Question about Nadeo Trackmania Nations ESWC
Hello, I have 2 problems with trackmania: At first: You chose to force software Tnl (vertex processing), in the advanced graphic pannel. This option can solve graphic driver and or card issues, but it may also affect the game performance. Therefore, it is recommended to only use it to fix graphic glitches (like odd geometry deformation). The second problem: when I try to start trackmania it's says that i have no videocard. How can I solve these problems?
Not enough memory to complete operation in Animation Shop
Contol Panel >System and Security >System >advanced system settings >performance settings; advanced tab open; under performance click "settings"; chose " let windows chose what's best for my computer"
Mar 05, 2014 | Corel Paint Shop Pro 9
Cold fear has stopping work
Try using 3d Analyzer . Run the gama with 3d Analyzer and check "emulate HW TnL caps" and "emulate pixel shader caps" . check force SW TnL and if it doesn't works your pc/laptop/netbook just can't handle the game requirements. I have the same issue here.
Aug 11, 2013 | Ubi Soft Entertainment Cold Fear for...
Replaced Drum Cartridge - Alarm light still on and still says "replace Drum Cartridge. How do I reset?
Try this procedure, it should help fix the problem,
Turn Printer off. While holding down Enter and Menu keys, power the printer on. You should see PCU Diag Mode displayed. Hit Menu key 6 times till Counter Set is displayed. Hit Enter key Dev xxxxx displayed, left 3 numbers are blinking. Hit (down triangle symbol) till numbers are 000. Hit Menu key, right 2 numbers are blinking. Hit (down triangle symbol) till numbers are 00. Hit Menu key. Drm xxxxx displayed, left 3 numbers are blinking Repeat steps 7-10. Dev tm xxxxx displayed. Repeat steps 7-10. Drm xxxxx displayed. Repeat steps 7-10. Life xxx displayed. Life should be set to 005. Hit Menu key. TNL xxx displayed. TNL level should be between 90-110, if you have problems, try changing TNL. Hit Enter key Counter Set is displayed. Hold down Form Feed key and insert blank paper into manual feed slot. You should get a beep confirming reset. Power printer down and back up, you are done.
Oct 06, 2010 | Sharp FO-4400 Fax
Hi, when i start a new game in couple of games my display crashes, and shows paralell vertical lines and some brownish background... but the windows is still running in the background, but i can only turn...
Cardinal Rule 1
NEVER PLAY GAMES ON YOU MACHINE....
Cardinal Rule 2
If you insist to play games....go to a galeria and use the games video machine there.....
a few $ spent there will save your laptop....
Laptops are not ment for playing heavy games that require strong graphic card and heavy RAMs...
Dec 10, 2009 | Dell Inspiron 1501 Notebook
Can anyone please tell me if my video card is a capture card? Nvidia Geforce 6200 thanks joe
Tech Specs CineFX 3.0 Shading Architecture
  • Vertex Shaders
    • Support for Microsoft DirectX 9.0 Vertex Shader 3.0
    • Displacement mapping
    • Geometry instancing
    • Infinite length vertex programs
  • Pixel Shaders
    • Support for DirectX 9.0 Pixel Shader 3.0
    • Full pixel branching support
    • Support for Multiple Render Targets (MRTs)
    • Infinite length pixel programs
  • Next-Generation Texture Engine
    • Up to 16 textures per rendering pass
    • Support for 16-bit floating point format and 32-bit floating point format
    • Support for non-power of two textures
    • Support for sRGB texture format for gamma textures
    • DirectX and S3TC texture compression
    • Full 128-bit studio-quality floating point precision through the entire rendering pipeline with native hardware support for 32bpp, 64bpp, and 128bpp rendering modes
64-Bit Texture Filtering and Blending
  • Full floating point support throughout entire pipeline
  • Floating point filtering improves the quality of images in motion
  • Floating point texturing drives new levels of clarity and image detail
  • Floating point frame buffer blending gives detail to special effects like motion blur and explosions
Intellisample 3.0 Technology
  • Advanced 16x anisotropic filtering
  • Blistering-fast antialiasing and compression performance
  • New rotated-grid antialiasing removes jagged edges for incredible edge quality
  • Support for advanced lossless compression algorithms for color, texture, and z-data at even higher resolutions and frame rates
  • Fast z-clear
  • High-resolution compression technology (HCT) increases performance at higher resolutions through advances in compression technology
UltraShadow II Technology
  • Designed to enhance the performance of shadow-intensive games, like id Software's Doom 3
TurboCache Technology
  • Shares the capacity and bandwidth of dedicated video memory and dynamically available system memory for optimal system performance.
PureVideo Technology
  • Adaptable programmable video processor
  • MPEG video encode and decode
  • High-definition MPEG-2 hardware acceleration
  • High-quality video scaling and filtering
  • DVD and HDTV-ready MPEG-2 decoding up to 1920x1080i resolutions
  • Dual integrated 400 MHz RAMDACs for display resolutions up to and including 2048 × 1536 at 85Hz
  • Display gamma correction
  • Microsoft® Video Mixing Renderer (VMR) supports multiple video windows with full video quality and features in each window
Advanced Display Functionality
  • Dual integrated 400MHz RAMDACs for display resolutions up to and including 2048x1536 at 85hz
  • Dual DVO ports for interfacing to external TMDS transmitters and external TV encoders
  • Full NVIDIA® nView™ multi-display technology capability
Advanced Engineering
  • Designed for PCI Express x16
  • Support for AGP 8X including Fast Writes and sideband addressing
  • Designed for high-speed GDDR3 memory
  • Advanced thermal management and thermal monitoring
NVIDIA® Digital Vibrance Control™ (DVC) 3.0
  • DVC color controls
  • DVC image sharpening controls
Operating Systems
  • Windows XP
  • Windows ME
  • Windows 2000
  • Windows 9X
  • Macintosh OS, including OS X
  • Linux
API Support
  • Complete DirectX support, including the latest version of Microsoft DirectX 9.0 Shader Model 3.0
  • Full OpenGL support, including OpenGL 2.0
GeForce 6 Series GPUs Features Comparison:
Feature GeForce 6800
Models
shim.gif GeForce 6600
Models
shim.gif GeForce 6200
Models
w/Turbocache
shim.gif Microsoft® DirectX® 9.0 SM 3.0 SM 3.0 SM 3.0 SM 3.0 Graphics Bus Technology AGP 8X/PCI Express AGP 8X/PCI Express AGP 8X/PCI Express PCI Express NVIDIA® Intellisample™ Technology 3.0 3.0 3.01 3.01 NVIDIA® SLI™ Technology X2 X2 n/a n/a NVIDIA® PureVideo™ Technology X3 X3 X3 X3 NVIDIA® TurboCache™ Technology n/a n/a n/a X4 64-bit Texture Filtering and Bending X X n/a n/a Effective Memory Interface 256-bit 128-bit 128-bit 128/64-bit Memory GDDR35 and DDR GDDR35 and DDR DDR DDR Process 0.13 micron 0.11 micron 0.11 micron 0.11 micron RAMDACs 400 MHz 400 MHz 400 MHz 400 MHz
1. GeForce 6200 models do not include compression technology.
2. NVIDIA SLI: Available on SLI-certified versions of GeForce 6800 Ultra, 6800 GT, 6800 GS, 6800, 6800 XT, 6800 LE, 6600 GT, 6600, and 6600 LE PCI Express GPUs only.
3. Features may vary by product. Some features may require additional software.
4. Available on select GeForce 6200 models only.
5. GDDR3 - GeForce 6800 Ultra, 6800 GT, 6800 GS, and 6600 GT only.
Nov 20, 2009 | Nvidia GeForce 6200 AGP Graphic Card
World at war problems UBYTE4N vertex data
Many computers do not come with a dedicated graphics card, which Call of Duty will require. If you don't have a dedicated graphics card installed, there is no way to play a game that requires it.
The good news is that most computers can be easily upgraded with a new graphics card, and you can play more advanced games. For more information about what would be compatible with your system, you might want to call the Upgrades or Tech Support department of the company that made your computer, or post more detailed information about it here and we can post a walkthrough.
Jul 21, 2009 | Microsoft Xbox 360 Console
TrackMania Sunrise wont start
first check if the game is compatible with your windows
secondly make sure the graphics needed by the game does not exceed the size of your graphics card
thirdly,check if the speed of the game is not higher than your processor speed
after doing this,re-install the game again and retry it agian
note that if your graphics card and processor speed does not meet the requirements of the game,your pc will freeze while trying to open the game.
thank you for contacting us with your problems
Feb 12, 2009 | Enlight Interactive TrackMania Sunrise for...
My card does not support vertex shader!
yes so you cant play any games that require vertex shader....
try to get a card that supports it then...!!!
Feb 05, 2009 | AB Soft Computers & Internet
Determining the equation of the parabola
V (2,0) and Focus (2,2)
since the focus is 2 units above the vertex, the parabola opens upward
vertex (h,k)
a is the focal length (distance between the vertex and the focus)
a = 2
(2 units above the vertex)
(x-h)^2 = 4a (y-k)
(x-2)^2 = 4(2) (y-0)
x^2 - 4x + 4 = 8 (y)
x^2 - 4x + 4 = 8y
x^2 - 4x - 8y + 4 = 0
**Answer: "(x-2)^2 = 8 (y)" or in expanded form "x^2 - 4x - 8y +4"
Nov 18, 2008 | Super Tutor Trigonometry (ESDTRIG) for PC
Video Game Consoles & Games Logo
138 people viewed this question
Top Nadeo Video Game Consoles & Games Experts
James Wishart
Are you a Nadeo Video Game Console and Game Expert? Answer questions, earn points and help others
