Question about Hotpoint Dryers
I have a hotpoint dryer displaying f10 what does this mean
    Champion:
  • 202 Answers
Google it
Posted on Mar 16, 2011
Washer stops working and displays F6
hotpoint?
"EVO1 Washing Machines and Washer Dryers" open="0" style="2"]
  • F01 - Short circuit motor triac*
  • F02 - Motor jammed tacho detached*
  • F03 - Wash thermistor open/short circuit*
  • F04 - Pressure switch jammed on empty*
  • F05 - Pressure switch jammed on full*
  • F06 - Program selector error*
  • F07 - Heater relay stuck*
  • F08 - Heater relay cannot be activated*
  • F09 - Incompatible eeprom*
  • F10 - Pressure switch not sensing correctly*
  • F11 - Pump cannot be activated*
  • F12 - Communication error*
  • F13 - Dryer fan or dryer thermistor faulty*
  • F14 - Dryer element faulty*
  • F15 - Dryer element relay faulty*
  • H20 - Not fillings. Check tap, hose and inlet valves
  • LOCKED - Check interlock*
Aug 24, 2015 | Washing Machines
Alarm F10 is displyed , my washer/dryer doesnt
Hotpoint error code F10 is
"No cold fill. Check that the taps are on or if the drain hoses are kinked".
Has someone turned off the water supply or the isolator valve on the plumbing?
If not, you may have a faulty inlet valve on the machine.
Please drop a comment back on this thread if you require further help or guidance
Jul 21, 2011 | Hotpoint Washing Machines
My hotpoint WT960 stopped filling and displayed F10 error please help
'F10' for Indesit (Hotpoint, Ariston) decodes as 'pressure switch, check PS, wiring and module' which sounds major BUT is not uncommon in this make of machine and is often caused by poor contact between plugs/ cables and the control PC, just needing re-seating- by an engineer ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
May 28, 2011 | Hotpoint Washing Machines
My Hotpoint Ultima keeps displaying an F10 fault and doesnt spin correctly. However, if I then switch it to a rinse and spin cycle it seems to spin OK.
F10 meanswater level pressure switch not sensing correctly, there could be a blockage in the switch hose or chamber, or the switch could be faulty.
Jan 17, 2010 | Hotpoint Ultima WF860 Front Load Washer
F10 error displays
hi the error shows bcoz of ur door problem...replace the door lock and ur problem will be solved...
Jun 11, 2009 | Hotpoint Dryers
It keeps flashing f10 and now started to flash f8 aswell what dose this mean and how do i sort it ?
Could you please tell what kind of dryer it is.Else here is a link that has all hotpoint error codes.Choose your model from the list and the error and post your comments so that i can further guide you to eliminate the error.
click here for hotpoint error codes
Please do rate my solution.Good luck with the machine.
Apr 11, 2009 | Hotpoint Dryers
F10 error code on Hotpoint ctd80. How do I fix ? Thanks
remove 2nd largest panel on back of dryer then remove the heater unit (two small screws) from inside panel,on the top of this you will see two small units with wires going in and out both sides looking closer one of these units has a small hole using a pin push it down into hole this resets thermal cut out,you should hear a small click.
Feb 02, 2009 | Hotpoint TDL15 Electric Dryer
Dont know what the fault codes are for my Hptpoint Dryer CTD80
Hi.
F10 indicates that the heater is open circuit, or the thermostat is faulty, more likely to be open circuit thermostat, you should replace both thermostats.
Also make sure that you clean the filters regularly
This should solve your problem.
Nov 20, 2008 | Hotpoint Dryers
Hotpoint wt960
Full manual can be downloaded from this link
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/ultima-7kg-lcd-wm-19505771900.pdf
Technical helpline will be able to tell you what F10 means
Apr 04, 2008 | Hotpoint Ultima WF860 Front Load Washer
Alarm Code 10 - Meaning Please?
You can download the manual from this link
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/HB00503_WF840_860_865_19504206802_jan05.pdf
You will need to contact the service helpline for the explanantion of the F10 display
Dec 30, 2007 | Hotpoint Ultima WF860 Front Load Washer
Dryers Logo
51 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
