Question about NEC DT730 Phone
If there is a extention # 112 and it will transfer only by dailing the number not when i hit the transfer button.....how can i reprogram it to transfer with out dailing the number????
How to make out going calls iphone?
Insert sim to iphone ..If its factory unlocked it will detect sim ..if not it has to be unlocked ..after inserting go to dail pad ..it has a logo of phone and dail the number you want to dail..then press the dail button below on the screen
Aug 18, 2014 | Apple iPhone Cell Phones
Every extention on the console is showing with the red led light, as if the lines are busy. Therefore I cannot transfer calls, when in actual fact, the lines are not busy
ouch, sounds bad...
possibilities~
1) everyone has DND turned on if so have them disable their call forwarding entirely (intercom*7100)
2) your buttons are all suddenly programmed wrong, reprogram them to the correct extensions
(press "PROG" then the button you want to program, press " 1 " then the extension number, then enter)
3) major error with the system, have a serviceman come out and take a look
Jan 04, 2011 | Panasonic KX-T7630 Corded Phone
Push numbers whilst talking on phone
1. FYI, when your call is dailed through successfully - please pay attention as there are two instructions on the screen. It tells you to press which button for dailing and which to press to unlock the screen.
2. To answer your question: On the left hand side of the phone, there are 3 buttons. Press the button at the bottom below the volume up & down buttons. The dailing screen should come up.
This button is also used as a shortcut for changing profiles quickly in the main screen.
Jan 22, 2010 | LG Prada KE850 Cellular Phone
How do I fax multiple numbers at once?
You have to setup a group Dial.First setup yur one touch dail numbers under user mode-Tel registration,one touch speed dails.Leave at least 1 dail open and program it to a group dail number.Under usermode-tel registration select group dail and select your group from the one touch buttons.
Dec 14, 2009 | Canon LaserClass 720i Plain Paper Fax
MY TRANSFER BUTTON TRANSFER TO LAST NUMBER DAILED
sounds like the programming for that button was changed to last number redial. To re- program the button, press feature *3, press the button labeled transfer, and press feature 70 (transfer).
Sep 18, 2009 | NorStar M7324 Telephone
DKT 2020 ST
The phone needs to be fowarded to voice mail. go to the phone press intercom# 604, dial the voice mail extension number , press the speed dial button, enter 16 for time then press redial
Sep 15, 2008 | Toshiba DKT-2010 Corded Phone
Programing numbers to dail
for one touch keys. press the fax button
1---function-7-4-start-1-1-9-start-1"qwerty key board"-start-stop
2---function-7-2-start-1"one touch"-press the speed dial you want to program"- enter number-start-enter name start-((do another one or hit stop))
if its name search let me know
Jul 18, 2008 | Panasonic DP190 All-In-One Laser Printer
No picture
Try a "hard restart". which simply means unplugging the power cord of the TV, and replugging it after 4 hours have passed. This technique reprograms the electronics, to a certain extent.
You can also visit the manufacturer's website or call their tollfree number for problem solving info.
Hope these suggestions help you out.
Jun 30, 2008 | Insignia NS-30HTV 30" TV
Want to get my nokia 1110i security code
you need to give me your IMEI number on the phone...you can press the #06# to show your imei number
Jun 22, 2008 | Nokia 1110i Cellular Phone
NEC DT730   Phone Logo
16 people viewed this question
Top NEC Lands Phones Experts
Craig Butler
Craig Butler
Oloyede Monsuru
ray gallant
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
