Hi my son's Bush Freesat remote is not working. He has only used it a few times. I have changed the batteries, but there is obviously not a problem with the box iteself as my other son also has the same box and his remote is working perfectly. There does not seem to be a signal from the remote as when pressing it, the red light does not illuminate. Can you help? Regards. Gillian
SOURCE: My remote does not work with my bush a632" tv. i
Hi there we had same problem so phoned 08456040105 and they told me to press menu button on tv for 10 secs and take batteries out of remote and press power button on remote for 10 secs while batteries are out. it worked for us doing both at same time....good luck
Posted on Feb 05, 2010
Testimonial: "Oh my goodness thank you so much for this advice. I was a bit sceptical but it worked wonderfully!!"
SOURCE: Remote volume control for Sharp Aquos 42inch LCD not working
User 'rapolley' is absolutely right. One can cycle through the functions to access different options, ie. 'TV', 'Audio', 'DVD', etc. I stumbled upon this solution when I thought my 'Menu' button wasn't working. All I had to do is cycle through the 'Functions' and choose 'Menu' once I get to 'TV'. Thanks!
Posted on Mar 19, 2008
  • 63 Answers
SOURCE: Panasonic Plasma TH-42PX60U - power light blinks 12 times
Bad capacitors...! Remove rear panel cover from tv. Most require a star screwdriver. Look for bulging caps in power supply board. (3300uf 10v ) caps need to be replaced with 3300uf 16v. Identify the bad caps.... Caps are bad when they are bulged/bulged and raised. A good Cap is flat X top not raised or buldged. I have pics of what bad caps look like on these boards. Email me if you would like to to see them. Caps cost abywhere from 1-2 dollars or you can buy them in lots of 10 or 12 on ebay for around 8 bucks. Caps need to be soldered on. Do it yourself (if confortable) or take it to a tech/pc repair shop in your local area. Do do that unplug all the wire harness from the board and unscrew the boarda nd take to your teck to solder on the new caps.
You can fix this for about 20 bucks if you have someone else solder or 40 cents if you buy the caps on ebay and replace the 2 bad ones yourself. If one is bad and the other is not replace them both.
The caps go bad because they need to be a higher voltage. 10 insn't enough..... 16 is plenty and don't go any higher than that.
Good Luck
Gunny
Posted on Feb 07, 2009
budmrtn
  • 11361 Answers
SOURCE: tv remote quit working
The remote put out IR (INFRARED) signal that human eyes cannot see, you need to use your digital camera to see it, just point the remote at the camera's lens, you should see flashing light on your camera screen when any remote buttons is pushed.
You may have problem with the IR receiver in your TV, but find out first if the remote is putting out the signals
Parts:
http://www.shopjimmy.com/vizio-3642-0022-0189-ir-sensor.htm
worst case will be the main logic board.
http://www.shopjimmy.com/catalogsearch/result/?q=VX32L
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Posted on Jun 28, 2010
  • 182 Answers
SOURCE: Dear Expert, My elderly parents have
first thing to check is the tv working in its old mode of analouge tv.
if this is instant and the slow start is with freesat box.this is probably faulty .
does the tv have freeview built in this is worth checking .
Posted on Aug 17, 2010
My bush freesat box out record tried turning off and turning on still doesn't work he model number is BU11FSRHD50
hi do you mean it's totally dead, if so this may be due to the fuse inside could have blown, thanks
shaun
Feb 10, 2017 | Bush Televison & Video
THE HANDSET WILL NO LONGER COMMUNICATE WITH THE FREESAT BOX. USING FRESH BATTERIES.
Hi. If the batteries were flat for a length of time or when you changed them there were no batteries in handset for longer than a few minutes the handset might need re synchronising to the box.this process if required will be in the manual.
Oct 15, 2014 | Humax Televison & Video
Will my westinghouse tv work in the uk in conjuction with a bush hd freesat box?
Both the tv and the Bush HD freesat box was bought in the Euoupean union?Wright?Yes,it will work together with no problems,both the tv and Bush HD freesat box both are recieving the same tv incomming broadcasting signal in PAL signal frequencies will be compatible.
Oct 27, 2011 | Westinghouse TX-47F430S 47 in. LCD TV
Freesat remote control manual 02sd
Good morning, afternoon, evening or night; whatever time of day you are viewing this. Thank you for choosing FixYa to solve your request. You want the owner's manual for Freesat 02SD Remote Control? I don't know if this is really gonna help you out, but here's the owner's manual for the Bush BFSAT01SD Freesat Receiver. In this manual, you will see a diagram of the remote and what each button is for.
http://docs.google.com/viewer?a=v&q=cache:MIwevx2mn3IJ:freesatsupport.co.uk/skin/frontend/default/fscom/manuals/BFSAT01SDum.pdf+freesat+remote+control+manual&hl=en&gl=us&pid=bl&srcid=ADGEESicRZoFlcwVLvP-Oeb2fMh_dqRXt6nr_uIZ5nbk844QWOJOuoMXDxq19FlJcFyxsliaOTe32_CV2oeGH3vsz65nnwp5jxl4Ngbp-suWDjIqX4Z5qBTnNz_vuFoHTni8hVJqdRzz&sig=AHIEtbQ_u5VU1ot5G1QramI7VxYPHuc4Pg.
I know this isn't for the exact model you requested, but this is the closest model to that. Sorry for any inconvenience this may cause, but I hope this will work out for you in the end. Thank you for visiting this website and choosing us as your one-stop solution spot for assistance with electronic product problems and requests. Visit us again soon and have a good day, evening or night; whatever time of day you are viewing this.
May 16, 2011 | Audio Players & Recorders
My second television I have freesat ,the remote a goodmans will not work,it is not the batteries,have only had the goodmans free sat for a couple of weeks is there anything I can do?
First find out how many digits of code your remote neeeds for your TV? Then you can input the code on number at a time until it works. Some remote only use two digits, but the lat model TV may need five digits. You can google the codes for goodman's remote for freesat if you know the TV brand name..
Dec 03, 2010 | Televison & Video
Bush hd freesat topbox will not switch off or operate. plugged in hdmi cable to box and television, switched on box started software update, after a while screen went blank since then nothing on screen and...
blobby 1589, my Bush freesat box has just done the same. Power going to it. Blue light on. Cannnot turn the box on. Screen froze before it turned off. Tried unplugging it. There was a software upgrade 2 days ago - wonder if that has anything to do with it
Mar 06, 2010 | Audio Players & Recorders
New codes for Nikkai big button remote control
hi...if don't mind can you send me a Picture and model you're universal remote what kind a universal remote you have.?i need to see what is that likely remote then i teach you to how its work done..Thanks
Apr 23, 2009 | Televison & Video
Poor signal bush hd set top box
I have a saterllite reciver just bought a bush hd freesat top box i am running my virgin cable tv through my samsung hd television i put my satallite cable in to my bush top box connect the hdmi cable to get the freesat turn my virgin box off source the hdmi cable on tv get the freesat logo but nothing else what am i doing wrong
Aug 31, 2008 | Televison & Video
Televison & Video Logo
664 people viewed this question
Top Televison & Video Experts
