I have error code T5 on a Ferroli Domicompact 24 kw. Will not reset, can anyone help? Its a new boiler,only 2 months old. Thanks Geoff
5 Suggested Answers
SOURCE: Is Ferroli Optima 701 a condensing boiler?
fraid not its pre condensing and my advice would be to chuck it in the sea
Posted on Jan 08, 2009
  • 9 Answers
SOURCE: fault code ( nocn ) on a ferroli boiler
if nocn is on the time clock then check the wiring to time clock and if all good then it is the time clock at fault and will need repleacing
Posted on May 04, 2010
hassan197954
  • 3 Answers
SOURCE: Fault code F5 & P10
my air cond runs for 20 minutes than shows f5 and shut down compressor
Posted on Mar 17, 2011
SOURCE: How do I set the
http://www.wickes.co.uk/content/ebiz/wickes/resources/images/pdf/DOMIcondens%20F28B%203540S920.pdf
Posted on Mar 20, 2011
Ferroli boiler
You should have 12psi for boiler to operate properly. Sounds like first you have a leak in your sytem. Second sounds like pressure reducing valve is not working properly.
Dec 19, 2013 | Plumbing
Ferroli boiler optimax he 38 c.Powers up ok,no hot water,no error code.Think its an ignition problem.Heating flame not showing?????
Is there an error code? If not the flow sensor for the hot water could be faulty. Also if you've had a power cut depending which model of Optimax HE you have, you sometimes have to tell the boiler it's a Combi, as they have a generic Pcb fitted which is also used on the system only boilers.
Sep 26, 2013 | HQRP Universal A/C Remote Control...
The wifi connection from worcester boiler to room thermastat Honeywell Cm921 , boiler not receiving signal
Can't help you directly, but Honeywell will have user instructions on their website.
It's something like holding the 'stat within a metre of the boiler when the batteries are inserted. Best to RTFI.
Jan 27, 2013 | Heating & Cooling
Fault code f26 ferroli optimax 25c how to reset
There is a parameter on the pcb to change would take 30seconds to do. Never replace ur pcb for these faults. Hold down reset untill u see t5 press reset 1 more time it will then say p01 press the heating temp button until u see p02 press the hot water temp button until it changes to numberv2 and that will fix ur problem
Dec 25, 2010 | Heating & Cooling
Fault code ( nocn ) on a ferroli boiler
Apr 25, 2010 | Heating & Cooling
Why does my Ferroli HE31C keep switching off code A3.
Here you go, page 30, sounds like it's overheating, possibly a problem with the boiler stat or lack of circulation in the system. http://www.ferroli.co.uk/Product_Documentation/Domestic/Optimax_HE_31_C_Manual.pdf
Apr 06, 2010 | Water Heaters
Ferroli boiler error code A3
boilers need a certain amount of water pressure to operate as specified--there may be a pressure regulator valve, allowing a certain amount of water to your boiler, and when water is drawn elsewhere, there may not be enough getting to the boiler---this is one possible solution, but there are easily 20 more, and that is where a trusted plumber is worth it's gold...very difficult to diagnose most plumbing problems without being onsite
Mar 03, 2010 | Water Heaters
Ferroli optimax 31c
Here is a link to the manual.It shows fault codes.
Please rate this solution.
Jan 16, 2009 | Heating & Cooling
Heating & Cooling Logo
296 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
