tried many of the posted solutions none of which worked. The only option was to visit my local PC repair shop who disconnected the OCD monitor for UK £15.00. Spare parts for this model are no longer available. Only down side was the power indicator light in middle of now redundant control buttons does not work. Otherwise a monitor works perfectly. NO MORE STRESS.
Oct 15, 2008 | Relisys TL 766 Monitor
Extech Br200 Wireless Inspection Camera W/ 17mm Head Logo
82 people viewed this question
Top Extech Home Security Experts
Lawrence Oravetz
Are you an Extech Home Security Expert? Answer questions, earn points and help others
