Question about Zanussi Ovens
Zanussi zkt6050x oven was working went off no conrol lights would not reset by turning off at mains after about one and half hours started working again any ideas
  • 6 Answers
SOURCE: Main oven not heating.
Hi, Is this your fan oven element that is not getting heating up? If so we have a guide on our site which may be of assistance: http://www.ransomspares.co.uk/fan_element_article.html
Posted on Mar 01, 2007
  • 1462 Answers
SOURCE: main oven not heating up
fan oven element has gone. it is a circular element and is located behind the back panel of the oven. some elements can be removed with the oven in place but for many you have to take the oven out and take off the rear casing. whichever, it is not a difficult job. element cost about £30
Posted on Mar 29, 2007
SOURCE: Oven will work for about half an hour and then turns itself off.
it sounds like the thermal cut out is broken can be replaced quiet easy need to disconnect oven from mains remove outer cover and has four wires two blue two white all with spade connectors can be bought from e spares on the web
Posted on Dec 08, 2007
  • 1894 Answers
SOURCE: F0 Error code
your model number please?
Posted on Jan 21, 2008
SOURCE: Main Oven does not get
Called Engineer in the end, Heating element needed replacing
Posted on Aug 15, 2008
Oven light blew and now no power to the oven.
If you are not knowledgable in electricity, call for service.
This is an electrical short at the light, I have seen this before.
The wiring for the light has grounded to the oven. This causes the main fuse to blow. You will need to fix the short first. Then reset the main fuse/replace.
In the case of the wall oven, you may have to remove the oven to fix it properly. Depending on the model and where the short is.
Nov 25, 2013 | Zanussi ZBF360 Electric Single Oven
The bottom oven on my zanussi zuq 875 has stopped working. No power indications of any kind.Top oven works fine. Followed instructions in manual but no power at all.ie; indicator lights, fan ,oven light....
Have you checked that the timer clock is set and not flashing,because the rest of the cooker will work after power outage but for the main/fan oven to work the clock needs resetting.
Hope this helps.
Jun 13, 2010 | Zanussi Ovens
Frigidaire gallery stove, oven not working,
Morison,
The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
May 04, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Faulty main oven
If the fan is working in the oven, and it is electrically heated, then it will be a faulty oven element.
This is located at the rear of the oven behind a removeable cover.
Feb 10, 2010 | Zanussi Ovens
Fan in main oven boken
Sounds as if your oven heating element has failed. You need to fit a new one.
Usually you have to get the back off, disconnect the old element, remove the fixxing screws and element, fit new one, reconnect and it should be fixed. Don't forget to switch the power off before starting work.
Dec 31, 2009 | Zanussi Ovens
We have a Zanussi built under oven (ZUF270). Last
You could but if you disable the timer and anything goes wrong with it could invalid your house insurance if anything went very wrong.
Jan 09, 2018 | Zanussi ZHQ575 Electric Double Oven
You need to replace a faulty main oven element.
This is done by removing the rear cover in the main oven,
there you will see the element, disconnect and replace.
It is not a difficult job , and is not too expensive.
Plz frate my solution.
THANKS.
Jan 06, 2009 | Zanussi Ovens
Whirlpool oven accubake system
I have a whirlpool accubake wall oven. Half-way through baking a pie ,unknown to me, the oven went to the self-clean mode , the door locked and the pie started to burn. I tried to turn the oven off but it would not cut off. I immediately ran to the house's main power and turned off the oven breaker. I waited for a short time to let the oven cool enough to open the door and get the burned pie out, then went back to turn my breaker back on and the oven (even though in the off mode) started heating again with the bottom unit turning red again. I had to then go back and pull the power. We tried this several times trying to push the off button but the oven will not go off until we throw the breaker. Help please!
Jul 01, 2008 | Whirlpool RBS245PDS Electric Single Oven
Nov 04, 2007 | AEG B4101-4 Electric Single Oven
Ovens Logo
Top Zanussi Ovens Experts
ashburton
Charles T Nevin
Charles T Nevin
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
