Question about Dell 3110cn Laser Printer
REPLACE TRANSFER BELT IN DELL 3110 PRINTER,TURN ON THE PRINTER MASSAGE IS RESET TRANSFER BELT ERROR CODE 009-391
  • 4 Answers
SOURCE: Dell 5100cn Laser Printer Problem
i had the same error, i found when i would take the toners out it would only recognize my yellow toner as missing, none of the others would show as missing, i replaced the yellow toner and it was fine after that, the yellow toner happened to be a remanufactured toner and had a different toner chip on it as well. also just an fyi,the dell 5100 color printer is a rebadged xerox 6250.
Posted on Feb 09, 2008
HandyManny
  • 4 Answers
SOURCE: printer problem
Hello, it is likely that the transfer roller requires replacing. You may be able to purchase the roller from a local office supply, otherwise buy on line. However, there is more to it...
The error means, the Transfer Roll Cannot start servo operation. Verify correct cable connections from the Engine board to the HVPS (high voltage power supply). Make sure there is continuity between the transfer roller and its contact on the HVPS; replace the transfer roll if the continuity is correct.
If there is no continuity, make sure the HVPS contact returns to its upward limit when depressed, and make sure the left bearing of the transfer roll is making proper contact.
If the wires are all connected correctly, and there is continuity through the roller contacts, replace the roller.
Posted on Feb 23, 2008
SOURCE: RESTART Printer
The new magenta cartridge you put in is bad. If you put the old one back in then you get the low toner message. Take the new cartridge back and get another new one.  I found the answer on the dell troubleshoot website
Posted on May 18, 2009
pineworks
  • 4041 Answers
SOURCE: Dell 5100 printer error code 009-380
Hi You can Try
Error Code 5100
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
Posted on Jan 28, 2010
  • 217 Answers
SOURCE: my dell 3110cn printer is
This error message indicates that the printer has failed to read information from the chip on the black printer cartridge.
This is either.
1. Black cartridge not fully pushed into place (I've been called out to a couple like this)
2. Faulty chip on the black cartridge - effectively not responding to the printer 'talking' to it.
3. Fault on the main board of the printer.
Solution
1. Push the cartridge fully home.
2,3. If you have an old black cartridge, try that. The message should change to Replace Toner, if it does, its the chip on the cartridge, if it doesn't its the printer.
Posted on Nov 24, 2010
How do you reset maintenance count on a dell 3130?
You don't. You can't.
When you install a replacement Transfer belt (it has it's own counter chip) that resets the transfer belt pagecount, and as a result clears any transfer belt life related warnings/errors.
When you install a REPLACEMENT Fuser (that has it's own counter chip) that resets the fuser pagecount, and as a result clears any fuser life related warnings/errors.
PLEASE NOTE - The fuser supplied with the DELL 3130 when new DOES NOPT have a counter chip - the fuser life warnigs are triggered by the printer pagecount. Installing a fuser from another printer (even if it has a ZERO pagecount WILL NOT reset the fuser pagecount (because the 'ship with' fuser has no counter chip.
Aug 27, 2014 | Dell 3130cn Color Laser Printer
Error code r80
what is the equipment that is giving you this error?
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Aug 21, 2014 | Office Equipment & Supplies
C2801 konica minolta bizhub 501
TCR output abnormality. What is the status of your consumables (drum and developer)? You might need to replace the developer. Also, you should check if the toner bottle is turning; you should see it turning while the front cover door is open and the machine operates; if it is not turning, it is possible that the toner bottle was inserted wrong (by force).
Aug 15, 2014 | Konica Minolta bizhub Office Equipment &...
Konica Copier says malfunction detected code C-0096
this is the error code for the image transfer belt pressure retraction failure to reset error code with the machine turned on open and close the front door if error comes back will have to replace either the transfer belt or the belt pressure motor
Oct 26, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
My Dell 3100 has a massage that says belt unit is close to life. What do i have to do?
The Belt unit is referring to the transfer belt which must be replaced, for the 3110 the part number is HG432. Iteminc.com has these in stock and ships same day. Installing it is simple and doesn't require any tools. Here is a video that shows you how. Hope this helps and thanks for using FixYa
Apr 07, 2011 | Dell 3100cn Laser Printer
Have a transfer belt error What to do?
To fix this error, you will need to replace the transfer belt and/or reset the transfer belt count on your printer. If you are happy the the print quality of the printer, then you can try to reset the transfer belt count and that will clear the error. Otherwise you need to get a replacement transfer belt and swap it out before resetting the count.
To remove your existing transfer belt, you need to open the front panel, and remove the imaging unit by pulling the green handle. The belt is located above the imaging unit. Pull the belt down to release and then pull it straight out of the machine. Take your new belt and slide the back into the machine and push the front of the belt up to lock in place. Then you need to reset the belt count.
To do this, follow the steps below.
1. Enter Tech Mode by pressing [MENU] [#] [1] [9] [3] [4]
2. If you do not see the Tech Mode menu press the menu button again. (You need to enter the key sequence quickly.)
3. Select Tech Menu
4. Select DataSetup
5. Arrow to Clear Counts and press OK
6. Enter Password 1934
7. Arrow to Transfer Belt and press OK.
Hope this helps you.
Apr 02, 2011 | Samsung CLX 3160fn All-In-One Printer
Dell 3110 laserjet printer, belt unit close to life
This message is displayed when the pagecount of the transfer belt is 80,000 (ish)+.
The rated life of the transfer belt in the Dell 3110/3115 is 100,000 pages.
After that pagecount the transfer belt 'expires' and no further printing is possible until the transfer belt is replaced.
Feb 03, 2011 | Dell 3110cn Laser Printer
I have a Xerox workcentre 7345 and reported that the transfer belt cleaner needed to be replaced. I replaced it and the message is still appearing.
Hi, In my printer Xerox 7245 display it appears Replace Transfer belt error. So please guide me how to reset value without replacing ETB
Jan 14, 2011 | Xerox WorkCentre M-24 Color Copier
Dell 3110cn "belt unit" -- what is that?!
hello
here is some information that can help ..
general link to access everything about 3110 laser printer
http://support.dell.com/support/downloads/driverslist.aspx?c=ca&cs=cadhs1&l=en&s=dhs&os=WLH&osl=en&SystemID=PRN_LSR_3110CN&catid=-1&impid=-1
you have to replace TRANSFER BELT, part number you need to order is "HG432 TRANSFER BELT," and you may want to consider "UG190 DAO Service kit: Fuser, SepRollers, TransferBelt, 110, 311XCN" The latter is a kit that contains the XFR belt, a fuser, feed and sep rollers, etc. as well.
this may be expensive ..
Nov 09, 2010 | Dell Office Equipment & Supplies
Ordering Belt Unit Dell 3110cn
Yes there is, I found something on amazon, here: Amazon com dell 3110cn belt. I hope this one helped you. have a nice day
Mar 13, 2008 | Office Equipment & Supplies
Dell 3110cn Laser Printer Logo
472 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
