Question about Ovens
Bulb out on the microwave portion. Kitchen Aid assist says requires a service call. TO REPLACE A BULB??!! Only 1/8 inch of bulb exposed so cant even get enough grip to tell if pin or screw-in. can anyone advise me?
    Champion:
  • 202 Answers
See if top panel has screws and comes off to excess
Posted on Mar 16, 2011
HOw to replace light bulb microwave KEMS308
Unit has to be removed from wall top panels removed to replace if can live with out it great bulb is cheap labor 100-150
Jan 24, 2014 | KitchenAid Architect II KEMS308S 30"...
How to change light bulb in microwave?
Found this post on another fixya-type site: below is the link..
Here's a repeat of Kai's instructions so you don't have to scroll down. I just replaced mine and it was a snap. Just a few Phillips screws and a few tugs. No need to pull the unit completely out as you can access the bulb after it's about half way. No need to disconnect any wiring harness except pulling the bulb out of its socket. I used the 10w (G4 12V) replacement bulb from Home Depot at $6. The light is a bit brighter but there've been no problems with fuses.
1) Turn off power to the unit
2) Open the lower oven door
3) Remove the side trim screws and pull the trims down and out.
4) Remove 2 screws on the sides of the control panel.
5) Open the Microwave door. Remove the 3 screws on the Air Vent Plastic Cover on top of the microwave. You can then remove the Air Vent Cover by pushing the control panel up and pull out slightly at the bottom.
6) Remove the 4 screws on the Air Vent Plastic Cover on top of the lower oven and remove the Air Vent Cover. (You may have to remove the left under side bracket of the Microwave door temporarily just for the Air Vent Cover to clear the screw of the bracket. Re-secure the side bracket of the Microwave door panel as the front panel may fall)
7) Remove the 2 screws which held the Microwave unit in place behind the Air Vent Cover on step 6.
8) Wiggle the Microwave unit out about half way to expose the light bulb unit on top center
9) Wiring to the Control Panel will prevent you from pulling the Microwave unit out any further. And you don't want to do that as the unit may fall. Space is cramped, but working carefully with pliers you should be able to release the springs which held down the light bulb unit and change the bulb.
http://www.fixed4free.com/answers.php?id=51232
Mar 21, 2012 | KitchenAid Architect Series KEMC308KSS...
Can you explain how to replace the light bulb in my amana oven?the model number AARG7303WW
This worked like a charm ... actually it's easier than you might think. Just a few screws and a few tugs. Give it a shot.. I found a 10W (G4 style ... you'll see the difference when you get to the store) replacement bulb at Home Depot for $6:
9) Wiring to the Control Panel will prevent you from pulling the Microwave unit out any further. And you don't want to do that as the unit may fall. Space is cramped, but working carefully with your fingers or pliers you should be able to release the springs which held down the light bulb unit and change the bulb.
Feb 14, 2010 | KitchenAid KEMC378KSS Electric Double Oven
How do i replace the cooktop light bulb in my microwave oven?
I realized the light bulb was fixed using an adhesive (maybe a glue stick) that is why, I had a hard time removing the old bulb. After forcing it (and breaking the adhesive seal) I was able to replace it with a new one.
Oct 06, 2009 | GE Ovens
Delonghi microvave replacement bulb, microwave only 6 months old
I got a Delongi Mic form argos too ,model ED8525S-SBD, sounds like a similar problem to what happened to it last year. Issue is that the bulb explodes (mainly due to the very strong spring on the door I think) leaving filament lieing on the metal chassis, hence the trip switch in your fuse box trips.
Didn't manage to find a replacement bulb but at least if you remove the old bits then it will get the machine back up and running and stop the trip tripping!
Take off the top by removing the 4or 5 screws around the outer edge at the back. The bulb sits directly behind the front panel inside its own metal chassis. There is a diamond shaped black plastic flange which the 2 power wires feed onto. 2 metal lugs hold this inside the chassis. straighten the lugs and the bulb holder pulls out. Even with the bulb removed I think there was a blown fuse and I had a further issue with the turntable not turning(this feeds off the same circuit as the bulb). So maybe Argos were right - the machine only cost £80 at the end of the day!
Jan 31, 2009 | DeLonghi Ovens
Need to replace light bulb in kitchen aid microwave
KitchenAid wants $58 for the replacement bulb. I bought it for $1.99 from www.lightbulbsdirect.com and it works just fine. The Item number is Q5G412V. It is a halogen 5-watt, 12-volt bipen G-4. Replacing the bulb requires some dismantling of the microwave. At first I was nervous about removing so many parts to get to the bulb but in the end it really wasn't so bad. The only tool I needed was a Phillips screwdriver. I surfed the net a eventually found instructions left by a friendly Blogger that guided me through the whole process. KitchenAid engineers were so STUPID when they designed this microwave. It takes two hours to replace a bulb that should take 5 minutes. Oddly enough, replacing the bulb in the normal oven below the microwave oven is a piece of cake.
Jan 19, 2009 | KitchenAid KEMC308 Electric Double Oven
Can't change light bulb
yes you wilkl need to remov ethe micro from the oven mountingin order to access the light bulb (dumb-design) but no way around it
Nov 16, 2008 | KitchenAid Architect Series KEMC308KSS...
Oven light bulb
Check your email
Jun 15, 2008 | Ovens
How do i change light bulb for my oven
Here is a simpler method from the same website mentioned in solution #1:
By the way, the bulb is Osram 64405S. It's available online for about $2.00 plus shipping.
See more info. at: http://www.howtomendit.com/answers.php?id=51232
Mar 13, 2008 | KitchenAid KEMC378KSS Electric Double Oven
Microwave oven light - KEMC 307
you ll need to pull unit out to replace bulb, 2 scrws remove side trim of oven, 3 or 4 screws remove trim under micro; above oven, 2 more screws behind that grill will release micro from supportthat should free it up enoug to slide foward 6 or 8 inches( the bulb is ontop of the cavity) good luck!
Feb 25, 2008 | KitchenAid KEMC307 Electric Double Oven
Ovens Logo
69 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
