Question about Liebherr Refrigerators
My refigerator is freezing up,even when the temperature control dial is set at 1
    Champion:
  • 202 Answers
Bad thermostat
Posted on Mar 16, 2011
Top of fridge freezing with temperature on lowest setting
You need a new thermostat but there are some things you can check in the link. 1 is the warmest setting.
Most refrigerator temperature settings are controlled with a dial or slider. They are sometimes labeled 1 through 5 or 1 through 9. If you are not sure what to set it to, then set it somewhere in the middle. If the dial is numbered 1 to 5 set it on 3, if the dial is numbered 1 to 9, then set at 4. USUALLY the higher the number on the temp control dial, the colder the temperature your refrigerator will get. If your drinks and food are not as cold as you like, set the temperature dial up one number higher. If it is at 3 and you want your food colder, set it to 4 and test 12-24 hours later to see if your food is at the temperature you want.
Why Is My Refrigerator Too Cold
Dec 18, 2016 | Refrigerators
Electrolux freezer will not turn on automatically when termperature warms in compartment, controls don't appear to turn compressor on, any help would be appreciated?
Sounds like your thermostat is bad. You probably have to replace it and the sending unit also. Big job! Look for a manual at : http://www.servicemanuals.net
Apr 28, 2014 | Electrolux Freezers
How can I get into the cut-on settings of refrigerator
Purchase an appliance thermometer that is specifically made for refrigerators and freezers. These special thermometers were made to withstand cold temperatures and provide an accurate reading when exposed to such temperatures.
2Place the appliance thermometer in a glass of water.
3Set the glass of water with the thermometer in the refrigerator on the middle shelf.
4Check the temperature on the appliance thermometer after 24 hours.
The temperature should register between 37 and 40 degrees Fahrenheit (2 and 4 degrees Celsius) in order to store food safely.
Only barely above freezing -- say 34 degrees Fahrenheit (1 degree Celsius) is even better for food storage at the cost of slightly higher electricity consumption. But check that food is not slowly freezing in any part of the refrigerator, which could make it less palatable.
5Look for the temperature control dial inside the refrigerator if you have to adjust the temperature, and make it warmer or cooler.
If you can't easily see the control dial, check the owner's manual for a diagram that shows the location.
When looking at the refrigerator temperature dial, you may see numbers rather than degrees. The majority of refrigerators use a set of numbers, with the lower numbers representing cooler temperatures and the higher numbers representing warmer temperatures.
6Move the temperature dial in the necessary direction to adjust the temperature up or down. Be sure to move the dial only one number in either direction because it probably will not take much to change the temperature in the refrigerator.
7Adjust the temperature balance control if your refrigerator has such a dial or sliding switch. This allows you to direct more or less cold air to the refrigerator section from the freezer section.
8Wait at least 24 hours, and then check the refrigerator temperature again.
9Observe the amount of frost in the freezer section of the refrigerator if you are unable to properly set the temperature.
10Defrost the freezer if the amount of frost is more than .25 inches (.64 cm) thick.
11Repeat the steps as necessary until the temperature is within the safe range.
12Use a permanent marker to draw a line on the dial after you locate the best setting on the refrigerator temperature dial. This will give you a reference point in case your dial moves and needs to be adjusted in the future.
Hope this help in solving the problem....
May 12, 2011 | Refrigerators
How do I regulate temperature
I hope this will help in solving the problem.......
May 09, 2011 | Samsung RF265AA Bottom Freezer French Door...
How to set up the temp. please
Hope this will help out...
May 07, 2011 | Traulsen Refrigerators
I cannot adjust the fridge/freezer temperature
Hi, there
Hope that helps in solving the problem...
May 07, 2011 | Refrigerators
Freezer is freezing fridge is warmer than usual does the dial indicating coldness from 1 to 2 apply to the freezer, refrigerator or both? have cleaned condenser on back of refrigerator - it was not really...
Usually, the freezer knob just adjusts the airflow from the freezer to the freshfood section. The refigerator control turns the unit on and controls temperature. When unit is running, do you hear the fan running in the freezer? The fan forces air to the refigerator section. If not, probably bad fan motor. If it is, do you see frost build up on the back wall of freezer section? If so this would indicate a defrost problem, ice build up on evaperator blocking airflow to refrigerator section. You cleaned the condenser, Was the condenser fan running? Defrost causes. Defrost thermostat, heater,defrost timer. Good luck.
Mar 31, 2011 | Whirlpool Refrigerators
The lettuce freezes even when we dial the control to 45 degrees. Please help
#1 Does your lettuce freeze in the crisper drawer? If so this would be your thermistor located behind the temperature control knob. At the very top inside the top cover is where it is located. It looks like a device with a wire covered in plastic that reads your temperature and allows your refrigerator to cool evenly. If your lettuce is not in the crisper drawer than this can also freeze your vegetables and dry them out. I hope I helped you.
Sep 02, 2010 | Maytag MZD2766GES Side by Side...
Side by side..fridge is freezing up while freezer works fine
Your baffle that controls the freezer temperature is possibly broken.  If you take the cover off the dials labeled "refrigerator/freezer" the baffle is a plastic arm that controls the amount of air circulation between the freezer and the refigerator. If the arm is broken is will stay closed completely blocking the air hole or vent.  I just wedged a small piece of wood or shim in mine and it hasn't frozen up since.
Good Luck.  I know how frustrating it can be to repeatedly defrost the ice build-up.
Mary Lynn, Alabama
Oct 11, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My refigerator and freezer are not cooling enough
Is the fan in the freezer running?? Is there frost on back panel of freezer??
Oct 03, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
166 people viewed this question
Top Liebherr Refrigerators Experts
Dan Webster
Dan Webster
Shehu Pro
Shehu Pro
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
