Question about Dell Vostro 1320 Notebook
The computer does not start up. It lights up the power indicator and after a couple of minutes it went off. Sometime the number indicator keeps beeping and it remains until I shut the computer off. For all your hepl, Thank you very much
    Problem Solver:
  • 13 Answers
Try unplugging the laptop. Then once you've unplugged the laptop remove the battery. With the laptop unplugged and battery removed, hold the power button for 10 seconds. Replace the battery and the power cord and see if the computer boots.
Posted on Mar 16, 2011
Watching T V and screen went black, Is it junk or is their a way to reset it ? Power light is on , but that is all. No sound.
Most TVs these days are computer-controlled, and the computer stays on, even when the TV is "off" so it can receive commands from the remote. Sometimes the computer gets hung up, particularly if there was a short-term power failure (a drop of a few seconds).
The way to reset it is to unplug the TV for a few minutes. See if that helps.
Nov 26, 2014 | Televison & Video
Hi my ignition light comes on an the steering gose stiff air bag light came on abs light came then when i stopped the car it would not start again but it did not effect my light
Have a load test done on the battery . Check battery posts and terminals are shiny clean and tight.. Check the alternator drive belt condition and tension because if it drives both the alternator and the power steering pump it indicates a belt problem.
Feb 11, 2014 | Peugeot 307 Cars & Trucks
I have a motorola blue tooth and I need to pair it to my htc evo.... How can I do that?
Ok, I'll give you a default procedure to put a blueetooth headset in pairing mode: starting with it turned off, press and hold the call button as if you were turning it on, but keep pressing the button until the indicator light is either steadily lit, or flashing rapidly, sometime in more than one color. This is usually achieved by holding the button down for some 6 to 10 seconds. Then, make your phone's blueetooth application search for new devices. After a while, your headset should appear on-screen. Make the application connect to it. If a pairing code (or passkey, or PIN), is requested, enter '0000' (four zeros). If the pairing process is successful, your headset's indicator light should flash some times, and enter the stand-by mode (normally flashing every couple of seconds). Your phone should also indicate that a headset is connected. However if the pairing process fails, after a couple of minutes your headset will quit the pairing mode, Turn it off, by pressing the button until the light goes off, and start the whole process again, firstly trying '0000' one more time, then changing it either by '1234' or '8888',
Hope you are able to sort your problems out soon, but, please, let me know if you further assistance.
Regards, Carlos
Sep 14, 2010 | Motorola Mobility Bluetooth Hands Free...
The light on my hard drive is yellow rather than green and my computer will not turn on.
Ordinarily yellow light indicates ACPI standby. On some Dell and HP motherboards the same light also indicates a CPU failure, usually due to overvoltage or overheating.
Turn the PC completely off (unplug from the wall socket). Open the side, so you can see the motherboard with CPU and heat block. Best if you wait some ten-twenty minutes. Plug the power cable and power on the PC. Does it turn on, and does the CPU fan rotate correctly? If the PC turns on, and the fan doesn't, you have a busted fan which needs replacing.
If this doesn't solve the issue, describe exactly how the error happened. Is it a new PC, a PC which already worked and stopped doing so, a DIY assembled machine? Does it never turn on, or does it sometime do?
Aug 20, 2010 | Dell (8N816) Motherboard
No picture no sound opc light and power light
This is very common in sharp tvs.U turn it on.U get power on light stable right?U hear a click,one or twice,sometime tv is good right?Sometime POWER light and OPC light flashes?Push the power button on/off couples times will work, picture will come on.If keep trying off/on couples time after POWER and OPC flashes,don't ever stop and never get backlight and picture.Ur Video backlight board is dead must replaced.
Dec 28, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Vizio P50HDM No Picture/No Sound
this is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at vancebaldwin.com
May 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
LG 700E monitor's power LED blinking continueously, no display
The monitor is probably on protection.
To start unplug monitor from power and from computer and test computer with different monitor to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
  • Video cable.
  • Video adapter on PC (sometimes integrated on motherboard)
  • Motherboard.
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing led on front of the monitor , and monitor turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occurr are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Apr 08, 2009 | LG 500LC Monitor
Screen went black
plz try by resiting the ram, if the problem persist then you have problem in display adapter,send it to the vendor from whom you have bought
May 16, 2008 | Compaq Presario 700 470024-192 Notebook
Flashing power light
you need 4 caps in you dm module they are 1000 mf @35volts
May 23, 2007 | Hitachi 43FDX20B 43" Rear Projection...
Dell Vostro 1320 Notebook Logo
261 people viewed this question
Alun Cox
