Question about Shimano Cycling
I require an instruction manual on how to maintain and set the gears and brakes on the shimano alivio system which is on a giant strata 2010 mountain bike
  • yadayada
    yadayada Mar 16, 2011
    No such manual available on line.
    Sergeant:
    Champion:
  • 205 Answers
Below is a link to the tech docs for the Shimano Alivio system look for the specfic componet you would like to adjust. The links with SI are the Service instructions. EV are the parts lists.
Shimano Alivio System info
Hope this helps.
Zeppelinx12
Posted on Mar 16, 2011
Hi! I bought a 2nd hand bike - actually it is more 3rd or 4th hand. The brand is called "Gazelle" and brakes and gears are from Shimano. Model Type of gears: Shimano Alivio FD-MC14, seems to be...
http://www.parktool.com/blog/repair-help/front-derailleur-adjustments
If you mean you can't get to the LARGE chainring, that would follow as the cable must be pulled the farthest to get to it. There are limit screws for each end of the derailluer's motion. You're probably fighting that adjustment. With the shifter tension on the cable totally relaxed (small chainring position) you should be able to manually grab the front derailleur cable as it runs along the downtube and, while pedaling the suspended bike, pull it away from the downtube and reach the highest chainring and, when released, the lowest chainring without dropping the chain. That's what the limits are for. THEN you adjust the cable tension and tweak it all. Web search for procedures like "how to..." just about anything and many resources will appear, some with video.
Sep 06, 2011 | Mountain Shimano Alivio Front Bike...
Is there a Bianchi bike owners manual so I know how to adjust the gear lever?
Look on the brake lever for a manufacturer and model number (probably Shimano). Even if you can't establish a model number, go to the website and find the mountain bike shifter that is closest to yours, There will probably be a technical manual for it and it will describe how to install and adjust it. You'll also want to look for and understand the derailleur it controls.
http://techdocs.shimano.com/techdocs/index.jsp
Dec 26, 2010 | Bianchi Mountain Bike 19"/49cm
Good evening - I have Shimano Alivio Gears on my Cannondale F6 MTB and the gears are trying to change down a gear on the rear cogs (go to the larger cog) and need adjusting - which screw is the one to...
Neither screw is for mis-shifts. Those are limit screws for the largest and smallest cogs. Tweaking the cable tension will usually bring in the indexing...
http://www.parktool.com/blog/repair-help/rear-derailler-adjustments-derailleur
It sounds like your cable is/was a smidge too tight.
Aug 14, 2010 | Mountain Shimano Alivio Front Bike...
Bleeding hydraulic brake systems
hello there;
you should be able to bleed the brakes just like a car brake system with the bleeder valve on the barake caliper make sure the reservoir is full before you start the proses and use the brake lever to pump pressure into caliper and crack the bleeder valve until you get all the air out of the lines you may have to repeat couple of times to ensure proper brake pressure
May 29, 2010 | Shimano Saint Hydraulic Mountain Bike Disc...
I have bought an Alivio front gear. Do I have to break the chain to fit it?
The easy answer and solution is yes, which will give you the opportunity to fit a handy little device called a missing link, which will allow you to remove your chain for cleaning in the future. They are available at bike shops and cost about $6.
Dec 30, 2009 | Mountain Shimano Alivio Front Bike...
7 speed alivo shifter no down shift
Hi log onto shimano.com and you will find what you are looking for
Oct 15, 2009 | Mountain Shimano Alivio Front Bike...
Problem with top/low adjustment screws on shimano gears
Forget the screws as those are more for fine tuning once you are close to having it set correctly. Where the shift cable connects to the shifter on the bars you will typically find an adjustment knob (note that you may have the same type of adjustment knob where the cable meets the gear shift mechanism also) which the cable rides in. You will make much larger jumps in adjustment when using this method as opposed to using the screws located on the gear changing mechanism. Best of luck to you on the fix!!
Please be sure to rate this solution.
Regards,
Joe
May 08, 2009 | Mountain Shimano Alivio Front Bike...
Cycling Logo
560 people viewed this question
Top Shimano Cycling Experts
Michial Gueffroy
Eric Hidle
Level 1 Expert
Mike
Are you a Shimano Cycling Expert? Answer questions, earn points and help others
