I need the PSU board (16PW36-2) for my GHD8015F2, as I suspect it has failed. If these parts are not available, I would also be interested in acquiring circuit diagrams for all 3 PCBs in the machine - the PSU board in particular is all discrete components, and should not be rocket science to repair... Grateful for any assistance, as this has been a brilliant machine, I have changed the HDD on 2 separate occasions (as they became full - currently running a 160GB) and would hate to lose all my recordings! IanL
3 Suggested Answers
  • 718 Answers
SOURCE: I need the PSU board
GOODMANS GHD8015F2 in the UK
You can get the USER's manual from;
http://safemanuals.com/314159.php?k=8391d3906c77608652c0aeebfd8fdc85&ID=567120&q=GOODMANS GHD8015F2
after entering a security code to proof you are not an automated software bot.
Here is some information I got from a forum you might find useful. If you can find a service manual for the same model under a different name, it should work.
I had a few recording on the Freeview box I wanted to keep so decided to extract them from the Harddrive and archive them on my Vista Premium PC.
Here are a list of the re-branded machines made by vestel obtained from http://www.futaura.co.uk/vestel.html
Digihome PVR80 and PVR160 (Argos)
Dual DPVR80 and DPVR160 (Asda)
Evesham PVR160
GOODMANS GHD8015F2
Grundig GUSTB80IV and GUSTB160IV
Hitachi HDR080 and HDR160 (Argos)
Maplin PVR80
Sharp TU-160H
Techwood PVR80 and PVR160 (Tesco)
Here goes with what you need to do, hopefully preventing other people going down some blind alleys as I did. You'll need a basic knowledge of PC DIY, but nothing too advanced.
Obviously taking your PVR to bits will invalidate the warranty, and there's a risk you'll damage it if you're worried about this don't do it!
Here goes....
1. Power the box down and disconnect from the mains.
2. Take the lid off, about 8 screws, four on the back and four on the sides.
3. You can now disconnect the IDE cable and power connector from the Harddrive. The easiest way to connect the drive to the PC is by use of an IDE USB Harddrive Caddy, that's what I did. Otherwise you're into opening up you PC and connecting it is as a secondary disk.
4. The disk has a Linux file system on it so Windows Vista will not recognize the disk, so you need to get a windows EXT2 file system driver.
5. I downloaded and used Ext2Fsd-0.46a.exe from here http://e2fsprogs.sourceforge.net/ext2.html
6. Run this and you'll see the disk. Mine had two partitions, you'll probably have to assign drive letters using the ext2fsd utility. I set mine to K: and L:, I connected in read only mode to ensure I didn't corrupt the disk.
7. You should now be able to see folders and files on the drives. One of my disk partitions was 75gb the other was 5gb. The recordings were stored in folders on the large partition. (I'm guessing the small disk is used for Pausing live TV)
8. It appears there is one folder per recording with a name showing the date and time the program was recorded. Something like this:
~dvr20090000191304000501.rec
9. The recordings are numerically split into individual files of about 190mb each (00,01,02 etc). Something like this:
dvr20090000191304000501.rec00.trp
dvr20090000191304000501.rec01.trp
dvr20090000191304000501.rec02.trp
10. I copied all of the folders and files to my PCs Harddrive, just in case something went wrong, I didn't want to damage the PVR disk contents.
11. Now you need to do a conversion to allow the files to be viewed by a suitable player, again pretty easy and here is it what you need to do.
12. You need to get a program called ProjectX. I got it from here:
http://download2.videohelp.com/downl...X_090.4.00.zip
13. Extract and install this program, it'll also install a Java compiler.
14. This program will convert the multiple ".trp" files to ".ts" mpeg transport stream files which can then be opened using the videolan media player.
15. When you run ProjectX you'll need to add the sequence of ".trp" files to the bottom pane of the main window. Make sure you have the lowest sequence file number at the top of the list i.e. 00 and all the other files are in the correct order, you do this by selecting the up or down arrow to the left of the pane.
16. I found you can drag and drop the whole sequence of files from windows explorer to the pane (just check the sequence order is correct order after the drop as per step 15 above)
17. For the first time only you need to click the prepare>> button on the left of the preview screen. All I did was select the radio button to the left of the "to TS" selection.
18. When this has been done just click the go button (Green arrow) and it'll process each file and stitch them all together to produce a ".ts" file in the folder where the ".trp" files are stored. This ".ts" file can be played by videolan. This process is quite quick as it isn't re-encoding the file format.
19. When you process the next recording you can skip the prepare>> steps (17 and 18) and just click Quickstart. I got problems when I tried to process the next recording so just closed ProjectX and started it again after each recording. I'm sure there's a better ways but it worked for me.
20. I believe you can use ProjectX to convert to formats for archiving to DVD, but I wasn't interested in that so didn't go any further.
21. I wanted to view directly from my PC so I used videolan mediaplay which can be obtained from here.
http://www.videolan.org/mirror-geo.p...9.8a-win32.exe
22. Installation of this is pretty straight forward and once you've installed it, all you have to do is double click on the ".ts" file create in step 18 and you can watch the files on the PC.
Thanks to all those who provided the pieces of information that allowed me to produce this single guide. I hope it helps others. Please correct/enhance as you feel necessary
Posted on Mar 17, 2011
  • 1116 Answers
SOURCE: Hi I need a manual
Follow this link and you will find your manual:
http://www.chung-sim.com/lg.rh256.html
Posted on May 14, 2011
Why does it turn on and off by itself?
Sanyo TV's can Succumb to failing capacitors in the Power supply board which can cause this fault, there are repair kits available if you are adept at soldering components, otherwise consider changing the full board, a little more expensive but easier and less skills required, have a look here for availability and pricing on Sanyo PSU Boards:
TV Parts Universal TV Stands DLP Chips ShopJimmy
Dec 16, 2015 | Sanyo Televison & Video
Samsung tv powers off, is the problem the power supply or main board?
Samsung Power Supplies are prone to failing electrolytic capacitors, you could consider buying one of the many Repair kits available, or go for the more expensive but less skill required power supply board swop,
Samsung Repair Kits : TV Repair Kits MBTV Electronics
Samsung PSU's :
http://www.mbtvelectronics.co.uk/product-category/led-tv-parts/psu-boards
Dec 09, 2015 | Samsung UN40H5003 40 Inch 1080p 60Hz
I have 5v andd 12v out should there be 24v?
I believe you may be confusing this particular error reference to voltage with the power supply's (PSU) available rails (in that case, no there is no 24v rail).
Regardless, it is likely you merely have a faulty PSU. You have two options here as I see it: One, purchase a PSU tester and verify that your PSU is failing (you can get one of these for as little as $6), or you can simply replace the 4700's 450W power supply for as little as $20-$25. In my opinion, and that is all I can give with the available information, you are better off going with the latter. Chances are, you are not going to be running a whole lot of additional PSU tests in the future (and it sounds like your PSU is failing) so you would basically just be spending an additional $6 on a the new power supply that I am very confident you need.
Just think, with that saved six dollars... you can buy approximately 1.82 gallons of gas today!
Sep 24, 2013 | Dell Dimension 4700 PC Desktop
Need a power supply for a pmh5000 and install directions
These are delivered with a power supply. If yours has failed, LIKELY there are other problems. I have repaired several supplies and can coach you through which parts to replace. Often the failure originates with a shorted MOSFET in one of the amplifier channels, usually the rearmost one. Getting parts for these is really hard as FullCompass is the Behringer parts distributor. The SPS1000 supply takes out about $25 of parts when they go. The hardest parts to replace are the IGBT transistors as the heat sinks are hard to remove to get the screws out of the transistors. All the repair parts are available using five different online sources.
Sep 18, 2011 | Behringer Europower Pmp5000 Powered Mixer...
It does not turn on
Does the unit show a clock display - or a standby light on the front? if not, then the PSU is likely to be the cause, with several faulty components, including electrolytic capacitors. If there is a standby LED, but it won't go further, the unit is in protection mode; again, from the (suspected) power supply.
You can opt to visually inspect the condition of the PSU (assuming the unit is out of warranty, and if so, have a look at the electrolytics - many may have bulged/leaked), or, if it still has a warranty, submit to a service centre for a quote on likely repair/parts costs, although I don't think it would be economical.
It is up to you as to how much further you wish to go with this - but keep in mind the possible expense involved along with availability of parts/boards. These days manufacturers lean toward board replacement rather than individual parts replacement/repair.
Mar 20, 2011 | Samsung DVD-HR735 DVD Recorder/HDD...
I need the PSU board (16PW36-2) for my GHD8015F2, as I suspect it has failed. If these parts are not available, I would also be interested in acquiring circuit diagrams for all 3 PCBs in the machine - the...
Evesham PVR160
GOODMANS GHD8015F2
Maplin PVR80
Sharp TU-160H
Here goes....
Mar 16, 2011 | Televison & Video
My protron tv pltv-32c has no picture but has sound, if you change channels the picture will flash on for about 1 second
Hi.
If there is sound but no picture, screen is completely dark and the picture is occasionally flashing, then the fault is likely a faulty inverter. In some case a faulty controller board or a defective PSU can cause the same problem.
I summarized the problem here:My LCD TV has sound but no picture.
I posted general procedure to test inverter, PSU and controller board on LCD here : How to test an LCD TV or monitor PSU and inverter.
If screen is not dark, but has blacklight or noise things are different. In that case check connection cables first. Parts that may be defective are main controller board, terminal circuit and tuner board.
Protron parts are available using the link below. Ensure that parts are compatible with your model before purchasing.
ShopJimmy - Protron Parts.
Regards.
May 15, 2010 | Televison & Video
Need part 955C230001 for WS-55859
Not good news for you;
Mitsubishi TV assembly
Since this seems to be an entire board, I suspect that it may have failed and some devices on it may be proprietary making the repair impossible.  The 'chip foundries' are capable of designing a complex integrated circuit in weeks and then giving it a unique part number that belongs exclusively to the company that designed it, making the part impossible to buy from a normal supplier.
If anyone is interested and junking this set due to the high assembly replacement cost, I'd like to get one of these to see if the board is repairable. It may have inexpensive components that have failed and can be easily replaced.  I have the equipment and knowledge that would allow me to either repair it or at least judge its repairability. If you are interested, please email me at:
freetekATlycos.com (remove the 'AT' and replace it with the proper symbol.)
Oct 25, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Ricoh 6513 - no power
There is no schematic available. Only point to point wiring for the various modules. If you have no power at all, nothing starts glows or blinks on the control panel or on any of the various boards then you will need a service call to try to resolve the problem. It may require a board swap to see if that board is at fault. Unfortunately the days of repairing boards are long gone. Sorry!
Dave T
Jun 02, 2008 | Ricoh 6513 Copier
Televison & Video Logo
125 people viewed this question
Top Televison & Video Experts
Electro Med Services...
