Question about Kenmore Ovens
I have the Kenmore electric double wall oven model # 911.47822100 (made by GE, I found the GE part# WB27T10295 on the touch control panel). I was getting the FO code. I found the answer here in FixYa where a few people said cleaning off the ribbon cable that comes out of the touch panel and inserts into the oven control board will fix the FO code problem. The problem I have is the plastic end on the ribbon cable that inserts into the board is broken. It is broken right down the middle. How do I fix this? DoI have to order a whole new touch control panel for just under $300?
    Champion:
  • 202 Answers
Afraid so if you can not soder it
Posted on Mar 16, 2011
What is a fo code on ge doulble wall oven
It is more than likely the touch pad is bad. It could be the electronic control or worst case both. Touch pads are notorious for giong bad. i would look there irst.
Oct 07, 2014 | GE Profile JTP56 Electric Double Oven
Ge double oven f1 error model jkp55wot1
F-1 error code.
Sometimes one or more buttons on the touch panel "get Stuck"
Nothing you can do to reset them, Good Luck.
Many times it means the touch panel needs to be replaced.
Jul 09, 2014 | GE Profile JTP56 Electric Double Oven
Double wall oven broiler goes off by itself f7 comes on light bottom oven goes on and off by itself whole panel will not operate and then will--serviceman was in said it is the panel ya think??
it could be the touch panel or the computer board,the model number you gave isn't the full model number like 10 different models came up,next time get the number off of the machine not the book,if this is a newer machine you can push the clear/off pad, unplug the touch panel ribbon for a minute or two,if the code comes back it's the computer board,if it doesn't come back it's the touch panel.he must have pulled out the tech sheet and showed you what it said for an f7 error code and if he said it's the panel he must have done this test.
Apr 18, 2011 | GE JRP24 Electric Double Oven
Our monogram double wall oven has a f7 code on the control panel. None of the buttons appear to be working, except clear, which clears the code. Then still no buttons work, and the f7 code comes back. What...
It's most likely that the error code you are seeing is F1, not F7. F1 is a code for 'stuck touch pad'. You will need to replace the clock/ERC or the touch pad (or both).
Feb 28, 2011 | GE Monogram ZET3058SHSS Stainless Steel...
Ge double wall oven, model number jkp26gotibb has an f1 error code. Part is no longer available. Is there any other way to fix this problem with out replacing the whole oven.
F1 touch pad / ERC test This simple test will help determine
whether the ERC (Electronic Range Control or Clock) or the touch pad is
defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single
assembly, in which case this test is not necessary. Simply replace the ERC
(Clock).
Warning: If you feel in any way uncomfortable performing this test or
making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound)
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Dec 16, 2010 | GE Built-In 24" Double Electric Wall Oven
My start button on my kenmore built-in oven w/microwave won't wor
my kenmore model number 911-47699100 oven doesn't work. Everything except the oven and broil works--cleaning, all timers, start button, etc. All that happens when you push start is about every 30 seconds, two relays can be heard making and breaking kind of like a click then immediately a clack. No error codes appear. Replaced sensor but that didn't work. Any help would be appreciated.
Mar 30, 2009 | GE JKP30WMWW 27" Built-in Single Electric...
GE Profile JT952 Touch Pad Button Issue
Try this link
http://www.fixya.com/howto/h155060-dreaded_f7_error
Mar 28, 2009 | GE Profile JT952 Electric Double Oven
Top oven doesn't heat.
We had this same problem in our lower oven and found the solution the night before Thanksgiving. With 26 people coming for dinner, I desperately need both ovens. (Turn off the breaker for the oven before you do this.)
My husband took the control panel off of the upper oven and found a wiring diagram. In the text, it said there was a manual reset for each oven in the access panel for each one. He opened the access panel for the lower oven and found the reset button in the middle of that area. He said it was a black circle with a red button in the middle. After reseting, we turned the breaker back on and everything works great!!
Nov 23, 2008 | GE Profile JTP56 Electric Double Oven
Ovens Logo
174 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
