Question about Mackie 1604 Vlz3 16 Channel Mixer
I have 1604-Vlz3 mixer recorded on cubase5 best matchable sound card is? I have M-audio delta 1010LT.This not so good sound.after recording. For like "Bollowood Hindi VocaSetting" EQSettings Mixer & Cubase mixerEQ for recording /Sound card DB/DELAY, REVERB ? gain 70% sennheiser 845e voc mic
  • Mackie Master
  • 5,603 Answers
The problem is that card has only UNBALANCED inputs. You really need balanced or first run the mixer outputs through a DI backwards. Frankly, I would recommend NOT using a card within the PC as there is so much digital noise. Use either a USB or Firewire external convertor and for goodness sakes use balanced lines from teh Mackie... ALL interconnected equipment needs to be powered from the same receptacle or source. M Audio, Roland/Cakewalk and Presonus all make cards as do others.
Posted on Mar 16, 2011
Just bought the mackie 1604 vlz3 mixer and cant figure out how to get sound to the main speakers, the speakers and amps are connected correctly
Simplest is to use the LR button at the bottom of the channel strips you want to send to the main mix. Make sure you set the gain for each channel in use so that the clip light just occasionally blinked then back off a fraction.
If you want to use sub channels assign the strip to the appropriate one 1/2 or 3/4 and the assign the sub to the main mix and bring the subs up.
May 21, 2016 | Mackie 1604 Vlz3 16 Channel Mixer
What is the best way to run a Bass thrue the mixer , Mike the Amp or directley thrue the mixer, we had problems with a clear sound?
The easiest way is to take the line out from the bass amp and connect it to the line in socket of the mixer ( not the XLR Mic in ). This will give a clean and flat sound which you will have to customize using the Mixer tone control and not the bass amp controls.
May 01, 2011 | Mackie 1604 Vlz3 16 Channel Mixer
MAckie 1604 VLZ Pro Mixer, running QSC 1850 with jbl's from main outs. I would like to hook up powered subwoofers. What is the correct pathway? kenshireman@msn.com
The best way is to use a two-way crossover between the mixer and the amplifiers. In your case, the low output from teh crossover would go to the powered subs, the highs to the QSC. Use the crossover adjustment to set the frequency crossover point to get the sound quality you require.
Dan
Mackie 1604 ---> Crossover --- Highs ---> QSC --->Speakers
-----> Crossover --- Lows ---> Powered Subs.
Jan 27, 2011 | Mackie 1604 Vlz3 16 Channel Mixer
I have 1604-Vlz3, M-audio Delta 1010LT With Cubase 5 . There is a main problem when it's normal with an apm it's no problem no sound problem but when the direct out is working with the sound card the...
You MAY be overdriving the sound card. Near flat should work for vocal, but setting the levels throughout the mixer is important as well as the sound card. You can use the LOW CUT to reduce hum if you have noisy system. Describing balancing the levels is more than I can do here. There are many good videos about mixer setup on YouTube.com. You cannot "fix" problems created by improper levels and noise injected into the system using the EQ.
What is important is to see that all gain controls and faders are around mid range to 70% when operating normally. You should be using BALANCED lines everywhere possible either XLR or TRS cables. ALL interconnected equipment should be powered from the same receptacle or power source INCLUDING all amps and powered speakers. Often users use unbalanced lines from mixers to sound boards and pick up noise or they have the levels set wrong between the mixer and sound board resulting in clipping and distortion or poor signal-to-noise ratio.
Jan 18, 2011 | Mackie 1604 Vlz3 16 Channel Mixer
I cant get my mackie 2404 VLZ3 to record any audio? I have the board setup to record from the master but no audio comes into my computer. What to do next?
check your cables, on some Mackie boards press the switch to enable master out, make sure the mute or cancle button is not pressed. i have a 2404 vlzpro mixer it's simular to yours, if you have any problems, you can call Mackie direct if the issue is not solved, it could be a bad button, fuse or slide controle, or even a fuse
Dec 12, 2010 | Mackie 2404-VLZ3 Mixer
HI, i cant get my mackie to record any audio, instrumenta, nore to record for live oline recording. what should i do?
you need a recording device to do it, a recording software and most of all an
interface.
Dec 05, 2010 | Mackie 2404-VLZ3 Mixer
I am trying to connect my mackie 1604 into my m audio device so i can record off of a program on my computer. How do I do that?
Using two balanced lines either TRS or XLR depending on what is on your M audiointerface, connect the L and R main outputs of the mixer to the L and R inputs of the M Audio. You will need recording software on your computer.
Nov 27, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
I was trying to hook up our 1604 vlz3 at our church and was wondering how the best way to do this?
Without knowing the resources you are connecting I cannot give you a schematic but will give this GENERAL advice:
1. Use BALANCED lines to connect from the mixer to your amps, preferably XLR connections.
2. Service the power to the amps and the mixer from the SAME place even if it means stringing a power cable alongside you audio cable snake.
Jun 12, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
Mackie 1604 VLZ3 Issue.
Hi kielhunt
It sounds like power supply issues.
You may have bad capacitors and/or bad regulators.
If you have a multimeter you can get in there and check the dc voltages for ripple(ac voltage mixed with dc) or over/under voltages along the +/- 15volts lines.
Good luck
Jan 20, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
Mackie 1604 Vlz3 16 Channel Mixer Logo
147 people viewed this question
Top Mackie Music Experts
Michial Gueffroy
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
 Grubhead
Grubhead
Are you a Mackie Music Expert? Answer questions, earn points and help others
