Question about HP Laserjet CM2320nf All-In-One Color Printer
The CM2320nf printer has random 1/2" wide black
  • HP Master
  • 1,915 Answers
Really sounds like a defective cartridge or bad contact. Have you changed any of the toners recently? If so, try another cartridge of the color that you just changed.
Posted on Mar 17, 2011
Heavy black stripe on back side of every printed page
This is probably due to miss alignment, there is an option of test page which will be scanned to allign the cartridge, if ur's a all in one printer. This test page is printed at the first time and scanned instantly for first time operation.
Thankyou
Mar 20, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Hp cm2320nf prints 2 black lines vertical all the way down pg 1/2' apart
Remove cartridge observe on cartridge drum finds any vertical toner line? replace cartridge, as well as check all cartridges same manner...if found replace them..If its only on copying: clean flat bed both glasses..with glass cleaner..
Feb 02, 2012 | HP Laserjet CM2320nf All-In-One Color...
Lines on print. There's are three lines on picture print only. Can't see the line on document. It's about 1/4 inch wide and going throught top to bottom.
Have ou gone into your menus. Into troubleshooting, then image quality.
You will want to run both the eliminate light stripes and eliminate smears procedures. that will purge the print head, blow air through the jets and hopefully resolve the problem. I do believe the 8550 has a Jet Substitutin procedure where you can do a workaround and make other jets make up for the light areas.
here are some directions, Will forward more
  1. Press the [Up] or [Down] arrow button on the Control Panel to select [Troubleshooting] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Print Quality Problems], and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Troubleshooting Print Quality Page], and then press the [OK] button.
  4. Evaluate the 'Light Stripes Test' page for missing printhead jets, such as missing Cyan, Magenta, Yellow or Black color bars. The 'Light Stripes Test' page is the last page of the Troubleshooting Print Quality Page that printed.
    WARNING: To avoid injury, do not touch the sharp metal strip attached to the clear rubber wiper blade in the Maintenance Kit.
  5. Use a clean lint-free cloth or a new paper coffee filter to gently clean the maintenance unit's clear rubber wiper blade, use only a wiping motion across the entire length of the wiper blade, and then empty the waste tray. A dirty maintenance kit wiper blade can cause white lines and weak or missing printhead jets.
  7. Repeat step 3 to reprint the Troubleshooting Print Quality Pages. If there are no missing or partially missing color bars then the print quality problem has been resolved. If there are missing or partially missing color bars then the printhead cleaning procedure will need to be performed. Continue with the next section.
To clean the printhead using the basic eliminate light stripes procedure:
  3. Press the [Up] or [Down] arrow button to select [Eliminate Light Stripes], and then press the [OK] button.
  4. Press the [Up] or [Down] arrow button to select [Basic], and then press the [OK] button. The printer will perform a head cleaning, which will take about five minutes. The printer will then print a cleaning page and a light stripes test page.
  5. Repeat steps 1 - 4 one more time. If there are no weak or missing jets then the print quality problem has been resolved. If there are still weak or missing jets after two basic light stripe cleanings, continue with step 6.
    NOTE: Do not try the Advanced Eliminate Light Stripes Cleaning mode without performing two basic cleanings first.
    To clean the printhead using the advanced eliminate light stripes procedure:
  6. Press the [Up] or [Down] arrow button to select [Advanced], and then press the [OK] button.
  7. Select the missing jet color and number. If necessary, check the light stripes test page to determine the color and jet number of the missing jet.
    NOTE: Only perform the advanced light stripe cleaning once. If weak or missing jets still persist, continue with step 8.
  8. Print the Troubleshooting Print Quality Page. Evaluate the Light Stripes Test page for missing printhead jets, such as missing Cyan, Magenta, Yellow or Black color bars. If necessary, perform the basic eliminate light stripes procedure one more time. If the Advanced Eliminate Light Stripes procedure does not resolve the weak or missing jets, perform the Enable Jet Substitution Mode. See the Related Items below.
Feb 05, 2010 | Xerox Phaser 8550DP Printer
Slightly light streaks, not stripes.
On the screen you need to scroll to troubleshooting and then to eliminate light stripes, and eliminate smears. Run those a couple of times each.
Then check the maintenance kit.
Dec 19, 2009 | Xerox Phaser 8560DN Laser Printer
Repeating wide smudgy horizintal line across my printed pages
I had the same problem, replaced the PCR in the cartridge, the small black drum that pre charges the drum and erase the old image.
After that print was all back ok.
Regards
Dec 11, 2008 | HP Q2613A OEM Genuine Black Laser Toner...
1 inch black stripe down edge of page
can you try to post a copy of what you see wrong . and try to do an internal printout " function-6-4-start- under the fax button. "
Nov 21, 2008 | Panasonic DP-150FX Laser Printer
Possible Print Head Issue
Select the Jet Substitution Mode.
  1. On the Control Panel, select Troubleshooting, and then press the OK button.
  2. Select Print Quality Problems, and then press the OK button.
  3. Select Eliminate Light Stripes, and then press the OK button.
  4. Select Jet Substitution Mode, and then press the OK button.
  5. Follow the Control Panel prompts to select the color and malfunctioning jet number indicated on the Light Stripes Test page.
Mar 25, 2008 | Xerox Phaser 8550DX Laser Printer
Dell 3100cn printing horizontal stripes
Sounds like a bad imaging drum to me...
Aug 14, 2007 | Dell 3100cn Laser Printer
HP Laserjet CM2320nf All-In-One Color Printer Logo
843 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
