Question about Fuji Computers & Internet
Hi there I have this Fuji Luxsetter 5600V and having an error Film jam 85. I opened the covers and found no traces of jammed film. would you assist me on this.
  • 163 Answers
SOURCE: paper jam, and check film error messages
dear sir the film sensing sensor and paper path sensors are abnormal or dusty pleaz check them
Posted on Sep 21, 2007
cammedic
  • 667 Answers
SOURCE: advance lever jam
Yes, If you get metering lights in the viewfinder display that go out when you press the release fully to take a picture, it is the cap.
Posted on Aug 05, 2008
SOURCE: Paper Jam
I have just had the same problem on one of these Canon MF4150 machines.
The manufactures warranty on our machine had expired just one week before this happened so I had to fix this myself.
The problem we had (which is very likely to be the same cause as yours) is when we removed some torn jammed paper, it had somehow pulled off a spring from inside the machine. The spring was linked to the paper jam sensor.
It does involve a LOT of work to fix it, and unless you are very 'techy' it may be quite a difficult task to do this for the 'average' person.
I had to completely disassemble the machine: Take off the front first (lift up the cover and there is 2 screws at the front and 2 clips on the bottom of the machine) Then remove the 2sides and finally the top (screws should be easy to see, to get the sides off, un-clip along the front edges and gently move them outwards and slide them backwards to release the clips on the back) being careful with the wires going to the scanner part). Then look for the fuser unit which is near the top at the back, there is a black rounded cover over the fuser. To remove the cover, look for 2 small clips one at each side and unclip the cover and gently lift upwards.  Under the cover on the left side you will see a small plastic rod which goes from the left side to a small tab in the middle, if you look about half way along that rod you should see a tiny spring, make sure this is clipped on properly and that you are able to rotate the rod and it should spring back to the proper position when you let go.
Once this is done, put it all back together again and it should work fine.
I'm sure a lot of other people probably have this same problem too so I hope this helps someone.
Posted on Sep 09, 2008
SOURCE: Paper Jam 075-134 (states Open Reg cover and Check MPF)
The problem might be that it isn't picking up the paper. This will register as a jam if the paper does not reach the next paper sensor within a certain amount of time. check the feed assembly and check the paper to see if there are any marks on the edge from the pickup roller.
Posted on Feb 02, 2009
SGNath
  • 170 Answers
SOURCE: Nikon FE film winder jammed.
Is it the viewfinder or the film advance lever? If the viewfinder is not showing any image and the shutter is not getting released, then it could be a problem with the mirror box.To confirm, remove the lens and see if it gets released. To align the lens, you have to take it to the nearest service center (or repair shop).
Posted on Feb 05, 2009
Luxsetter 5600 when i start the machine this message appear "film jam" err 90 what can i do
You'll need to open it up and check the entire film path to see where a jam may be. It could also have debris or film pieces stuck along the path.
Sep 04, 2014 | Photography
Canon ir 3300 have a problem for paper jam in fixing film so how to solve the problem
there is an error in the rotation of the fixing film.
check the fixing film sensor and make sure that all the wiring and the connectors are connected securely.
if it persists, consider replacing the fuser fixing film
thanks
Aug 17, 2014 | Canon IR 3300 Digital Copier
Fuji film finepixF480 showing focus error
Possible that the lens mechanism is jammed , sometimes the flexible connector of the lens focus/zoom can be faulty.You try to check for some tips from the link below; http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Dec 30, 2011 | Fuji FinePix F480 Digital Camera
My canon IR 2018 copier is giving me system error 007
hi;
its a fixing film problem, your fixing film is not spining properly maybe its paper jammed inside try to clean paper jam carefully else you order new fixing film from canon
good luck
Oct 20, 2010 | Canon iR 2016i Black and White Copier
The printer display an error message E007, the printer model is CANON IR 2016i
The error E007, is a common error for digital copiers, B&W segment.It means that fixing film on fixing heater is worn out.To be exact: on left side of fixing film on heater is little white square.With help of this square, photo sensor knows the condition of fixing film.If this square is "eaten", the sensor does not recognize it and automatically reports error code E007.
Your next step should be to replace fixing film. For EU region, or 230V and 50Hz current, the part number is FM2-3353 FIXING FILM ASSY.
In case of mild worn fixing film, you can try to turn off and on the copier, and get few more copies.
If the copier has over than 500 000 copies, the best solution would be to replace the whole fixing unit.
For EU region, the part number is FM2-3352.
The condition of fixing film you can check with pocket mirror and flash light.
Open the left door, above the drum unit (long green roller) is fixing unit which have warning heat lable.Place the pocket mirror under left side of fixing unit, and you should be able to see the damadged fixing film.Also if the fixing is so badly eaten, on left door should be particles of light brown color.
But however, you should replace the fixing film.
Feb 16, 2010 | Canon iR 2016i Black and White Copier
I have System error E007 problem in my Canon iR-2016 copier machine?
Hi
Thanks for using FixYa. Error E007 means there is a jam in the Fixing/Fuser Assy. Error E007 is related to a non-detection of the Fixing Film/Upper Roller, the fixing film sensor didn’t detected the rotation of the film for 6 sec or more while the fixing motor is driven. Please check the condition of your Film also check the green handle in this area for paper jam removal if it is broken or removed, may also cause this error. If everything is fine then try clearing the error by entering the service mode, you can do it by pressing *(star), then press 2 and 8 keys at the same time & then press *(star) again.
Now press COPIER>FUNCTION>CLEAR>ERR, to clear the error code.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 28, 2009 | Sharp AR-M350N Copier
No error message displayed when film jams
Take it into nikon specialty shop for a service.
Aug 18, 2009 | Nikon Super Coolscan 5000 ED Film Scanner
Canon printer iR2016 error E192
HI, The problem could be casused if there was paper jam as the error is related to a non-detection of the Fixing Film/Upper Roller not spinning correctly. Please check the condtion of your Film also check the green handle in this area for paper jam removal if it is broken or removed, may also cause this error. Good luck Thanks for using fixya proton
Apr 28, 2009 | Computers & Internet
Paper jam, and check film error messages
Sep 19, 2007 | Panasonic KX-FP121 Plain Paper Thermal Fax
Computers & Internet Logo
100 people viewed this question
Top Fuji Computers & Internet Experts
Computer Links
Victorman
Victorman
robert
Are you a Fuji Computer and Internet Expert? Answer questions, earn points and help others
