Question about Samsung Televison & Video
The tv screen goes blank then flickers then looses its channels, this continues for about an hour then everything seems normal. Could this be a dry solder joint, as once the tv is nice and warm the problem stops? If this is the case, what is the most common component to do this and is worth my while fixing it or resign the set to the loft?
  • 916 Answers
I would check the power supply board for dry joints and bulging capacitors (capacitors with domed tops).
Posted on Mar 16, 2011
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
I have a RCA L32HD31YX12 TV. The TV works fine for a half hour and then the screen flickers and goes black. The sound continues. If I turn the set off for a half hour, it works again for another half
You have answered your own question, someone needs to open it and find a loose plug or broken solder connection--if it reacts to being tapped on that is the issue- a physical problem inside.
Dec 05, 2012 | RCA Televison & Video
My alba lcd22advd keeps flickering while on fav channel
check for a dry joints at the inverter board for the screen back light, which may have loose contact.
Aug 10, 2012 | Alba LDVD1538WDCH LCD TV
Phillips 47pfl3603d blank screen with sound
if the Tv have back light the problem is t-con if not the problem is inverter
Jun 06, 2012 | Philips 47PFL3603D LCD TV
Samsung tv power cycles when I get to higher channels pass 40. I attempt to change channel. Doesn't change and then front led blinks, tv screens goes blank, led flashes again and then screen is normal. I'm...
We have a similar problem when changing channels/surfing, the TV will begin to power cycle, until you unplug THE CABLE TV input, then it will turn on again and stay on as you rehook the cable and change channels....till it decides to do it again, DTV channels seem to trip it up, but not sure....if I leave it on the same channel it will run for days. Yep and the cable TV is grounded outside
Dec 19, 2009 | Samsung LN40A630 40 in. LCD TV
Dell 3008WFP monitor cut out after 2 or 3 hours use
sounds like a over heating problem, if there is any fans make sure they are tunring , make sure no vents are coverd on back, hover any dust from any of these areas. if continues you might be looking at a repair job.
Nov 29, 2009 | Dell 3008WFP Monitor
TV SREEN GOES BLANK, BUT AUDIO CONTINUES NORMAL,
Try unplugging for 36 hours. I had the same problem but with no sound and picture
Mar 03, 2009 | Sony KP-53HS10 TV
2 problems- 1-gasket is hanging loose on top of protection screen. 2- TV goes blank and I lose the picture and sound only on some channels at 9:00pm every night
unscrew the screws along the sides and top at back. gently lower screen forward and look inside--you should see the gasket--reattach it or remove it...I just removed it after staring at it for a year or more
Sep 10, 2007 | JVC AV-48P575 48" Rear Projection...
Televison & Video Logo
62 people viewed this question
Henry  Thomas
Henry Thomas
