Question about Troy Garden
It will not start. I tried squirting starter fluid in the carburetor by taking off the air filter. I t would then start for a few seconds until the starter fluid was gone. I did that several times to see if it would finally catch on, but to no avail.
  • 10,865 Answers
Hello rino.... Make sure you have fresh fuel in the tank, a new spark plug, and a new air filter. Then get that can of starter fluid and a helper. Have the helper continue to squirt a little starter fluid into the air intake after you have removed the air filter. Keep spraying until the engine runs for a couple of minutes and takes off on it's own.
IF after a few minutes of doing this drill with the starter fluid it still won't run on it's own you then have no choice but to disassemble the carb. and clean it. Joe
Thanks for choosing Fixya!
Posted on Mar 17, 2011
Hi i have a briggs and stratton pressure washer cv 2300psi omb 6.75 horse power 2.0 gpm .It was working about amonth ago and jus stop.I pull the string a couple of times and nothing,so i left it .Can you...
hi marlo. check the fuel level, the air filter, and the spark plug. clean or replace as necessary. then get a can of starter fluid and an assistant. give the air intake area, by the air filter a couple of squirts of starter fluid and then start it up. keep it running by squirting more starter fluid for up to 2 minutes until it will run on it's own. J.
Jul 15, 2011 | Briggs & Stratton Gas Pressure Washer...
I JUST BOUGHT A NEW POULAN WOODSHARK CHAINSAW AND IT WILL NOT START
hello red.... how aggravating. Check to be sure the chain is not too tight. Check to be sure it has the right mix of fuel and oil, a clean filter, and a new spark plug. Then get a can of starter fluid and a helper. Remove the air filter and have your helper squirt a little starter fluid into the air intake. Once it starts have the helper continue to squirt starter fluid until it will run on it's own, usually a couple of minutes. Joe
Apr 15, 2011 | Garden
The tb475ss trimmer will not start.
It is difficult to diagnose a no start problem without the machine being on hand. You need to check for blue spark, fresh oil and fuel and a clean air filter. You also need to verify that the engine isn't worn out and that it has compression. To try and get it to start, remove the air filter and squirt some aerosol type carburetor/choke cleaner into the opening to the carburetor. If it runs a few seconds, that is good and eliminates some of the causes. It may just need a good carburetor cleaning. Post back with results.
Oct 15, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
My MTD Sprinto was happily mowing away until i stopped to empty the grassbox. When i returned, it would not start. It has a new battery which reads 11.97 volts, so no probs there and the spark plug looks...
Remove the air filter and take a close look at it with a bright light. It may be clogged. IF so, replace it. Also get a can of starter fluid and a helper. Have your helper squirt a little starter fluid into the air filter opening while u start it up. IT will start. Then keep it running by adding more starter fluid until the problem clears, usually within a minute. Joe
4 thumbs up please. ty
Oct 08, 2010 | Mtd Garden
Has been sitting for a few years.. cleaned carb and chedcked settings on H and L screws.. still wont start.. replaced fuel lines and primer bulb.. and its a mac 3227 weedeater.. cranks but doesnt start,...
siphon out the old fuel and put brand new fuel in the tank. Change the air filter even if it looks ok. Put in a new spark plug. Then get a can of starter fluid and an assistant. Squirt some starter fluid into the air intake and start it up. have your assistant continue to spray the starter fluid for a minute or so until it runs on its own. J.
Sep 30, 2010 | McCulloch Garden
I replaced the carburetor, spark plug, and put in new gasolone on a Toro Recycler (5 yrs. old) and it still won't start. The ignition is only one year old. Seems like I'm not getting any spark and the fuel...
Hi. Replace the air filter. Then use some starter fluid and an assistant. Spray some starter fluid into the air intake as you start it up and keep spraying so that it runs on the starter fluid for a few seconds until it really takes off. J.
If this does not do it then you will have to have the carburetor rebuilt as it has hardened gunk in it.
Aug 01, 2010 | Garden
I have a homelite blower model UT08580. I have replaced the tank (cracked) and the carburetor,I have spark but will not start... suggestions?
Make sure you have a new air filter, new spark plug and fresh fuel. Then get a can of starter fluid and a helper. Squirt some starter fluid at the air intake and start it. Have your helper continue to squirt the starter fluid to keep it going as this will clean out the entire combustion chamber. J.
Jul 31, 2010 | Homelite Garden
Toro lawn mower wont start (super RECYCLER)1998 module. I have changed spark plug and air filter.have been using fresh gas from start of season. any thoughts of what my next step should be
Hi. Get a can of starter fluid from your local auto parts store and a helper. Squirt a little into the air intake, start it and have your helper continue to squirt more fluid to keep it running until you clean the gunk from your carburator. J.
Jul 06, 2010 | Garden
! have a Troy built mower with a Honda engine, it quit running and will not start. I changed the spark plug, it ran for about one hour. Now the mower will not start.
Hello. If the gas has been sitting all winter, remove it with a siphoning bulb and put in brand new gas, not even gas that you have been storing all winter. Also, change your air filter. Finally get a can of starter fluid and a helper. While one person squirts a bit of starter fluid into the air intake [near the air filter] the other person starts it and use more squirts of starter fluid to keep it running. Joe
Apr 09, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
171 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
