I have a daytex tv and the remote is not working, and when I manually change the channels from the side of the tv I cannot get channel 3. Is there anything I could do to get it to change the channel 3, so that I could get my cable tv. Is there a code that I could use to enter into my universal remote.. My email address is eamacl@cogeco.ca
    Problem Solver:
  • 18 Answers
There is no Daytek code for a universal remote, but I would try the codes for their parent company,
Daewoo. Those are: 011,019,027
Please let me know if this was helpful by rating my suggestion.
Have a great day!
Posted on Mar 16, 2011
    Problem Solver:
  • 5 Answers
No picture no sound the lamp turn on 3 minus and shurtdown .Samsung HLD 5067w
Posted on Mar 21, 2011
I have a Symphonic model ST420FF along with a Phillips Universal remote. The tv used to work oerfectly but then the channel changed (we have a charter cable box hooked up). Now when I try to change the...
Can you use the menu buttons on the TV to navigate to the control panel to automatically or manually add channels? That would be a start to make channel 3 exist again.
Sep 20, 2014 | Televison & Video
I don't have a remote control for my RCA TV and it's on channel 2. It needs to be on channel 3 so that It's compatible with my cable box. How do I change the channel without a remote to channel 3. It
U should have a menu button on your tv.If so try to find the channel setup option if you find this you should b able to manually go through your channels to add & delete the channels you want.If not you will have to go out a buy a universal remote.Make sure that it is compatibl to your tv.They should be a list on the back of the remotes pack stating all the brands that the remote is compatible with.I think you should be able to get one for unde 5 dollars.in the pack it should have an instruction manual.some tvs u can set up very easily & some you might have to keep putting in different codes until it works.Hole this could be some help to you.Good luck.
Apr 19, 2013 | Televison & Video
TV is on one channel and will not work with remote or allow me to change channells from side of tv
I've run into this same issue. Although not a complete fix, I was able to program the tv with a basic universal remote. Try using the Goldstar remote codes. While I'm unable to use the channel buttons, I can change channels manually and turn the tv on/off and use the volume button. Again, not a fix, but a work around for now.
Jun 25, 2011 | Element Electronics FLX2211B 22 in. LCD TV
While moving my parent's Curtis Mathes Cm19001 TV produced in 1999, I touched the channel button which took the TV off of channel 3. We've tried to use the channel buttons to return to channel 3,...
I have one of this tv model too.Just used a RCA component cables like Y,R,W hook one side to the tv Video IN INPUT holes and the VCR the other end of the cable to VCR Video OUT INPUT holes.Now just pushes a channel manual button up or down a couples for the tv go into VIDEO Mode.Play the dvd player it will work.Or try Remotes.com to buy a tv original remote.Return the universal remote.
Jun 18, 2011 | Curtis-Mathis CM19011 TV
My universal remote went out and somehow the tv-a Sansui-got switched from channel 3. How can I get it back to channel 3 so the converter will work? I tried changing channels manually at the tv but it...
Look in the owner's manual for instructions on having the TV scan channels. Make sure the converter is on before starting the scan. If that doesn't work, you'll have to buy or borrow a universal remote to take care of it (enter 3, 03 or 003 on the remote control). This will happen every time you remove power to the set, whether it is unplugged or you have a power failure, so start saving up for a new remote control.
Dec 07, 2010 | Sansui 27" TV
I need to reprogram my rcr317w remote contact with manual
Turn the tv on. Hook up your components, turn them on, go in to tv menu and auto program the stations. It will see that there is a signal on channel 3 and lock it in for you.
Jun 30, 2009 | Universal Remote Control DIRECTV Universal...
Can't change channels. don't have remote. need to get channel 3 for cable
Use the buttons located on the TV to switch the channel to 3 or buy a universal remote from any local supermarket/drugstore. Or if it's not a rush, get the original from Ebay based on yor TV model
May 21, 2009 | Samsung TV Remote Control
Can't change channel using the remote or buttons on tv
Simple Fix
I had the same problem, couldn't change the channels with the remote or on the side of the TV. This was for a Vizio 37"
Here is the fix:
1. Turn on TV
2. With remote, press the Menu Button
3. Go to Antenna Menu
4. Select Auto Search
Let it search, it could take several minutes. It may not finish to 100%, mine got stuck at 79% for 10 minutes. It's fine if that happens, go ahead and cancel.
5. It should be done, your remote will work perfect along with the TV channel buttons.
Sep 07, 2008 | Vizio L32 32 in. LCD HDTV
Remote not working on TV
Try programming with Code Search:
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Jun 13, 2008 | Philips Televison & Video
Unable to channel to channel 3
If you take a working remote, point it at the TV and hit "3", then "ENTER", does the set go to channel 3?
Sep 04, 2007 | Sony FD Trinitron WEGA KD-27FS170 TV
Televison & Video Logo
531 people viewed this question
Top Televison & Video Experts
Electro Med Services...
