Question about Heavy Duty DeWALT DW304PK DW304P HeavyDuty 10A Reciprocating Saw
How do I remove a broken blade from a dw304 saw??
    Sergeant:
    Champion:
  • 250 Answers
Unloosen the blade and You could try holding a strong magnet against a screwdriver and touch the blade of the screwdriver to the broken blade and pull it out.
Posted on Mar 16, 2011
How do I remove blade that's broken off in a Skil 9216 reciprocating saw?
Turn the release as far as it will go, then tap on something blade down till it emerges.
Aug 03, 2014 | Skil 9216-01 9.0 Amp Variable Speed...
I need the size of set screw used with the Dewalt DW304 Recip saw
If you are referring to item 21 on this diagram it is 1/4-28x3/8.
DeWalt DW304 diagram
Jun 27, 2012 | Dewalt Saws
Broken blade in dewalt sawzall
Remove broken blade, install new one. These blades don't change themselves, unfortunately.
May 06, 2012 | Dewalt Dw938 18v Reciprocating Saw Sawzall...
How much is a good used DW304 worth
If you are trying to sell it: In the neighborhood of $40-50 used. If you are going to pawn it: $15-20.
Jun 15, 2011 | Dewalt DW304PK reciprocating saw kit with...
How to change dewalt DW304 blade
In short, with as little force. 1) use a hex key to remove a small bolt at the tip of the reciprocating blade holder, right at the base of the blade. the blade should now wobble, but you may not be able to pull the blade free. 2), turn the saw so that you are looking from the front, blade pointing right at you. now slide the blade as far to the LEFT as possible. this should be the position that the blade clears the little round retaining nub on the left side of the shaft that fits through the hole on the blade and pulls free. sometimes the blade is too thick or is bend so this is difficult. 3) try yanking or wiggling while the blade is slid as far left as possible. i just had to pry / knock the blade free with a screwdriver and hammer. there is a narrowing at the very base of the blade before it enters into the mounting hole, and i just used a screndriver wedged in there and hit iy with a hammer WHILE having the blade slid over into the left position. 4) to make it easier for yourself the next time, use sandpaper to remove the paint of the base of the new saw blade, so you will be able to easily pull it free.
Nov 27, 2010 | Heavy Duty DeWALT DW304PK DW304P HeavyDuty...
Dewalt DW304 stopped working while sawing 1 1/2'' branch. What could be problem?
the breaker box started ticking then the red light went out. Is there a fuse in the box?
Jan 02, 2010 | Dewalt Saws
Solution for "changing blades on a milwaukee miter saw
Have you removed the old blade yet?
The blade lock my be broken off -- it should be a button on top of the motor.
This saw has left hand threads -- turn clockwise to loosen the bolt/nut.
If you can't find the blade lock, lower the saw onto a piece of wood llike a 2x4 to keep the blade from turning.
May 02, 2009 | Milwaukee Tool 10" Magnum Compound Miter...
Broken blade on a porter cable 737 tiger
This is a jigsaw miscatagorized as a chainsaw. Do you have a blade big enough to drop 24" tree? We don't answer jig saw questions in the chainsaw section.
Mar 30, 2009 | Porter Cable Variable Speed All-Purpose...
How does one remove a broken blade from a Bosch rs20 blade holder
twist the collar around where the blade fits in the saw. It will lock in the open position. When you insert the new blade, do so firmly until the collar releases locking the new blade in place. Give a tug at the blade to make sure it is locked in.
Nov 27, 2008 | Bosch RS20 13 Amp Reciprocating Saw
Heavy Duty DeWALT DW304PK DW304P HeavyDuty 10A Reciprocating Saw Logo
442 people viewed this question
Top Heavy Duty Saws Experts
Tom Chichester
ray gallant
Are you a Heavy Duty Saw Expert? Answer questions, earn points and help others
