The Gateway monitor FPD 1730 screen is black. Someone suggested I check to see if the dimness switch was on. Could you telll me where to locate that? Also what do I do if that's not the problem?
  • Computers & ... Master
  • 27,725 Answers
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
or it might be your graphics card make sure its securely seated and there is no dust built up
on and around the graphics card hope this helps
Posted on Mar 16, 2011
Gateway FPD 1730 (mfg June 2004) On start-up, monitor flashes bios screen for less than half a second, then flashes the Windows XP logo for less than half a second and then stays black, no image. No...
All support is finished for XP years ago. The system is 13 years old and well past it expected life. Average is 8 to 10 years on a shop bought unit like Gateway, 12 years on a custom build.
I am thinking you probably have a dry joint on the board behind the switch as holding the switch makes the monitor work.
My advice though is a new computer running Windows 10, technology moves on in hardware and software.
Mar 08, 2017 | Gateway FPD 1730 17" Flat Panel LCD...
Message from display FPD 1730 won't go away
press the menu button on screen panel and press exit.
Dec 02, 2009 | Gateway FPD 1730 17" Flat Panel LCD...
Computer will power up, but FPD 1730 screen stays dark, says "power saving mode" How to cure??
Its setting problem just fallow this stapes for the same.
Go to Start > Control panel > Power options Properties >
Turn off monitor: Never
Turn off hard disks: Never
System standby: Never
Apply > Ok
After that your issue will resolve.
Thanks
Abhay Singh
Nov 16, 2009 | Gateway FPD 1730 17" Flat Panel LCD...
Gateway monitor FPD 1730: We have had it since
If the screen is black (ie there isn't any backlight) then the fault maybe the inverter board that supplies high voltage to the CCFL lamp ot the CCFL lamp is faulty.
For service, parts and DIY info. check out LCD Parts - use this link to their WEB site.
www.lcdparts.net
Sep 28, 2009 | Computers & Internet
Screen going black, green LED staying on
Check to see if the image is Dimmed. Chances are the power supply on the FPD is either dead or not supplying power to the back lights.
Your problem is the power supply or the inverter on your board, you can replace it and it will be fixed.
Easy Fix REALLY EASY FIX
(inverter is what supplies power to your backlights. A lot of the times the reason a monitor goes black and the green power button is on, is because the backlights shut off. in most designs of the 1730 the inverter is embedded on the power supply. That is most often the case on this problem. Power supply/Inverter=Replace it and you will have a spanking new looking nice monitor working again. :)
Jun 19, 2008 | Gateway FPD 1730 17" Flat Panel LCD...
Gateway flatscreen monitor
There is a problem with the power supply cable to this monitor. You need to have a new one put on. An easy way to test this is to get it to a shop so they can test the cable.
Jun 11, 2008 | Gateway FPD 1730 17" Flat Panel LCD...
Gateway flat screen monitor goes black when turned on
open monitor and look at the PC Board to locate some kind of DRY SOLDER or burn point , specially where a transformer is located , check re solder any solder point that looks suspicious , and try again , hope this helps
May 03, 2008 | Gateway FPD 1730 17" Flat Panel LCD...
Gateway FPD 1730 17 in. Flat... Problem
Try using it on a different computer, it's possible that it is your graphics card causing the problem. Check for bent pins.
Dec 20, 2007 | Gateway FPD 1730 17" Flat Panel LCD...
Benq7t3
jaki powinien byc ncp1200 (40,60 czy 100 Mhz)
Nov 20, 2007 | Gateway FPD 1730 17 in. Flat Panel LCD...
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
