My HP pavillion dv6338se wont bootup. The Blue LED light on the top just keeps on blinking but the LED on the "Caps Lock" & "scroll" botton does not. Kindly give me an avdise on what to do. Thanks
  • 39 Answers
You should try to unplug the laptop and remove the battery. Wait 1 minute and then put the battery back in and plug it back in. This will reset the laptop and should allow it to boot up.
If this helps please rate and vote for me. Thank you.
Posted on Mar 16, 2011
How do i fix a problem of green power led continuously blinking in Hp compaq nc6320 laptop even when the battery is removed and the motherboard is outside the case?
HP Notebook PCs - Troubleshooting LED Blink Codes or ...
h20564.www2.hp.com/hpsc/doc/public/display?...na...
Hewlett?PackardHP Notebook PCs - Troubleshooting LED Blink Codes or Beep Codes During Startup or Boot ... HP Pavilion and Compaq Presario notebook computers built in 2009 or later use blinking LEDS to identify ... Press the power button to turn on the computer, and look for blinking LED lights on the keyboard. ... Continuous blink.Missing: green ‎nc6320
HP Notebook PCs - Computer Does Not Start and Emits an ...
support.hp.com/us-en/document/c01732674
This document pertains to HP and Compaq notebook computers. .... light next to thepower socket or the light on the AC power adapter and note its condition: off, blinking, or constantly on. ... Battery power LED off, and Caps Lock/Num Lock off.Missing: green ‎nc6320
HP 6735s won't boot, power LED blinks 7 times - HP ...
Feb 03, 2016 | HP Computers & Internet
My laptop screen is black and caps lock and scroll key are flashing
That is a security configuration on HP Laptops, depending on the way they blink is the problem your machine has.
Here is the web page where this info is posted, in case you need more info, hope this helps you to determain.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01443366&lc=en&dlc=en&cc=uk&lang=en&rule=26781&product=3816592
This document pertains to HP Notebook PCs with the HP Unified Extensible Firmware Interface (UEFI) beginning in late-2008. On startup, you may see a blank screen. If the diagnostic utilities detect a specific problem with hardware components, the fan turns on, but the screen remains blank. To help identify the cause of the problem, various LED lights on the keyboard blink a series of codes. The diagnostic utilities use the LEDs near the Num Lock or Caps Lock keys to blink a series of error codes. At the end of the series the blinking stops. The pattern of blinks will occur any time you attempt to start the computer until the error is resolved. Battery power LED blinks The Battery power LED indicates the condition of the power supply. When starting the computer, or when the computer is in operation, use the chart to identify the power condition. Battery Power LED Component Tested Error Condition Battery power LED off, and Caps Lock/Num Lock off Battery or AC Adapter AC adapter not connected or failure
Battery low charge or failure Battery power LED blinking Battery Insufficient charge on the battery When new computer is used for first time, the white LED light for the AC power connector blinks. Battery is still in "Shipping Mode", the light continues to blink even when AC power is connected.
To resolve, turn off notebook, connect AC power and allow battery to charge for at least 30 minutes, then start computer. LEDs near Caps Lock and Number Lock keys blink when starting notebook The LED lights near the Caps Lock and Num Lock keys will blink if an error is detected during the start up process. The LEDs will blink a number of times in a sequence and then stop. The number of blinks in the sequence indicates what component caused an error when it was being tested during start up. If the LEDs stop blinking and the computer does not start, you can press the power button again to repeat the tests. Count the number of blinks, and use the chart to identify the error condition. Knowing the number of blinks is helpful when you contact an HP support agent for technical help. Caps Lock/Num Lock LED Component Tested Error Condition LEDs blink 1 time CPU CPU not functional LEDs blink 2 times BIOS BIOS corruption failure LEDs blink 3 times Memory Module error not functional LEDs blink 4 times Graphics Graphics controller not functional LEDs blink 5 times System board General system board failure LEDs blink 6 times BIOS BIOS authentication failure
Dec 01, 2011 | HP Computers & Internet
On My Dv5-1125nr both the caps lock and num lock keeps blinking when i turn it on. It's wont boot at all. What kind of hardware problem is this?
First remove the battery and power cord for about a minute. Then plug back in and see if that helps. Otherwise please read the following:
Aug 03, 2011 | HP Pavilion dv5-1125nr Notebook
Compaq 6735s notebook pc goes to HP screen, but wont boot
First you need to determine how many blinks you are getting when you try to power on the laptop.
Check the blinking codes below and reason behind that for HP Compaq laptops
Blinking battery power LED Battery Insufficient charge on the battery
Blink: 1 - Caps Lock/Num Lock - CPU CPU not functional
Blink: 2 - Caps Lock/Num Lock - BIOS BIOS corruption failure
Blink: 3 - Caps Lock/Num Lock - Memory Module error not functional
Blink: 4 - Caps Lock/Num Lock - Graphics Graphics controller not functional
Blink: 5 - Caps Lock/Num Lock - System board General system board failure
Blink: 6 - Caps Lock/Num Lock - BIOS BIOS authentication failure
Plz get back so I can suggest you the steps to resolve the issue.
Dreamkam
May 24, 2010 | HP Compaq 6735s Notebook
My laptop does no more boot up. As soon as i start , the caps lock and the scroll lock lights keep flashing continuously and the fan even does not run.
Well hellonihar, As far as your issue is concerned it seems to be some hardware issue. LED
Component
Error Condition
Battery
CPU
CPU not functional
BIOS
Memory
Graphics
System board
BIOS
Apr 19, 2010 | HP Pavilion dv5-1000us Notebook PC
HP DV6110us: 4 beeps, no boot
besides the beeps which indicate a motherboard timing issue. There should be LED blinking codes given on the front LEDs. I will include the blink codes below, but lets try to at least get the system up and running. First, I would like you to remove the RAM sticks from the laptop and just reseat one stick back in the machine. Try to boot with that one stick, if it does not, try the other alone. There have been issues when reseating the ram or re-installing it have temp. fixed the issue. If it does reboot, go to the HP support site, put in your model number of your laptop and download and install an updated BIOS. Below are the blink codes that may narrow down the problem.....
HP DV6000 LED Blink Codes
LED Component Error Condition
Blink: 1 - Caps Lock/Num Lock CPU CPU not functional
Blink: 2 - Caps Lock/Num Lock BIOS BIOS corruption failure
Blink: 3 - Caps Lock/Num Lock Memory Module error not functional
Blink: 4 - Caps Lock/Num Lock Graphics Graphics controller not functional
Blink: 5 - Caps Lock/Num Lock System board General system board failure
Blink: 6 - Caps Lock/Num Lock BIOS BIOS authentication failure
Oct 22, 2009 | HP Compaq Pavilion dv6110us Notebook
Hp Pavillion Tx1320us..wont boot up
You're probably one of thousands of victims of defective nvidia chipsets in these systems. Call HP and complain.
Jun 08, 2009 | HP Pavilion TX1320US Tablet PC
Hp power on problem
Sounds like your hard drive problem.
Jul 22, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
178 people viewed this question
David Payne
David Payne
