Question about HP Vectra VEi7 (D8131T#ABA) PC Desktop
Car with spanner on dash &willnot rev more than 3000 revs
  • yadayada
    yadayada Mar 16, 2011
    That symbol means you are in limp mode. This is caused by a failure in the system
    Sergeant:
    Novelist:
  • 185 Answers
Hi there. Usually the car with spanner you describe on your dashboard could be 1 of 2 things.
1 it could be your engine management light (meaning there is a fault somewhere in your engine)
2 it could be your service light (meaning your car is due a service)
The only way you will be able to find out exactly what this simbol means is by looking in your cars manual (usually a black book that comes with your car)
Due to your car only revving upto 3000revs, This could be a number of things.
1, lift your bonnet and unscrew the oil cap (yellow cap with oil logo on it)
If there is a mustard coloured residue on the cap and inside the engine, your head gasket is going or it has blown. (This is usually the main cause of your car only revving low and very expensive to fix.)
2, there may be a problem along the exhaust (a hole in the exhaust or broken joint , not so expensive to fix)
Hope this helps and please rate. If you need any further assistance please feel free to comment and i will get back to you asap.
Posted on Mar 16, 2011
Hyundai sante fe 2007 2.2crdi wont rev past 3000 rpm
If your standing still in park it wont rev past 3000 rpm as its got a limiter on it And only revs past 3000 rpm in drive on the move.
Sep 27, 2016 | 2007 Hyundai Santa Fe
2002 jaguar xj8 when I drive it won't go over 3000rpm
Jaguar wont rev 3000 rpm Questions & Answers - Fixya
www.fixya.com > Forum > Tags > wont rev 3000 rpm
1998 Jaguar XJ8 won't rev over 3000 rpm ... Wont go beyong 3000 Revs s type 2001, wont go beyond 3000 Revs and it' in limp ... Question about 2002 X-Type ... My jaguar xjr8 year 2000 battery went dead started car went for short drive back ...
Jaguar engine cuts 3000 rpm Questions & Answers - Fixya
www.fixya.com > Forum > Tags > engine cuts 3000 rpm
1998 Jaguar XJ8 won't rev over 3000 rpm ... engine cuts out and shudders at 3000 rpm won't accelerateobd code p0332 2002 jaguar x type 3.0 l P0332 - Knock ... Car is boging out in park and will not go over ... driving, don't worry about it.
Rev Won't go up
www.jaguarforum.com/showthread.php?t=14662
Dec 15, 2015 | Jaguar Cars & Trucks
Vectra 1.6 16v will not rev above 3000 rpm
I recently had the same problem with my transit connect.
Does the power judder at all?
The fault turned out to be the fuel pump.
Feb 02, 2014 | Cars & Trucks
Igot a vauxhall astra 1.8 sri igot a light *** on the dash its a car with a spanner threw it when on the engine idles bad
there so many reason
1 may be co2 sensor
2 air mass sensor
3 coil pack
4 throttle body sticky
Apr 18, 2012 | Vauxhall Astra Cars & Trucks
I have a mk3 golf 1.8 8v 1993. it sarts beeping at just over 2000 revs. it will continue untill i rev it over 3000 revs. any ideas????
I suggest you get a replacement waterpump. (approx £30 from gsf). I have the same problem on my 1.8 auto golf. there is a red light on your dash that comes on unless the bulb has gone
Apr 12, 2009 | 1993 Volkswagen Golf
Shogun pajero 1990 rev counter
hi i think your going to need to replace the speedo cable this goes from the back of the dash display through the bulk head then into the back of the gear box.
When you remove the old one remember how it came out as they can be fidly to do.
Im not 100% sure how much of the dash has to come out untill the display is free and you can get to the back of it.
The cables are not expensive but can be tricky to replace if you are unsure about working on vehicles.
Even if you took it to garage to get done it should not cost that much anyway if your going to do it yourself its best to buy the part before you reomve the old one so as you can follow the old one with the new one.
where it goes into the back of the rev counter this should just be hand tight and should undo the cap that holds it into the rev counter then it should pull out.
Where it goes into the gearbox you will need big spanners im not sure of size but usually about 17 or 19 spanner udon this and ot should pull out its splined into the gearbox once removed you will know if the cable is damaged by turning one end and see if the other end turns or not.
In the rare case that this cable is fine then you might find that the rev counter needs replacing this is not likely to be the problem though as they usually last as long as the car.
The gearbox end should have no problems so i would remove rev cable first and check this youll find it will have split in half.
If you need further assistance let me know or let me know if the rev counter is digital then let me know ok then i help you with that ok
Feb 01, 2008 | Car Audio & Video
HP Vectra VEi7 (D8131T#ABA) PC Desktop Logo
163 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
