Question about Epson Computers & Internet
How do I stop my ink from going so fast - Epson Computers & Internet
  • 981 Answers
You can print lighter, but I can't help wonder why your Epson Desktop PC uses ink! Perhaps you mean printer instead, and know what model it is? Make a question in the right category!
Posted on Aug 02, 2008
My printer got wet when ink spills out what will i do?
The best thiNg to do is to give to an engineer to open it up and clean it up for you fast before it will affect the panel/mechanisim
Aug 05, 2014 | Canon PIXMA MX330 Multifunction InkJet...
Trying to scan but says low ink and wont scan
You can go to printer preferences and change the setting to print Fast and Grayscale. That should allow you to scan and print if needed until the ink cartridges are replaced.
Mar 06, 2014 | Canon MP560 All-In-One InkJet Printer
HP Officejet 5610 All-In-One InkJet Printer - printing any kind of document, from many formats (docs, pdf, photos) takes more than 15 minutes for one page to print. Tried restarting computer, printer,...
When you click to print something, you will get what's called the Print Dialogue box. Before clicking "OK", click the Properties button.26849353-6c28-4abb-ab9c-b5e445a1b08b.jpgThis will take you to a screen with some tabs. Click on the Paper/Quality tab. Somewhere in that window you will see some options for "Print Quality".
By default, it is probably set to "Normal". That's the middle setting. To save ink, you can set it to Fast Normal (better for ink saving) or Fast Draft (best for ink saving). This means the printer will use less ink to print the page. The final copy will look a little lighter but certainly still readable.
This option "fast draft" will print very fast and also save your ink.
Oct 16, 2013 | HP Officejet 5610 All-In-One InkJet...
In standby mode - the printer (cannon ip 1880) keeps on rotating in side so that my cartridges keep on moving from left to right and run out inks fast....?
This is the purging operation being carried out. It is quite normal to stop the ink from going hard in the printhead.You can always turn the printer off when not in use.It will do it no harm.
May 20, 2011 | Office Equipment & Supplies
I was printing several pages & it just stopped working. the ink button & on button flash. Changed the ink cartridges but still get the same blinking with no printing. Turned both the computer...
Press the Ink Cartridge Replacement button and check the flash pattern of the control panel lights:
ERROR and POWER lights flash at the same speed = replace black cartridge
ERROR light flashes twice as fast as the POWER light = replace color cartridge
Jun 04, 2010 | Epson Stylus Photo 1280 InkJet Printer
Everything seems ok on my printer but when try to print something it comes very light not dark enough
Generally one can set the "Print Quality" in printer "defaults" often they are noted as, Fine, Normal, Fast Normal, Fast, or similar... now that means the amount of INK on the page, the faster you go, the less ink... the less darker it is. Try setting your printer to it Highest/best quality setting see if that helps.
Feb 05, 2010 | Office Equipment & Supplies
Canon MX700 printer ink lamp fast blinking
1) Insert both ink cartridges and then check the ink levels that way it will tell you if there is something wrong with them.
2) Make sure you buy 1 colour ink and the other black and insert them into the correct slots.
3) Contact your printers manufacturer by going on there website. They may have a live chat.
4) Try this link: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15651
Nov 03, 2009 | Canon MX700 Office All-In-One InkJet...
Ink cartridge full, but printing as if out/low
I have found using 3 r d party inks in Canon printers will mess them up fast but the ones with the contacts don't work period
Dec 01, 2008 | Canon PIXMA MP510 All-In-One InkJet...
My HP printer's light blinks, but it doesn't print.
two things to consider.
1. If the blinking is fast (like more than two blinks per second) then the printer is damaged. Either the main controller board is fried or the carriage/ink controller is damaged.
2. if the blinking is slow ( 1 blink per second) this means that either of your cartridges is busted. remove the black cartridge then close the top cover. If the blinking stops, then the black ink is the culprit. If not, replace the black then remove the other cartridge. THis means that one of your cartridge needs to be replaced.
Sep 27, 2008 | HP DeskJet 3940 InkJet Photo Printer
PRINT IN BLACK WITH COLOR CARTRIDGE?
Yes, you can print out in black from a color cartridge, however it is not advised as you will run out of colored ink twice as fast as it combines all the colors to get black.However it works great when your in a pinch and need black ink.
Just go to your printer properties when you print and the option will be in there someware.
Dec 26, 2007 | Canon MultiPASS MP390 All-In-One InkJet...
Computers & Internet Logo
26 people viewed this question
Top Epson Computers & Internet Experts
teamtech
teamtech
Are you an Epson Computer and Internet Expert? Answer questions, earn points and help others
