Question about Samsung Computers & Internet
I have an Samsung monitor "gh19ps". This monitor is intermittent. Sometimes it comes on other times not. On/off button light is flashing when off. Other monitors work with computer.
MUKHTAR
  • 2017 Answers
SOURCE: Monitor blacking out intermittently
it is monitor power problem pls change the power cord and see. bye
Posted on Sep 24, 2007
skotkolr
  • 558 Answers
SOURCE: FP531 Monitor flashes 'Benq'
sounds like an internal issue with the power board service tech should look at it
Posted on May 10, 2008
bammbammfran
  • 159 Answers
Monitor going black after a few seconds can be causd by a faulty power supply or inverter. Some monitors have both as one unit.
Sometimes it is basic failed capacitors, After that then I would look at transistors.
The average monitor from 17 to 20 and sometimes the 22s have usually 4 bulbs in them. One bad bulb will also cause the inverter to not fire up.
Bad bulbs usually show pinkish tint, or flickering or are dark at center top or bottom of the display.
ebays bammbammfran
Posted on Oct 05, 2008
Fix-4U
  • 293 Answers
SOURCE: Samsung 940 BW Monitor Not working (Black screen)
Hi...there,
That's indicated your backlight inverter are busted. Need to replaced a new one or repaired it. To repaired look for a bad capacitors with a bulged on top of each caps. Not sure, just replaced all the caps... Have a nice weekend!
Posted on Oct 11, 2008
SOURCE: BENQ FP737S Monitor shows "No Signal Detected" on startup
first problem could be the hdmi cable you are using is loose or broken.second, the display mode you selected was wrong, try to go to desktop and right click and choose nvdia control panel and choose the nview display mode to use,select the only use one display(single)and apply.
Posted on Jan 27, 2009
Why does it switch on and off intermittently?
Check the power supply circuit for bad capacitors, you can tell which are bad by their bulging tops.
May 15, 2015 | Samsung Televison & Video
Samsung gh19ps flat screen won't turn on but the green power light comes on
If you have a power light then there is a couple easy things to check. Make sure the input on the tv is properly selected to match the input you have the cables in. The second would be verifying that your cables are good.
Nov 17, 2013 | Televison & Video
It seems like im having some issue with my syncmaster2493 monitor. it will black out and once i wiggle the power cord it will come back on. any help will be apprecaited
Your power supply board is failing and when you wiggle the cord it is turning it on and off until it finally starts up. There are parts called capacitors that start failing and it will cause intermittent power issues such as slow to show picture, flashing power button, wavy or flashing picture. The board can be repaired and the monitor will be as good as new. Here is a picture of the power supply with the parts circled that need to be replaced.
There is a step by step repair guide for the Samsung 2493HM unit here:
http://www.ccl-la.com/blog/index.php/reparing-a-samsung-2493hm-24-lcd-monitor/
I hope this helps, if so please rate my solution.
BuddyMc
Jul 30, 2011 | Samsung SyncMaster 2493HM Monitor
Tube does not turn on
If TV model is Sony KV-32HS420 then mostly it requires to replace 2 ICs on DZ board, let me know if you can replace ICs on circuit board and know about TV repair to provide you more technical info.
Thanks.
Sep 16, 2009 | Sony FD Trinitron WEGA KV-32HS420 32" TV
How do you hang a samsung gh19ps monitor upside down?
Hi there!
I'm not sure why you'd want to hang the monitor upside down, but your best bet would be to purchase a wallmount, attach the monitor upside down and mount the fixture right-side up. Click HERE to see an example of a wallmount Amazon.com sells that will work.
Hope that helps!
Aug 31, 2009 | Computers & Internet
I have just gotten the Samsung syncMasterP2570 monitor and the on button is just flashing and monitor does not come on. When I take out the Dvi or the hdmi I get the auto light flicking. I know that is to...
Your samsung monitor has a bad power mosfet connected to your backlight driver. Or if not you have a bad backlight or bad capacitor's. This problem is normal to samsung syncmaster monitor.
Jul 24, 2009 | Samsung Computers & Internet
Funny monitor problem
If I were you I would invest in a new video display card. Sounds your card is intermittant, because the chances of a tube type display and a TFT display having the same problem is slim to none. LOL Good Luck Please dont forget to rate this thread
Oct 20, 2006 | Samsung SyncMaster 540N 15" LCD Monitor
Computers & Internet Logo
69 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
