Question about Kenmore Sewing Machines
I can't loosen the wheel to wind a new bobbin on model 158-1340280
  • 40 Answers
It may be seized up, depending on how old your machine is. I had the same problem with mine & used a hair dryer to blow hot air on it until I was able to loosen the wheel.
Posted on Mar 17, 2011
Thread won't wind on bobbin. Just goes up and down and never swings thread around bobbin,
you have to loosen the hand wheel clutch to stop the up down motion then perhaps the bobbin with turn
Feb 06, 2017 | Sewing Machines
How do I add thread to the bobbin on Singer sewing machine 3114?
Your repair shop will have to fix the handwheel, but you can still wind your bobbin. UNTHREAD the machine completely, and take the needle out. Set up your thread to wind the bobbin, and push the winder over until it clicks. Wind your bobbin. I don't have a picture of your model; this is just standard.
Feb 23, 2015 | Singer Sewing Machines
How to wind bobbin
1. LOOSEN THE HAND WHEEL. 2, PLACE BOBBIN ON BOBBIN WINDER AND PUSH TOWARDS INNER WHEEL TO LOCK. 3. RUN THREAD FROM THREAD HOLDER TO LITTLE METAL WHEEL ON LEFT OF MACHINE. 4.RUN THE THREAD AROUND THIS WHEEL AND TO THE BOBBIN. 5. ATTACH THE THREAD TO THE BOBBIN. 6. PUSH THE FOOT PEDAL.
7. WIND THE BOBBIN EVENLY AND STOP AT TWO THIRDS.
Nov 16, 2014 | Sewing Machines
Winding a bobin
That's how that machine works. You don't loosen the hand wheel or anything, Simply put the bobbin on the winder and go.
Mar 13, 2014 | Husqvarna Viking 1
When I wind a bobbin, it makes a screeching noise and the needle goes up and down. What step am I missing ?
On the right side is a big wheel and in the middle a smaller one. You need to unlock the smaller wheel so that the needle mechanism does not run when re-winding a bobbin. You need to use both hands to do it. Hold the bigger wheel and then loosen the inner wheel anti clock wise. Once you have finished loading your bobbin you need to tighten the inner wheel again for the machine to be fully functional again.
Jan 12, 2014 | Singer 7436 - INGENUITY
I only want to know if the wheel must be loosened to wind the bobbin and if so with direction, to the front or backwards and press and turn or pull and turn.thanks
Which make and model sewing machine do you have?
None of my sewing machines need the wheel to be loosened for bobbin winding. The Singer Touch & Sew bobbins are filled in place. Use the handwheel to get the needle into the highest position (just turn the wheel). Wrap the top thread around the screw that holds the presser foot; open the slide plate part way and press the bobbin wind button. Hold the top thread and then begin winding by stepping on the foot pedal.. The thread should break after a few winds.
The Kenmore and the Husqvarna Vikings both get wound at the top. Place bobbin on winding pin. With the needle up and metal presser foot in place thread the top thread up to the bobbin (through the guides) and up through the hole in the bobbin. Slide the bobbin winding switch over towards the bobbin. Hold the thread tightly and begin winding (step on the foot control). After a few winds are on the bobbin, cut the thread that you were holding flush with the top of the bobbin. Continue winding the bobbin. (The newest Viking in the group has a computer screen; on that one, do not press OK until done winding the bobbin.)
However, if the handwheel is not turning and the needle is down, first find out why it isn't turning properly. This could indicate a tangle of thread somewhere in the system. (The older Husqvarna sewing machine in my home has a non-functional handwheel. The machine will still sew but you have to use the needle up/down switch that forces the needle to stop in the up position before you run out of bobbin.)
Please add a comment with the specifics of your sewing machine and I'll be glad to add additional information.
I hope this helps.
Feb 28, 2012 | Sewing Machines
How do i add thread to the bobbin? i have wound it and placed on the knob, and pulled out the wheel but nothing is happening..
when you place the bobbin on the bobbin winder on top of your machine, you then push the lever closest to it into the bobbin until it clicks. most newer machines will automatically quit using the needle when you are winding a bobbin if its an older machine there may be a push button on the wheel or you may have to loosen the knob inside the wheel to keep the needle from operating , you then use the foot pedal to wind just as you would to sew. Bobbin will automatically pop when full, be sure to redo anything that you had to undo to wind bobbin.
Oct 28, 2010 | Kenmore 15516 Mechanical Sewing Machine
Needle not going up and down but power getting to the machine
Check your manual for the bobbin winding steps for your particular model.
On some machines there is a knob in the center of the hand wheel that is loosened for bobbin winding - this also disengages the movement of the needle. Tighten for sewing.
There may be an additional step, such as moving the bobbin winding pin to the right or the bobbin winding wheel to the left.
Apr 06, 2010 | Bernina Sewing Machines
The knob on wheel stuck.
Remove the needle, and place a screwdriver or something like it under the needle bar to keep the wheel from turning.
Wrap the knob in some type of fabric to keep it from being marred.
Using channel locks or water pump pliers, grasp the knob and turn it to the left. It should come loose. Once it is loosened, try it 2 or 3 times to make sure it works as it should.
Wind the bobbin, insert a new needle and have fun again.
sewman7
Dec 29, 2008 | Necchi 3537 Mechanical Sewing Machine
Winding the bobbin?
Most of the entry level machines will have either a clutch knob or an automatic release when the bobbin winder mechanizm is engaged (put a bobbin on and more the unit to you right). If it does not disengage the clutch automaticly then either loosen the clutch wheel by turing or pulling. Sometines you have to grab the whole clutch wheel to disenage the mechanism to free wheel while winding the bobbin. Now press you foot control to wind the bobbin.
SewTech
Apr 21, 2008 | Janome Mini Compact
Sewing Machines Logo
100 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
