Question about Briggs Stratton IC Horizontal OHV Engine 305cc 1450 Series 145 Gross Torque 1in x 3 2132in Shaft Model 2053320537B1
Bllowing oil out the exhaust pipe. - Briggs Stratton IC Horizontal OHV Engine 305cc 1450 Series 145 Gross Torque 1in x 3 2132in Shaft Model 2053320537B1
  • 391 Answers
Was an oil change recently performed on the car?
If so, check the oil level. If the oil level is well above the hashmarks, then it was overfilled and should be drained until the oil level is correct.
It is also possible that the engine's piston rings may be bad, allowing excess oil to seep into the combustion chamber. But, if this happens, you may also have a loss of compression, which may result in a loss of power. hope this helps you.
Posted on Mar 16, 2011
What is the problem when there is oil dripping from the exhaust pipe
Oil? Or condensation mixed with carbon inside the exhaust? Oil coming out would be a very bad sign of serious engine damage. Condensation is normal, and sometimes looks like oil, but it isn't. Do the drops you see dry up after a while?, that would be condensation, and that is just fine. If the drips never dry up, that's oil, and time for a new engine
Nov 10, 2014 | Cars & Trucks
Yamaha V-Star '07 1100 oil leak at rear cylinder exhaust pipe seam
hard call ! compression test , but sounds like your going to get your hand dirty ! P...
Dec 03, 2013 | Yamaha Motorcycles
Backfires badly when downshifting or just letting off the throttle v-star 1100
Most people have this problem after changing the exhaust system. In your case you have to unbolt the exhaust system just to change the oil filter during an oil change. There is an oil filter relocation kit available for around $400 that allows you to both use a spin on filter and not have to unbolt the exhaust system every time you change the oil. The cause of your problem is air leaking past the exhaust o-rings in the head. Buy new exhaust o-ring gaskets for the head and your problem should be solved. If there is a sealing pipe gasket going from the head pipe to the muffler you may have to replace that too. The cause of your problem was probably an oil change where the mechanic replaced the oil filter but did not bother to replace the exhaust o-ring gaskets. Happy riding.
Jul 02, 2011 | 2004 Yamaha V Star Classic
We recently did an oil change on my car and then we went to drive it and it seemed like smoke was coming out of the exhaust pipe
Keep an eye on your oil level, but I suspect when you did oil change "someone" spilled old oil on an exhaust pipe. It happens all the time. But for peace of mind, check your oil level to make sure there isn't a leak.
Mar 09, 2011 | 2008 Kia Rio
Oil pan leak
buy a tube of sealer called Right Stuff
1. Remove the flexible exhaust pipe
2. Disconnect the downstream catalyst monitor sendor (OXYGEN SENSOR)
3. Drain engine oil
4. Remove the 15 bolts and the oil pan
5. Clean pan & surface area.
6. Apply sealer 10mm (0.40 inch) diameter of sealer
7. Position oil pan and hand-tighten the oil pan bolts
8. Start with front of oil pan tighten each bolts going around oil pan till all are tighten up.
9. Install exhaust flexible exhaust pipe
10. Connect OXYGEN SENSOR connector
11. Lower the vehicle.
12. Fill oil 5w20 (Spec)
Feb 10, 2010 | 2001 Ford Escape
I took my 99 camaro super charged for an oil change at jiffy lube and now when i turn my engine on oil just comes out my exhaust pipes. one day later i noticed that the oil was all gone from the engine and...
Hi , Oil from the ex pipe? Liquid oil or burned oil? The oil may be so new that you are not seeing it on the dip stick? An engine will run about 5 min with no oil before it locks up.
Quinn
Jan 23, 2010 | 1991 Peugeot 405
How do I replace the oil pan gasket on a 2001 GMC Yukon XL?
Changing the oil pan gasket on a GMC Yukon XL is realtively simple, but does require removal of the exhaust pipe. You will need a new oil pan gasket and a new exhaust pipe flange gasket.
Put the car on ramps or jacks to access the undercarriage.
Remove the exhaust pipe by removing the 3 nuts holding the exhaust pipe flange to the exhaust manifold. These nuts often rust and prior application of penetrating oil may be required to remove them without damage. Once the pipe is unbolted, work the exhaust system loose from the hanging brackets. In most cases the entire system does not have to be removed since there is enough room to remove the pan with only the front hangers removed.
Drain the oil from the engine
Remove the 10 mm bolts holding the pan to the block.
Remove the old gasket material and scrape any remaining gasket from the block and pan.
Install the new gasket. Forma-Gasket or a similar product may be used in small quantities to "glue" the new gasket in place and prevent shifting while the pan is reattached to the block.
Reinsall the 10 mm bolts in a cross pattern to ensure the gasket is compressed evenly. Do not overtighten the bolts.
Replace the pipe to flange gasket between the exhaust pipe and the exhaust manifold with a new part.
Reattach the exhuast pipe to the hangers.
Install the 3 bolts connecting the pipe flange to the exhaust manifold.
Fill the engine with oil.
Sep 15, 2009 | 2001 GMC Yukon
Oil leak by exhaust pipe
I am not personally familiar with a 1975 DT250, but here is a general overview. If the bike is a 4 stroke, the oil you observed could have been from the exhaust, however it is more likely that it is from a leaky valve cover gasket or a head gasket. If the bike is a 2 stroke, the "oil" is from the exhaust (expansion chamber). It is excess 2 stroke oil that accumulates. You should reduce the mix to 32:1 or even 40:1 and replace the oring gasket in the opening of the pipe. If in a pinch you can use high temp silicone, but not a good way to go.
best wishes!
May 11, 2009 | 2003 Suzuki RM 125
05 susuki forenza
Removal Procedure
1. Disconnect the negative battery cable.
2. Drain the engine oil from the engine crankcase.
3. Remove the exhaust flex pipe retaining nuts from
4. Remove the exhaust flex pipe retaining nuts from
the catalytic converter or the connecting pipe.
5. Remove the exhaust flex pipe.
6. Remove the oil pan flange–to–transaxle retaining
bolts.
7. Remove the oil pan retaining bolts.
8. Remove the oil pan from the engine block.
Cleaning Procedure
1. Clean the oil pan sealing surface.
2. Clean the engine block sealing surface.
3. Clean the oil pan retaining bolts.
4. Clean the oil pan attaching bolt holes in the engine
block.
5. Clean the oil pan scraper.
Installation Procedure
1. Coat the new oil pan gasket with sealant.
Important : Install the oil pan within 5 minutes after applying
the liquid gasket to the oil pan.
2. Install the oil pan to the engine block.
3. Install the oil pan retaining bolts.
Tighten
Tighten the oil pan retaining bolts to 10 NSm (89 lb–in).
4. Install the oil pan flange–to–transaxle retaining
bolts.
Tighten
Tighten the oil pan flange–to–transaxle bolts to 40
NSm (30 lb–ft).
5. Install the exhaust flex pipe.
6. Install the exhaust flex pipe retaining nuts to the
exhaust manifold.
Tighten
Tighten the exhaust flex pipe–to–exhaust manifold
retaining nuts to 35 NSm (26 lb–ft).
7. Install the exhaust flex pipe retaining nuts to the
Tighten
Tighten the exhaust flex pipe–to–catalytic converter
or connecting pipe retaining nuts to 35 NSm (26 lb–ft).
8. Connect the negative battery cable.
9. Install the oil pan drain plug.
Tighten
Tighten the oil pan drain plug to 35 NSm (26 lb–ft).
10. Refill the engine crankcase with engine oil.
Jun 14, 2008 | 2005 Suzuki Forenza
Briggs Stratton IC Horizontal OHV Engine  305cc 1450 Series 145 Gross Torque 1in x 3 2132in Shaft Model 2053320537B1 Logo
305 people viewed this question
Top Briggs Plumbing Experts
John Trevino
Jim Parker
Jim Parker
Are you a Briggs Plumbing Expert? Answer questions, earn points and help others
