Question about Microsoft Windows Vista Home Premium Edition for PC
How to fix the unnecessary computer lock.. my computer locks up frequently during my computer works
  • 30 Answers
I would suggest upgrading to Windows 7 Home premium. You can do a direct upgrade. Find simple to follow instructions here: http://www.intowindows.com/how-to-do-vista-to-windows-7-upgrade/
Posted on Mar 16, 2011
Upon exiting car with key in ignition and off, frequently all doors lock automatically
Jack, Dealership should be able to reprogram door lock program in computer to some other setting or least turn off auto door locks.
Apr 15, 2016 | Cars & Trucks
What could be causing lock up to kick on & off while driving down the highway?
sounds like your lock up converter is kicking on and off. a shift kit could help. just take it to your transmission shop and be done with it.
May 10, 2014 | 1999 Dodge Ram
Frozen screen when hot
- Stop Overclocking your CPU.
- Make sure your Heat Sink is placed properly above the processor.
- Clean the Processor fan, Heat Sink and other peripherals.
- Use High Speed fans.
- Use CPU Heat Sink Paste in the processor.
- Fix OS registry with reliable program like I always use Reginout.
- Shut down your computer atleast two hour a day.
Most of the time, PC starts running slow and freezing by lots of reasons. Corrupt registry, unnecessary applications, as well as too many start-up items would be the major reasons contributing to this problem. Many PC users simply utilize PC yet never consider how to maintain and optimize PC performance. I would suggest you to download any reliable program to fix registry, to manage unnecessary applications & start-up items like am using Reginout since 2011. Many programs are available in market which can perform these steps, but don't believe on free products. Now its up to you. :-)
Good Luck.
Nov 12, 2013 | Dell Latitude E6510 Laptop
Num lock
If you use the number pad frequently during your daily computer usage, you may want to have the "Num Lock" key enabled when the computer starts up.
You can enable Num Lock automatically in two different ways: one involves modifying a value in the registry and the other requires you to create a small script in Notepad.
Activate Num Lock Through the Registry
Enter the registry and navigate to "HKEY_CURRENT_USER\Control Panel\Keyboard\." Double-click on the value labeled "IntitialKeyboardIndicators," which has a value of 0,1 or 2.
Change the value to "2" to turn Num Lock on after logon, "0" to turn Num Lock off after logon and "1" to disable Num Lock.
Create a Num Lock Script
Configure a script that runs to automatically change the Num Lock state.
Depending on where you place the script, you can activate the script for a single user or all users on the computer. Open Notepad and paste the following code
"set WshShell = CreateObject("WScript.Shell")
WshShell.SendKeys "{NUMLOCK}"
Save the file as "numlock.vbs," including the quotes to change the notepad file to a script.
Paste the file in the directory "Documents and Settings\All Users\Start Menu\Programs\Startup" to enable Num Lock for all users by default.
For a single user, copy it to their startup folder instead of All Users.
Enter the BIOS
Enter your computer's BIOS before Windows boots up to change the integrated Num Lock settings.
Depending on your motherboard manufacturer, different key combinations allow you to access the BIOS.
Common keys include "F1," "F2," "Del," "ESC" or "F10."
Consult your computer's documentation for specifics.
Navigate through the basic or advanced options until you find a section dedicated to enable or disable Num Lock on boot.
Enable in Linux
Linux is an alternate operating system.
While the BIOS method may work for Linux, you can also change the process through the options if using KDE Linux.
Navigate to "Control Panel" and click "Peripherals." Select "Keyboard" and select the option "Turn on" under the heading labeled "NumLock on KDE Startup."
How to Set the NUM LOCK State at Logon in Windows XP
http://support.microsoft.com/kb/314879
How do I enable the NUM LOCK key for the logon screen
http://support.microsoft.com/kb/154529
May 15, 2013 | Compaq Computers & Internet
CAPS WORK BUT LIGHT DOES NOT COME ON
Step 1:
If you use the number pad frequently during your daily computer usage, you may want to have the "Num Lock" key enabled when the computer starts up. You can enable Num Lock automatically in two different ways: one involves modifying a value in the registry and the other requires you to create a small script in Notepad.
Activate Num Lock Through the Registry Enter the registry and navigate to "HKEY_CURRENT_USER\Control Panel\Keyboard\." Double-click on the value labeled "IntitialKeyboardIndicators," which has a value of 0,1 or 2. Change the value to "2" to turn Num Lock on after logon, "0" to turn Num Lock off after logon and "1" to disable Num Lock. Create a Num Lock Script Configure a script that runs to automatically change the Num Lock state. Depending on where you place the script, you can activate the script for a single user or all users on the computer. Open Notepad and paste the following code "set WshShell = CreateObject("WScript.Shell") WshShell.SendKeys "{NUMLOCK}" Save the file as "numlock.vbs," including the quotes to change the notepad file to a script. Paste the file in the directory "Documents and Settings\All Users\Start Menu\Programs\Startup" to enable Num Lock for all users by default. For a single user, copy it to their startup folder instead of All Users. Enter the BIOS Enter your computer's BIOS before Windows boots up to change the integrated Num Lock settings. Depending on your motherboard manufacturer, different key combinations allow you to access the BIOS. Common keys include "F1," "F2," "Del," "ESC" or "F10." Consult your computer's documentation for specifics. Navigate through the basic or advanced options until you find a section dedicated to enable or disable Num Lock on boot. Enable in Linux Linux is an alternate operating system. While the BIOS method may work for Linux, you can also change the process through the options if using KDE Linux. Navigate to "Control Panel" and click "Peripherals." Select "Keyboard" and select the option "Turn on" under the heading labeled "NumLock on KDE Startup."
http://support.microsoft.com/kb/314879 How do I enable the NUM LOCK key for the logon screen http://support.microsoft.com/kb/154529
Feb 25, 2013 | HP Pavilion Computers & Internet
Slam on brakes i feel a vibration in the pedal
This may be a silly response but are you sure it is not your ABS? This is the Anti-lock Braking System that prevents your tires from locking up when you slam on your brakes during an emergency. This helps prevent you from losing control of your vehicle. If any of your tires lock up your ABS will kick in and you will know this when your brake pedal starts to more or less vibrate. Sometimes when this happens your ABS light will come on your dash during the time your ABS is in use. This is a normal response and will happen more frequently when on icy, wet, or unpaved and muddy roads.
May 12, 2011 | 2004 Ford Explorer
My dell inspiron 1720 locks up frequently - this problem started just yesterday I've used CC Cleaner and tried to do a complete virus scan using Kaspersky software - computer locked up at 7% into the...
Try running these scans in Safe Mode.
Keep pressing F8 on startup, and choose 'Safe Mode' from the list that appears.
If you still find it locking up during scans, you may have a hardware problem that needs fixing.
Regards.
Apr 26, 2011 | Dell Inspiron 1720 Notebook
Internet explore has encountered problem needs to close..sas..i prees to report l losing pages
download malawarebytes its free, update and run it
your browser hass been corrupted
Sep 01, 2009 | Toshiba Satellite A100-S8111TD Notebook
Beeper alarm won't stop & Power locks going on/off during driving
see if going back the truck and resets the alarm on this does on the 96 of mine, Please give me thumbs up if does
Jul 09, 2009 | 2004 Jeep Liberty
I was being nosey hitting buttons and now my laptop is locked
The I button is another one of those unnecessary things PC makers do to try to be more convenient. This one is a programmable button for your favorite or frequently used programs.
Use F8 to boot to Safe mode, then:
Using the Keyboard and Touch Pad In Microsoft® Windows® XP
  1. Click the Start button, and then click Control Panel.
  2. Under Pick a category, click Printers and Other Hardware, click Keyboard, and then click the AccessDirect tab.
  3. Click Help, and follow the instructions.
In Windows 2000
  1. Open the Control Panel, and then double-click the Keyboard icon.
  2. Click the AccessDirect tab in the Keyboard Properties window.
Jun 10, 2009 | Dell Latitude C640 Notebook
Microsoft Windows Vista Home Premium Edition for PC Logo
65 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
