Question about Hoover Refrigerators
Water running out from underneath the fridge model HE505UF
  • 64 Answers
There should be a tray underneath the fridge, it is normal for water to collect here, however there is usually a mechanism for drying out this tray, typically a heater that evaporates the water.
Posted on Aug 02, 2008
Why does kenmore side by side model 596.50004100 leak water from bottom?
1. there is a condensation pan under refrigerators, pull front bottom grill off & you should see pan. if pan is full it will overflow, pull forward to remove & empty. also check to see if something spilled in bottom of fridge & is running into drain hole into pan. most of the time condensation is so slow that it will evaporate before the pan fills up, but I've had them fill up on me in the past, not too often though.
2. if fridge is equipped with ice maker & clod water dispenser, connections on bottom back side could be leaking ( not likely, unless they have been disturbed).
there is not much else that it could be unless it is not the fridge & is coming from some where else & running under the fridge.
Oct 09, 2014 | Refrigerators
My Samsung RS253BAWW has been collecting water underneath the bottom drawer for some time now. It eventually winds up in the drip tray underneath and then runs out onto the floor. I've replaced the...
Depends if there is plastic tubing running inside fridge compartment. Shut off water to fridge. If that stops it you will have to look inside to see if there is visible plastic water tubing or if you can get to it from inside the fridge. Maybe the water line has a defect or got pinched and somehow split. Then turn on water, find leak and splice in a replacement section.
Jan 28, 2011 | Samsung RS2534 Side by Side Refrigerator
Water runs out the frezzer side when the door is closed onto the household floor.
Look underneath the fridge and check the drain pan it's probably full. Also check your hoses when you under there. You have a line running from the wall underneath the fridge and up to the water supply system. Check for any lines that might be leaking or have come loose and causing the problem.
Dec 22, 2010 | LG LSC26905TT Side by Side Refrigerator
Hoover Contour HE505UF Refridgerator has stopped working light works have taken off the back pannel fan not working could it be the module on the compressor? rather not spend hundreds on it to fix would...
Same thing happened after a storm to ours. On the back of the fridge next to the motor to the left (you have to remove the panel) there was a red dial inserted. We turned it and the fridge worked again. (well one day so far).
Aug 15, 2010 | Refrigerators
Water leaking from inside the fridge
Clear ice build up from drain plug using hot water in a syringe. Works well I just did mine. Located behind access panel inside fridge. Blue tube running down the back. Pull down and remove ice from the drain at the top.
Jun 22, 2010 | Refrigerators
Water line for ice maker/cold water leaking underneath
Check your connection at the bottom of the freezer door, behind the kick plate. Also pull out your crisper drawers and check the cold water reservior. If this only leaks when the water dispenser is pressed I would try to track the line from the bottom of the freezer door back to where it goes into the refrigerator (behind the crispers) to the cold water reservior.
If you absolutely have to lay this fridge down lay it on it's BACK only. Also be sure to let it stand upright for at least a half an hour before you start it back up.
Good luck with this!!
Jun 14, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Water leaking from underneath. Not currently
This could be a blocked drain.Behind the fridge is a hose/pipe running from the inside of the fridge down to the compressor where the water will then evaporate.If this pipe is blocked,the water will push up back into the fridge.Try to blow the hose clean from inside the fridge.This should solve your problem.
Regards
Andre Nagel
Mar 13, 2010 | Freezers
GE GSH22JFR side by side refrigerator
Yes the water line has frozen in the door. There is a kit to repair this WR49x10173
Feb 09, 2010 | GE GSH22JFR Side by Side Refrigerator
A corner of the door has broken off and the door has dropped. The model is HE505UF hoover frost free contour fridge, can it be fixed or do i have to replace it
sounds crazy but u may be able to take a 1 1/2 " x 8" piece of flat metal bend at 90 degree angle. drill appropriate hole for hinge and screw to door. i've done it and it works.
Jan 21, 2010 | Hoover Refrigerators
Refrigerator has water underneath vegetable and fruit bis. It seems like an air flow situation
We found that the drainage for the defrosting was plugged. The water from the freezer drains from a hole that's on the top of the fresh food unit. There's a gutter that shunts the water to a tube that runs to a tray underneath the refrigerator. The tray was bone dry. So we unscrewed the gutter from the top of the fridge, and yes, it was plugged. Some Scrubby bubbles later, the plug was done. We reinstalled it, and now we don't have water underneath the vegetable/fruit bins.
This is for the GE TBF15DC For other models, your mileage may vary.
Jun 05, 2008 | Kenmore 64802 Top Freezer Refrigerator
Refrigerators Logo
115 people viewed this question
Top Hoover Refrigerators Experts
Charles T Nevin
Charles T Nevin
Jim Goldsmith
Jim Goldsmith
JONFRIDGEDOC
Level 1 Expert
Are you a Hoover Refrigerator Expert? Answer questions, earn points and help others
