Question about Maxtor OneTouch 4 500GB External USB 2.0 Hard Drive
Hard drive has been in use for a few years now. Last week after a power failure and voltage issue with the electric utility company (Com Ed), the drive was no longer being recognized. Although the light initially flashes, upon rebooting it will stay on constantly. Secondly, the menus are not reading the install under the Computer Icon. Third, if I unplug and replug the drive in, you hear the computer say the standard alert, when hardware is disconnected or put back in, but a window does not pop up on the monitor like it previously did of for other items @ cable internet connection. Forth, ran diagnostic check through windows, and it says there is an I/O error. Fifth, ran the diagnostic program for cleaning the registry, solved all those errors, but am still not reading the external drive. I failed to back up my data on this drive, and am unable to recover and read this drive unit now. I can hear the drive running, but I cannot read this drive. The software company that provided the registry cleaner, (My Clean PC), tested and assured my registry is clean (spent about 4 hours on line with them diagnosing my computer). Their recommendation was to contact a repair service for these drives. Any further recommendations on your end?
  • 1,381 Answers
Hello dj_itachi7
Maybe it's only the electronic connection inside the box of your drive that is damaged . The USB connection is dead but you still seem to have power .
I would try to open the box ( will be lost ) and put the drive in another USB external box or connect the drive straight inside your pc if it is a desktop , using the IDE or Sata connection of the motherboard .
Regards ,
fanaudi .
Posted on Mar 16, 2011
Invertomatic victron imv ups
Malfunction of input circuit: voltage delivered is too low. The batteries may
be faulty or depleted. Wait for a few hours, leave the UPS switched on
If absence of input power (utility failure, maintenance work) is expected to last longer than a few hours, switch
off the UPS to save battery power. If the UPS input power is absent for several days and the UPS remains on
under no-load conditions, the batteries can be discharged very deeply, resulting in a short battery life time
Apr 22, 2014 | Computers & Internet
LaCie 500GB portable hard drive is giving error 43. It was working fine for a few weeks and now I can't get into it from either of my computers. I tried uninstalling the USB Controllers but still same...
The symptoms indicate there is a problem with the drive, how it is connected, or with the computer used for troubleshooting. The next best step is to change physical variables, and find a simpler problem than a broken product.
  • Change the data cable (USB, FireWire, Ethernet, etc.) A failure in the cable can cause this issue.
  • Change the external power supply or cable. If a different LaCie product is available, borrow the power cabling from that unit to see if the problem is in that component. On drives that are powered via USB or Firewire, try using the included power sharing cable and connect it to a second port.
  • Change the computer you are using. Computer problems can manifest themselves in many ways. Even if the computer appears to be working properly, this is a worthwhile test.
Then run
Dec 22, 2010 | LaCie 500GB Rikiki USB 3.0 Portable Hard...
I would like to thank all the experts on this site that helped me to solve my problem.Two swollen caps were my problem, which I managed to replaced for a cost of $2. Power board, 25v1000mf. Initially...
Glenn
You are so welcome, glad you got the expert help you need.
Many expert's believe it was not the "caps" that caused the failure in the first place. Manufactures that get cheap use lower voltages to save money some may disagree.
Using a higher voltage Capacitor will not hurt the unit as long as the MF rating is the same and as long as the thing fits on the board itself.
What makes these Capacitors give out is power surges, wear, and other issues with the unit. Do not get me wrong here just changing a capacitor sure might help things for a little while or maybe the life of the product who knows? People have changed out "Caps" and had it fail after a few months because of other issues with the Values that change on a power board.
We Thank You for bringing your issue to us and hope you do find the site Very Helpful
Regards
Ed aka Rulds2008
Nov 18, 2010 | Samsung Computers & Internet
I have a 1998 Cadillac Deville D Elegance and have had 4 batteries in 5 months. been told it was not the alternator, but a ground? When the first battery died i was jumping it with another car when white...
Instead of guessing as to what the problems is have it diagnosed at a qualified repair shop . Electrical testing needs to be done , charging system out put testing . voltage drop test electrical circuits . A bad ground wouldn't cause the battery to go bad , not charge properly is about all . Was the battery tested before it was replaced ? load and capacity tested ? What's the voltage Measurement at the battery with the engine running ? If the battery failed as many times you said it did , without testing i would suspect a over charge condition .That would be a guess without testing. The charging system on your vehicle is computer controlled .
Battery Common Causes of Malfunction
A battery is not designed to last forever. With proper care, however, the battery will provide years of good service. If the battery tests good but still fails to perform well, the following are some of the more common causes:
• A vehicle accessory was left on overnight.
• The driving speeds have been slow with frequent stops (stop-and-go driving).
• The electrical load has exceeded the generator output (particularly with the addition of aftermarket equipment).
• Existing conditions in the charging system, including the following possibilities:
- An electrical short
- A slipping belt
- A bad generator
- A bad generator voltage regulator.
• The battery has not been properly maintained, including the following situations:
- A failure to keep the terminals tight
- A failure to keep the terminals clean
- A loose battery hold down.
• There are mechanical conditions in the electrical system, such as a short or a pinched wire, attributing to power failure.
Aug 19, 2017 | 1998 Cadillac Seville
My Dell Inspiron 530, works fine once its powered up, but it take three attempts for the computer to boot on. I have taken the following steps. Checked that all fans are operational, they are. I have...
OK, here is what dell says:
BIOS checksum failure. Possible motherboard failure.
Try re-seating your memory modules and see if the beep code disappears
Also, Try using the Dell Diagnostics which is located on a hidden diagnostic utility partition on your hard drive or on the Drivers and Utilities Cd that came with your computer.
  1. Ensure that the computer is connected to an electrical outlet that is known to be working properly.
  2. Turn on (or restart) your computer.
  3. When the DELL™ logo appears, press <F12> immediately. Select Boot to Utility Partition from the boot menu and press <Enter>.
Press any key to start the Dell Diagnostics from the diagnostics utility partition on your hard drive.
Dec 29, 2009 | Dell Inspiron 530 Desktop Computer
Isn't receiving power. Ports seem "loose" in back.
Couple of things. Lacie power supplies are notorious for their failure rates. Don't buy a new one just phone lacie and they will send you a new one no questions asked (that's how bad they are!)
Second, the circuit boards in some are pretty poor and the FW sockets can actually break off.
I used to recommend lacie to my clients - but not any more.
Sep 10, 2009 | LaCie Big Disk Extreme 500 GB Hard Drive
Motherboard start and freeze at the ''E'' screen
You may have a failed motherboard or power supply. Failure of motherboards (and power supplies) is usually due to breaking capacitors. A few years ago a capacitor company stole the "recipe" for making capacitors from another company and tried to make their own, unfortunately they did not get the ingredients right and the capacitors started breaking after 2-3 years of use. They sold these capacitors at very cheap prices and a lot of computer companies and power supply makers bought them. This is easy to diagnose. Look for capacitors (caps) (they look like little tiny soda cans) on your motherboard (mobo). They should be perfectly flat on top and not bulged or swelling or leaking anything. Also they should not have bursted out the bottom (it is hard to see). The dead giveaway is the fact that you are not getting anything after you changed the PSU. There are a few companies that will repair broken capacitor issues. Also if you add a bunch of extra components without upgrading the power supply you can suffer underpowered situations and that can cause internal parts to fail.
To eliminate some other stuff you could remove the memory and disconnect all the power plugs from the drives and then try to start it up. If it does not change the behavior at all (no beeps, no change in flashing lights) then you probably have motherboard issues. Make sure when disconnecting the memory chips (sticks) that you touch the metal on the inside of the case first to discharge static electricity. If it does change the behavior add 1 component or item back at a time to see what you can find out. Post back with what you find. I am currently working on an emachine with the same issue. It has about 6 bad caps, 5 top bulgers and one bottom bulger.
Mar 31, 2009 | E-Machines etower 633ids PC Desktop
Computer not loging on
You may have a failed motherboard then. Failure of motherboards is usually due to breaking capacitors. A few years ago a capacitor company stole the "recipe" for making capacitors from another company and tried to make their own, unfortunately they did not get the ingredients right and the capacitors started breaking after 2-3 years of use. They sold these capacitors at very cheap prices and a lot of computer companies and power supply makers bought them. This is easy to diagnose. Look for capacitors (caps) (they look like little tiny soda cans) on your motherboard (mobo). They should be perfectly flat on top and not bulged or swelling or leaking anything. There are a few companies that will repair broken capacitor issues. Also if you add a bunch of extra components without upgrading the power supply you can suffer underpowered situations and that can cause internal parts to fail.
To eliminate some other stuff you could remove the memory and disconnect all the power plugs from the drives and then try to start it up. If it does not change the behavior at all (no beeps, no change in flashing lights) then you probably have motherboard issues. Make sure when disconnecting the memory chips (sticks) that you touch the metal on the inside of the case first to discharge static electricity. If it does change the behavior add 1 component or item back at a time to see what you can find out. Post back with what you find. You could also change out the power supply if you do not find any caps that are visually bad.
Mar 31, 2009 | E-Machines T6414 (RBT6414) PC Desktop
Motherboard failure
Failure of motherboards is usually due to breaking capacitors. A few years ago a capacitor company stole the "recipe" for making capacitors from another company and tried to make their own, unfortunately they did not get the ingredients right and the capacitors started breaking after 2-3 years of use. They sold these capacitors at very cheap prices and a lot of computer companies and power supply makers bought them. This is easy to diagnose. Look for capacitors (caps) (they look like little tiny soda cans) on your motherboard (mobo). They should be perfectly flat on top and not bulged or swelling or leaking anything. The dead giveaway is the fact that you are not getting a monitor signal and if you listen to your computer as it starts up, a few of the devices may not start (hard drive, etc). A failed video card will also give you "No signal message", but the computer should sound normal when starting up. Mobos are usually expensive to replace because the computer makers have them made especially for them and only order so many. They usually do not have a lot of extras laying around. There are a few companies that will repair broken capacitor issues. Hope this explains why they can fail. They can also fail if overheated (like when a case cooling fan fails), the cpu is overclocked and not cooled down (which raises temps), the power supply fails or by lightning and power surges. Also if you add a bunch of extra components without upgrading the power supply you can suffer underpowered situations.
Mar 11, 2009 | Compaq PRESARIO SR1475CL AMD Athlon 64...
Maxtor external hard drive failure
If you really want those files, try DriveSavers.com. They do wonders with dead hard drives (known to have recovered files off a burned hard disk). But it comes with a hefty price. So check their website, http://www.drivesavers.com/.
Dec 23, 2007 | Maxtor 100GB 7200 RPM Personal Storage...
Maxtor OneTouch 4 500GB External USB 2.0 Hard Drive Logo
182 people viewed this question
Top Maxtor Computers & Internet Experts
Computer Links
Rick Arnold
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
