Question about Canon DC100 DVD Camcorder
Camera is totally dead. Will not charge the battery and does not even indicate the power cord is attached when battery is removed for AC use.
  • 5 more comments
  • scubahal56 Mar 16, 2011
    Thank you, I have ordered the part you suggested
  • scubahal56 Mar 19, 2011
    Took your advice because you were positive it was the battery adapter causing the issue. For future reference if you are charging for your advice, please be sure your advice is sound. I replaced the battery adapter (because you were positive that was the problem) and nothing changed. IS NOT the battery adapter so I spent $25 for nothing, because you were sure it was the problem.
    Was told by eagle 338( he was positive) that a non power problem to my Canon DC100 was caused by a faulty battery adapter. I spent $25 for a new adapter to find out the adapter is NOT the problem. Your thoughts please. Camera is dead with battery installed or not, won't work with the cord attached, doesn't light up, totally non responsive.
    OK, how do I open the camcorder to check the DC power jack? Where is the DC power jack?
  • scubahal56 Mar 20, 2011
    Correct, doesn't matter if the battery is in , with the power cord attached the battery is still dead. I thought the camera was designed to operate without a battery as long as the AC cord was plugged in. No matter, dead as a door nail with the power cord plugged in with or without the battery. Is taking the camera apart I should attempt to do?
    Thank you for your thoughts. Kinda looked online for a new battery and they range from around$8 to $25. I'm leaning towards the $8-$9 battery as I don't want to waste anymore money than I already have. Will the cheaper ones be adequate to either isolate the problem as battery related or remove it from consideration?
    Thank you for your response. I requested a quote for repair and if it is too much I will take advantage of the turn in offer from Canon. I really appreciate your help!
  • Canon Master
  • 19,396 Answers
Hi.
Power adapter and battery do not fail at once and the adapter is already good. The problem is neither of these.
The power adapter should have been tested using a multimeter (see Multimeter)
If the adapter was good it would have read +_0.5V from the value in specification.
The camcorder is supposed to start with the adapter connected even if the battery is drained or if there is no battery. The battery is not the problem preventing the camcorder to start.
The problem is internal. The most common occurrence is a faulty printed circuit board. A short or a broken contact in the power ribbon cable are less common, but will give the same symptoms.
The camcorder must be disassembled and tested to find the problem.
If the unit is over one year old you can ask an online quote using this link:Repair.
Regards.
Ginko.
Posted on Mar 20, 2011
  • Ginko
    Ginko Mar 20, 2011
    Hi.
    Sorry to hear it that.
    The turn in offer from Canon usually offer good value. It looks like that is the best choice given the situation.
    All the best.
    Ginko.
  • Canon Master
  • 12,061 Answers
Hi, whenever a camera is completely dead, and it isn't the batteries and it isn't the AC adapter, then most often we find that the charging and conditioning power circuit, has gone faulty, this can happen for any number of reasons.There is simply NO WAY to DIY a sophisticated device such as this without considerable support, spare parts, and a service manual.
I'm my professional opinion the absolutely best thing to do, is to contact Canon,, either the head or a local office, and ask them for a referral to an Authorised servicing center. Either take it to them or ask for a service call. Now when in contact, ask for a "Quote" for the repair before allowing any repair work to be undertaken. This way you can then make an informed decision as to what to do, repair or replace. (Often clients prefer to put any large amounts of monies, that would have been outlaid on any repairs, towards a new/used modern set, with a warranty)
One thing to try is a brand NEW battery, if this rectifies the matter, then all good, ensure you charge it up correctly. Otherwise, well.. see above.
  • 4,889 Answers
If the camera shows no signs of life at all, then its definitely an issue with the battery adapter. I am positive that a replacement adapter will resolve the problem. It costs about 20$
http://www.amazon.com/Canon-DC100-DC210-Replacement-Adapter/dp/B00115QY44
Posted on Mar 16, 2011
  • 5 more comments
  • eagle338
    eagle338 Mar 16, 2011
    You are welcome. Thank you for using Fixya!
  • eagle338
    eagle338 Mar 19, 2011
    I couldn't have asked you to open the camcorder to check the DC power jack is damaged before confirming thats the problem can I?
  • eagle338
    Thats the only other possibility and before you open the camera to check the status of the jack I wanted to make sure it was not something else simple.
  • eagle338
    Would you have been happy to take the trouble to take it apart before being sure that its the problem? Like I said I wanted to be sure that the DC power jack of the camcorder was bad before I actually told you to take it apart.
  • eagle338
    The DC power jack is the one into which the AC adapter plugs in. We have to check if it has developed dry solders. Also by "the power cord is attached when battery is removed for AC use." does that mean that it does not run on AC power?
  • eagle338
    eagle338 Mar 20, 2011
    Yes it is a problem with the AC adapter. Sorry I did not understand your problem initially I though it was working on AC power. And yes taking it apart should fix it because the jack I am referring to is the one that receives the AC power and powers up the camcorder and since its totally dead that would be the first thing I would check. I will see if I can find a service manual for this camcorder and let you know. Please give me a few minutes
  • eagle338
    No I cannot find one in my collection, but I found one online even thoug its not free. The disassembly instructions in it should help you get to the power jack and see if it the solder joints that connect it to the mainboard are broken
    http://www.tradebit.com/filedetail.php/9...
    If you are unable to comprehend anything, upload a copy to mediafire.com and get me the link so that I can break it down for you
T will indicate charging but it won't charge actor
If the laptop works only off the Power Cord and the batteryis not charging, then the battery is dead.
To check to make sure the Power Cord is working remove the battery and let thelatop run for 10 minutes or so.
To check to see if the battery has any charge left in it put the battery in andremove the power cord. If it won't boot or shuts down then the battery is deadand needs to be replaced if the power cord is ok.
Apr 23, 2012 | HP Compaq nc6400 Notebook
Laptop Power Up Problem
Try booting under AC power with the battery removed.
Jun 05, 2008 | Gateway 400SD4 Notebook
When i remove my charger, the laptop turns off.
As lond as the battery is still accepting charge from the charger and will run ok on a battery, I wouldn't worry. Pulling the AC power cord isn't a good idea when the laptop is running anyway.
However, what you describe sounds like a dead battery that will no longer accept a charge. Even a battery showing 100% charged can still fail, as it drains in seconds if dead. What kills most batteries is leaving them in the laptop afetr they have charged and running on ac power.
Mar 27, 2011 | Samsung R519-53S Notebook
Its that the battery is not charging, and on the power meter icon its blinking four times orange and one time green. If I remove the battery, the laptop works with ac adapter. but if I reinstall the...
Check for a DC connector problem:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
Feb 06, 2011 | Dell Latitude D610 Notebook
Dell Latitude D620 isn't getting power to the mainboard.
diagnostic procedures as follows:
1. Turn off the computer and peripherals, and disconnect them from AC power.
2. Reseat each installed battery by removing it and then replacing it.
3. Turn on the computer. Does the green power indicator light up?
Allow one minute for the computer to initialize its components before checking for signs of power.
Yes. Continue to step 4.
No. Use the AC adapter to connect your computer to AC power. If the computer operates normally when using AC power, go to step 7. If the computer does not boot when using the AC adapter, see the previous subsection, "Total Power Failure When Using the AC Adapter."
4. Does the battery indicator flash amber or show a a steady amber light?
Yes. The battery needs to be charged. Go step 5.
No. Go to step 7.
5. Connect the computer to AC power, and fully charge the battery.
For instructions, see the topic titled "Charging the Battery" in the online System User's Guide.
6. As the battery charges, does the green battery indicator light up?
Yes. Go to step 9.
No. Go to step 7.
7. Is the battery indicator flashing green and amber?
Your computer may be in a hot environment. Charging the battery in this condition may affect the life span of the battery.
Yes. Continue to step 8.
No. The problem is resolved.
8. Disconnect the computer from AC power. Is the the battery indicator still flashing amber?
Yes. You may have a defective battery. Continue to step 9.
9. Remove the battery, and press its test button. Is the uppermost indicator in the charge gauge of the battery flashing?
Yes. You have a defective battery. Continue to step 9.
10. If a spare battery is available, fully charge it, and then install it in the computer.
11. Turn on the computer. Is the power indicator off?
Yes. Your original battery is defective. get a new battery replacement.
No. Call Dell for technical assistance.
if you need Dell latitude d620 Battery you can go to online shop
http://www.global-battery.co.uk
http://www.sales-batteries.com
here you can perchase high quality battery easily
good luck!
Feb 04, 2010 | Dell Latitude D620 Notebook
Compaq nx6320 won't power up
Replace your battery Some laptops don't boot up when no battery is present even it is connected directly on the power supply. Or if not to visit your nearest HP service center. If its still with warranty, use it.
Good luck kabayan. ^_~
regards,
-engrkoiled-
Mar 27, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Camera will power-up only when connected to DC
This from Sony website:
To ensure the proper operation of the battery, please do as follows after charging the battery.
(1) When charging by connecting the AC adaptor directly to the camera Pleasedisconnect DC IN from the camera after charging is completed. Also, itis recommended to remove the battery from the camera when charging iscompleted as the battery is discharged slightly even if the camera isturned off.
(2) When charging with the supplied USB cradle Ifthe camera is installed in the USB cradle, please leave the power cordconnected to the outlet (when using the power strip, please leave itsswitch to on).If you want to unplug the power cord (or switch off thepower strip) after the battery has been charged using the USB cradle,please remove the camera from the USB cradle. Also, it is recommendedto remove the battery from the camera when charging is completed as thebattery is discharged slightly even if the camera is turned off.
NOTE: When you charge the battery by connecting the AC adaptor directly tothe camera or using the USB cradle, do not leave it with the power corddisconnected from the outlet.
Should it not work, continue with the manual reset procedure below:
  1. Turn off the camera.
  2. Ensure the camera is not connected to an AC power adapter.
  3. Remove the battery from the camera for 15 seconds.
  4. Reinsert the battery.
  5. Turn on the camera.
NOTE: If the issue is not resolved by performing a reset procedure, service may be required .
Oct 09, 2008 | Sony Cyber-Shot DSC-V3 Digital Camera
DELL 600M AC POWER CORD
The internal power supply of your PC is broken, it needs to be serviced.
Feb 13, 2008 | Dell InspironTM 600m Notebook
Dead laptop
Check the ac adapter is the proper one for that laptop. Check the power jack is not damaged or loose. let laptop site without battery or power for a few hours. remove battery and retry power. try another ac adapter if that doesn't work, you may have a reset button but not likely to solve the problem. sounds like motherboard is damaged, or something blew.
Aug 27, 2007 | Compaq Presario M2000 Notebook
Power cord and battery's support NO power to Video Camera
This incident happens often and damages the camcorder's power board. Replacing power board and some adjustment should resolved the problem. Your cost may run from $175-$225 in US for this model. Whenever you are transfering and connecting to pc, it is recommended to connect AC adapter power for this. Do not rely on a charged battery. Good luck.
Mar 17, 2007 | Canon Optura 50 Mini DV Digital Camcorder
Canon DC100 DVD Camcorder Logo
115 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
