Question about Vtech 5.8 Ghz Handset Cordless Phone System with Digital Answering & Caller ID
One of my handsets has a barely audible dial tone. the volume is set at the highest level possible. i've already put new batteries in twice, but the volume stays extremely low. what could be the problem?
  • 12,061 Answers
Hi, often these phones ear pieces fault. it is a simple matter, and inexpensive to replace the ear unit. you need to have this attended to by the Vtech repair center. Contact Vtech, and ask them where to get your unit attended to.
Posted on Mar 17, 2011
HOW TO INCREASE VOLUME IN XOLO A500S
here are some steps to increase incall volume
open your dial pad thwn input *#*#3646633#*#*
go to hardware option nd select audio then select sph.....select level 6 then select volume lwvel at 160 then press on set key
now reboot your dewice
The first step is to get in the "Engineer Mode" by pressing the following set of keys in the dialpad "*#*#3646633#*#*"
Xolo A500s low microphone volume fixby Sbplus 20/09/2013 ' 3:39 6 Posted in Tutorials
If you are a Xolo A500S owner, then you might have noticed the low microphone volume on this handset. So think no more, just follow these simple steps and this problem will be fixed.
You can watch the video or follow the steps below.
The next step is to go to the " Hardware Testing " and select " Audio "
Now select " Normal Mode "
From the dropdown, select " Mic "
Now we will increase the value to the highest possible number, which over here is "255" You can also select the level as " level 6 " , which will set the maximum value.
Now press "set" to apply, and then restart/reboot the handset.
Repeat the procedure if the settings are not saved the first time.
Sep 09, 2013 | Cell Phones
The handset lights up and the incoming number is shown but you dont hear it ringing
Many times there is a volume switch on the actual handset itself. Most commonly on the left side of vtech devices. there are three different volume levels. By pressing up on the button you should be able to turn the volume up until it has an audible tone confirming volume change. Handset should ring with incoming call when audible tone is heard by pressing up on volume button.
Oct 13, 2010 | Vtech DECT 6.0 Cordless Phone with Digital...
Re Sony VAIO F12 (new unit): Audio is barely audible using onboard and external speakers, even though volume bar indicates volume is at highest level. Any way to increase audio volume? Thanks.
1. Yes, check to see if you have the volume up for the wave file turned up that is on the program you are using to listen to the Mp3 or sound wave with.
2. check the speaker connector/ Use another speaker that is know to be good and test. Use a set of earphone in the output jack also to test the output.
If these things are doing the same then you have failing sound card and it needs replacement.
Aug 10, 2010 | Sony VAIO FR130 Notebook
The phone is not ringing and it is plug on charge and my wife got new battery for it too. What can i do to get it working? What size of Batteries cani use for this cordless phone
You need the specific battery pack: 5-2814 for the handset. This is a 850 mAh Nickel Metal hydride battery.
When I see a cordless phone that doesn't ring, the first thing I recommend checking is the phone jack and line itself with a second phone. I prefer to use a corded handset with a new phone cord to check for dial tone. If no dial tone at the jack, check for dial tone at the service entry box. If you have no dial tone at the service box, contact your provider. If it's only a problem at the jack, you will need to check your inside wiring.
To check the base, try a new cable (RJ-11) (double check the power as well).
To check the handset, first make sure the handset is fully charged (16 hours) and that the battery is fully installed. Does the handset beep when the Talk button is pressed? Next check that the handset ringer software is on. With the phone off (not in the talk mode), press the Mute/menu OK button. Use the Caller ID/volume (up/down) buttons to get to the Handset setup menu. Press the Mute/Menu OK button to access the menu. Use these buttons to check the Ringer Volume (should be on) and Ringer Tone. Press Mute/Menu OK to save the settings at each sub-menu. Check that the Do Not Disturb function is not on - this toggles with the Do Not Disturb button and should be noted on the handset screen when on.
If you have multiple extensions on the phone line, try unplugging some of them.
I hope this helps.
Jul 07, 2010 | GE T28821FE2 19 GHz Twin 1Line Cordless...
No dial tone pressing hook, NG and Poor line condition transmission report on sending and receiving. Confirmed good dial tone on line in and on phone on ext. Copy, display, everything else fine. I hear...
Make sure that you have your telephone line from the wall jack plugged into the port on the fax that says "LINE" and that your telephone is plugged into EXT.
All your cables and jacks seem like they are working since your phone gets a dial tone, the onyl thing could be that the wires are mixed or the modem on the fax is broken.
Thanks,
Pat
Mar 27, 2010 | Brother Multi-Function Center MFC-240C...
Cit200
Adjusting the volume of the caller's voice
You can increase or decrease the volume of a caller's voice during a call. There are 5 volume levels for selection.
To adjust the volume, during a call: While the phone is off hook (i.e. dial tone can be heard), press Up or Down.
The display shows the current volume level. Press Up or Down again to adjust the volume.
Still can't find the most comfortable level?
Besides adjusting the volume on the handset, you might also need to adjust the volume on your PC in order to set the speaker to the most comfortable
volume.
To set your handset's ringing melodies and volume:
1. Press MENU.
2. Press Up or Down to select SOUNDS. Press OK.
3. Press Up or Down to select HANDSET. Press OK.
4. Press Left or Right to change the volume level. Press Down.
5. Press Left or Right to select the external melody. Press Down.
6. Press Left or Right to select the internal melody. Press OK to confirm when finished.
Nov 01, 2008 | Linksys CIT200 IP Wireless Phone
When the radio is powered up a a constant buzzing noise is present. This noise is at the same audible tone when the radio is set to any volume level and whether it is set to CB, or weather selection... ...
If this is a high-pitched tone it probaly is from the DC-AC inverter that provides the high voltage to light up the front panel. Normally, this is barely audible, but I've seen a few that are loud enough to be annoying. It may be possible to install a small filter in the power line to the inverter, inside the radio. I've never tried this but if the inverter is the source of the noise, this will be the most practical way to isolate ite & eliminate the problem.
This should onlty be attempted byan experienced CB technician.
Sep 26, 2008 | Uniden PC78ELITE 40-Channels Base CB Radio
Cant get one of the phone to get dial tone says unavalibel
All you have to do is put the phone that does not get a dial tone on the MAIN CHARGING BASE for 20 seconds! it will then sync up!
Jul 17, 2008 | GE 25931 Trio Cordless Phone
GE 28851 base handset #1, will not save ringer tone or volumn I selected. Brand New.
As it turns out, the primary base handset did save the newer selected ring tone and volume level setting.
However, the base maintains its own ring tone and volume level setting from factory.
Therefore, the base will present its own settings along with the handset setting during an incoming call.
So, one has to lower the volume of the base (in non-talk mode). The base should display in window: LO.
Then, only the ring tone and volume level selected for handset will be presented during an incomiong call.
How did I do????
Ken
Jul 09, 2008 | Uniden Cordless Phone
Vtech 5.8 Ghz Handset Cordless Phone System with Digital Answering & Caller ID Logo
97 people viewed this question
Top Vtech Lands Phones Experts
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
