Question about Refrigerators
The motor is making loud noice - Refrigerators
  • Refrigerators Master
  • 43,501 Answers
Here is a tip that I wrote about refrigerators and the fan noisethat they develop sometimes...
RefrigeratorFan Noise
heatman101
Posted on Mar 19, 2011
Why it make loud sound like fan is thatching some metal when i plug in?
check the fan blade to make sure it is tight on shaft. also check to see if any of the fins are bent could be that they are hitting the housing of the fan motor.
Jun 07, 2014 | Turbo Air MUF-48 M3 Series 2 Door 48"...
DW makes a lot of noice when it's washing....squealy, whiney noice...very loud.
Hello Summer Summer - Often if the dishwasher is making a loud, squealing noise then it is recommended for the wash motor to be replaced. If this problem persists, you can locate a certified technician directly through the manufacturer website or in your local directly to determine what may be causing the issue at hand.
Mar 12, 2013 | Frigidaire FDB1100RHM Builtin Dishwasher
GE Dishwasher - loud rumbling/growling noice!
If I am not mistaken this dishwasher has a Clean out at the bottom of the machine that can open .This is here to catch stuff like broken glass and things like that. It has a little fan like blades that act to chop up food that is to big to go down the outlet hose. also look under the machine if you can ,but in most cases you must remove 4 screws to get the bottom kick plate off, Also check all the spinning arms to make sure they are turning correctly. hope this helps
May 02, 2012 | GE Dishwashers
Dyson makes loud noise
Could be damage to Fan within motor or shaft on motor..Remove brush roll and run with nothing connected to motor ,if noise still appparent then sounds like one or the other if ok then check for damage to the brush roller.../Housing..good luck
Mar 31, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Machine drum makes loud noice in the spin cycle. Makes the same sound that a top-loading machine makes when it goes out of balance. Help.
  • Hi,
  • Try these:
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
please rate my suggestion...
May 20, 2009 | Kenmore Washing Machines
Charger makes loud whining noice
they have a cpu fan in it, and unlucky for you you cant buy anthother part, you either get a new one, or try sparaying some WD-40
May 02, 2009 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
WHIRLPOOL WASHING MACHINE WON'T SPIN
replace coupler between motor and gearbox.
Mar 08, 2009 | Washing Machines
Loud grinding noice before starting to print
Mine makes a grinding noise when scanning or making copies. As long as everything is working, I just tolerate the noise in which the rest of the staff find amusing at first and then ignore it as I do.
Jan 25, 2008 | HP PSC 1210 All-In-One InkJet Printer
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
