Question about Canon PIXMA MP160 All-In-One Printer
My gadget MP160 flashes nubers 2 then 7 then E and tells that the Cartridge is overfull with ink. what can I do
    Guru:
  • 78 Answers
Hi spahoromeo, Clearing procedures for E27 or Error 27 Code for Canon Printer:
1. With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
2. When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3. When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4. When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset button pressing LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print (auto teste)
2 times Green EEPROM print (dados da EEPROM)
3 times Orange EEPROM reset (EEPROM reset)
4 times Green Waste ink counter reset (Absorvente reset)
* Turn off the printer.( it must be turn off) then turn it on again.
PLEASE Note:
This is actually a very easy fix.
Two absorber pads are located on the right side of the printer, under the ink cartridges. With the printer on, lift the top to expose the cartridges. They will automatically move out of the way. You can move them to the left side by hand if the printer is not on. You will probably need a flashlight to see the pads. They each sit in a rubber retainer. The pads can be removed very easily and cleaned. Take the pads out of the retainers with tweezers. They clean up nicely with warm water but you can use something like Simple Green if they are stubborn. It is best to use a spray bottle (on stream) and blast it through the pad until it is white. Sometimes just putting it under a running faucet will do the trick. If there is ink in the rubber retainer after taking the pad out, it can be cleaned up with a paper towel. Put the pads back into the retainers and you have successfully cleaned the ink absorbers. Now you may have to reset the error message so you can get back to printing. This is how to do it.
Posted on Mar 16, 2011
Please describe your what size ink cartridge do i need for pixma mp160 printer problem:
The following cartridges are compatible with Canon MP160:
Canon PG 40 Black Ink Cartridge Black Ink Cartridge
Canon PG 50 High Capacity Black Ink Cartridge
Black FINE Cartridge, High Capacity
Canon CL 41 Tri Color Ink Cartridge
1 Cartridge of Cyan, Magenta, and Yellow
Canon CL 51 High Capacity Color Ink Cartridge
Color FINE Cartridge, High Capacity
Nov 23, 2010 | Office Equipment & Supplies
My canon mp160 got a error 5100 or E2. I have tried several solution: uninstall and reinstall the driver, reset the printer, shake the ink cartridge but still it won't work. Please help..
E2-2 = No paper (ASF) and E22 = Carriage error
steps from canon website 1. Allow print head to cool down
2. Disconnect and reconnect the USB cable to ensure a secure connection
3. Press ON/OFF switch to reset the multifunction device
4. Reseat ink cartridge (MP160 / MP180 / MP460)
5. The MP160 may require repair
if you need further assistance please let me know, Thanks midwest-tek
Aug 31, 2010 | Canon PIXMA MP160 All-In-One InkJet...
5E problem
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly.
1. try to take out colour ink and then put in again to see ok or no
2.try to install new cartridge to see ok or no
3.if this all can't is better you send you printer to authorized canon to check you printer is print head problem or no....
Aug 13, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Flashing E and the number 5
E 5 says that the ink color ink cartridge is defective or not compatible with your machine. You can try wiping the contacts on the cartridge, but you probably need a new ink.
Jun 26, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Ink cartridge
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prito-i-7
May 09, 2009 | Canon PIXMA MP160 All-In-One InkJet...
I am getting an error on my cannon mp160 all in one of a backward
MP150/160 resetting errors
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
button pressing
5 times Orange Destination setting
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
E8 Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD over current error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Apr 08, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Error message on Canon MP160 flashing E-2-2 error message 5100
The error code refers to Ink Cartridge
Issue: ERROR: Error code 5100 appears on the computer screen
Issue: ERROR LED: E, 2, 2
1. Disconnect and reconnect power cord to reset the device
2. Remove Packing Material MP160 / MP180 / MP460
3. Reseat ink cartridge (MP160 / MP180 / MP460)
Nov 15, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Canon mp160 error
E5 means one of three things.
1. The ink cartridges are not installed
2. The ink cartridges installed are not compatible
3. The ink cartridges are not installed correctly.
Are you using genuine Canon or a copy cartridge? If copy then they may not be correct. If they are genuine Canon you may need a new printhead.
Nov 14, 2008 | Canon PIXMA MP160 All-In-One InkJet...
E5 Error when I reinstalled new & original cartridges
hi,
597
Jul 01, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA  MP160 All-In-One Printer Logo
85 people viewed this question
old marine
old marine
