Question about Honeywell Computers & Internet
I have a Honeywell 6100 pda this computer must connect to AS400 (iseries) through an ODBC ClientAccess sometimes connects but in most cases fails. We review the ODBC and it works. What can cause this problem?
  • 197 Answers
Who is server
Posted on Mar 19, 2011
I want to print Greek Language fro AS400 to Monarch 9855. How I do it?
This is not an easy explanation through this type of forum without some back and forth, so please call 1-800-547-6650 (if in North America), option 7. Ask for Tabletop technical support.
If in or around the UK Tel: 44 (0) 1279 786 000
Sep 04, 2013 | Lenovo Ibm As400 Iseries 9406-800 2793 Pci...
The syncronizing software for OZ-290HII will not work with my computer,though it installs,it keeps saying (file export failed) and this unit has a USB cable. I followed all the instructions but that...
Hello Sr,
Kindly read this, it may help you.
When the software that lets your computer communicate with your PDA acts up, always check the cables and connections first. Is the USB (Universal Serial Bus) or serial cable connected securely to the PDA (or cradle) and the PC? Is the PDA seated properly in its cradle if it uses one? If everything is in place, visit the palmOne (www.palmone.com/us/support/downloads) or Windows Mobile (www.microsoft.com/windowsmobile) Web site and download the latest version of the HotSync or ActiveSync software that is compatible with your PDA and your computer's OS. Keeping synchronization software up-to-date is important because newer versions fix compatibility problems and usually add new features.
If you have a Palm OS PDA that uses a USB connection, sometimes incompatibilities exist between Windows and the software that you can resolve only by running a special USB utility found at the PalmOne download site mentioned previously. Select your hardware from the drop-down list and click the USB Registry Utility link. Download the USBRegClean.exe file, navigate to the downloaded file, and double-click the icon to install it. Reboot your computer and reinstall the Palm Desktop and HotSync Manager.
...contd
Mar 09, 2008 | Computers & Internet
I cant set the printer with as400
Turn the printer off
Enable auto config in Systems Value QAUTOCFG see ...
http://publib.boulder.ibm.com/infocenter/iseries/v6r1m0/topic/rzarl/rzarlautoconfig.htm
Then turn the printer on
If the printer descriptor doesn't get created automatically, use
CRTDEVPRT command see:
http://publib.boulder.ibm.com/infocenter/iseries/v5r3/index.jsp?topic=%2Fcl%2Fcrtdevprt.htm
Dec 28, 2010 | TallyGenicom 6306 Matrix Printer
Zebra TLP 2844-Z appears to print from the iSeries/AS400 but nothing prints no error message Set up same as other Zebra printers that are working printing bar codes
check the connection configuration (if is com port, check speed, flow control and others)
Try to install locally with segull drivers (www.seagullscientific.com) if you need, reset to factory defult. print a test label from the driver. if is comunicate, is not printer problem, is connection problem with your software.
Aug 17, 2010 | Zebra TLP 2844-Z Thermal Label Printer
ZEBRA printing issues via AS400
*SAME
*WSCST
ZEBRA
*LIBL
*NONE
'10.27.9.21
Jun 26, 2009 | Zebra 105Se Thermal Printer
Re: Printing Garbage
I believe you have this setting incorrect: the MFRTYPMDL should be *IBM6400EP. That is because you want the AS400 to send out plain old ASCII to our printer. It is an ASCII printer and not a HP. The codes are different.
Aug 05, 2008 | Printronix P7005 Matrix Printer
USB Connection
Hi floinmist .
Westell 6100 modem by default can only be used for 1 PC . It cannot orit is not enabled to use for 2or morer computers as it creates a conflict within. Ethernet connection is the BEST connection for you to use.> your USB is sent to you by you provider { ISP} or by westell packages. Its is only a spare cable just in case your PC doesnt support ethernet connection ,  nothing else.
To resolve this issue you might want to upgrade your modem to a router w/c is westell versalink . You can connect 2 or more computers  { wired or wireless connection } and is more stable compared to your westell 6100.
Connecting 2 computers could cause slow, intermittent and NO connections at all problems.
IF you have other questions pls feel free to ask and let me know if theres anything ii can assist you with .
Best wishes.
Prince
May 02, 2008 | Westell Wirespeed LiteLine 6100...
Printronix p5010 with AS/400 IBM server
I can get the P5010 printing on your AS400... But, there are to many things to check without knowing a little more about your environment.
If you can't ping the PTX P5010 from the AS400 or a PC, then you have a printer configuration problem.
Take the printer offline and hit the Print Config button. and then the enter on OPs Panel. Then post top or first paragraph of the config. so I can look at...
__________________________________________________________
If you can ping the printer from the AS400...
You will need to create a remote out que on AS400... command is crtoutq then hit F4...
if you can't post the printer config here... Fax it 972-233-7306, Attn: P5010, Toby
Dec 12, 2006 | Printronix Line Matrix P5010 Printer
Computers & Internet Logo
91 people viewed this question
Top Honeywell Computers & Internet Experts
Ron Dufek
Ron Dufek
Les Morrison
Les Morrison
Are you a Honeywell Computer and Internet Expert? Answer questions, earn points and help others
