Question about HP LaserJet 4250DTNSL Printer
Our stapler is not working, we have changed the cartridge, any ideas?
    Genius:
  • 1,089 Answers
Sounds like you need to replace the "Stapler Unit".
Part # RM1-1164-000CN.
You might want to 1st make sure that there are no staples jammed in the unit
Posted on Mar 17, 2011
I have tried to reload the stapler but it will NOT staple What am I doing wrong?
1. Make sure you have the correct staples for the machine. This machine requires "standard" staples, which are 1/4" staples.
2. Check the staple cartridge to make sure there are no visible jams.
3. Check the power connection to the stapler. Is it plugged in? Is the plug working?
4. If you continue to experience problems, contact the manufacturer at
1-800-STAPLES. They will replace the stapler if it continues to malfunction.
Apr 18, 2011 | Staples One Touch High Capacity Stapler
We have a Swingline 690 electric stapler in our office. We are unable to get the stapler to work after loading staple cartridge. We followed the directions and made many attempts to load. There does not...
I had the same problem with my 690. This is what worked for me.. I simply pulled out the staples from the cartridge a little further than the suggested tear-off point, and the machine was able to start working. Hope this helps!
Mar 30, 2011 | Swingline Portable Electric Stapler
Stapler losing air around trigger is this a o ring problem?
The problem is most likely the trigger valve. P/N FA205BA1 any Bostitch dealer should be able to get it for you. Its a complete cartridge that slids into the gun frame, unfortunatly you can't just change the o-rings.
Dec 26, 2010 | Stanley Bostitch Sb 2IN1 2 In 1 Narrow...
WHERE do I open it to refill it??
Located on the end opposite of where the staples come out, there is a spring loaded cap. Push it in toward the base of the stapler and slightly down to release the retaining hook. then let the spring release the pressure rod and pull it out. Connedted to the end of the rod you will see a plunger that is shaped like a short run of staples. Make a mental note of how and where this plunger slides into the base of the stapler. Place a run of staples into the stapler in the same manner that the plunger fits then replace the plunger into the same place following the run of staples. Compress the spring into the stapler and attach the hook as it was. Now you are ready to work.
NOTE: If you cannot compress the spring enough into the stapler you have inserted too many staples, just remove some of the run of staples and try again.
Nov 12, 2010 | Arrow T50P ARROW STAPLE GUN
Our Canon NP6035 copier won't staple. It had a jam in the stapler, which I removed. We installed a new staple cartridge. The stapler makes indentions in the paper, but it won't advance any staples.
Do you have a 10 or 20 bin finisher? I'm guessing you have a 10 bin. Did you install the stapler cartridge in correctly? There is a small black plastic gear that cracks and the stapler will not work. The two way's to solve the problem is to replace the gear or the stapler unit. Both may be had to find. Good Luck
Aug 24, 2010 | Canon NP 6035 Copier
How do you open the optima powerease stapler to add more staples?
Push the black half-oval button at the hinge to release the staple cartridge. Extend the staple cartridge from front of the stapler, add staples, push back in.
Jun 25, 2010 | Swingline 87850 Optima PowerEase ? Full...
My Swingline model 520e jams every other time I staple.
There were a few staples left in the cartridge when the stapler stopped working. I went thru all the steps on bottom for stapler after changing the cartridge with two different cartridges. It makes the noise and puts marks in the paper, but no staples come out of it.
Mar 18, 2009 | Staples Swingline® 36115 Staple Guns Tools...
The stapler is not working
Take a can of can air after you have removed the staples cartridge and blow out the socket that the staples fir into. Sometimes a jammed staple can stick in there and cause problems. Also if you can remove the bottom blade of staples out of the staple cartridge. Just raise that piece with the green on it and carefully remove just one blade.
If that does not work you most likely need a new stapler assembly and they could cost 2-$300. retail. If its under contract with a dealer this should be replaced for free.
Good Luck!
Jan 08, 2009 | Canon IMAGERUNNER 2230 Copier
Stapler
please make sure that there are no staples jammed in the unit,
take the staple cartridge out, release the leaver on the staple cartridge and remove the first sheet of staples, close up the leaver, and reinsert in the copier.
then try to staple again
May 13, 2008 | Toshiba e-Studio 350 Copier
HP LaserJet 4250DTNSL Printer Logo
124 people viewed this question
Seeker5211
Seeker5211
