Question about Fuji FinePix Z1 Digital Camera
When i turn on my camera, it says on the screen 'protected card' and i can't delete or take any pictures.
  • 6,831 Answers
Hello
Thank you for using Fixya!!!
Before you try anything, try using another card. If the problem persists, try the suggestions below.
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Mar 16, 2011
  • 6,771 Answers
Remove memory card from the camera, look along the one edge and you will see a tiny switch, slide it towards the contacts to unlock the card, the switch in the furthest position from the contacts is in the locked position to protect the photo's from deletion. Now! if the card is in the unlocked position slide it back and forth to reset the card, If that fails replace the memory card.
Kodak easy share c183 memory card protected how to reset
Camera LCD: "Memory card is protected (Reset ... - Kodak
support.en.kodak.com/.../camera-lcd%3A-memory-card-is-protect...
KodakAug 25, 2010 - The camera screen displays "Memory card is protected (Reset switch on card). ... The memory card is locked so that data (pictures, videos, or files) ... The disk is write protected." when writing to or formatting an SD card. Share.
[PDF]KODAK EASYSHARE C183 Digital Camera
resources.kodak.com/support/pdf/en/manuals/.../C183_xUG_GLB_en.pd...
Kodak, EasyShare, Max, Perfect Touch, and Pulse are trademarks of Eastman Kodak. Company. ..... Access to more manual settings than Smart Capture mode. ..... NOTE: To delete protected pictures/videos, remove protection before deleting.
Jan 26, 2016 | Kodak Easyshare C183
PROTECTED CARD CANNOT DELETE PICTURE
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Dec 03, 2013 | Fuji Finepix S1500 10.0 Megapixel 12x...
I was trying to upload pictures from a Olympus VG-110 micro sd flash drive. and i couldn't see the files saved in it.. why is this happening? Then we put the back the disk in the digicam and after turning...
SD cards (and most microSD adapters) have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
And yes, formatting the card will delete all the pictures on it.
Sep 13, 2013 | Olympus Vg110 Vg-110 Red Digital Camera...
How to unlock a photo in camara
The protect function allows a user to protect a picture from accidental deletion. To unprotect a picture on your camera, scroll to the protected picture that you want to delete, then press the Menu button (the button to the right of the Play button.) Scroll down the menu and you should come to an option that allows you to Protect/Unprotect the picture. Since your picture is currently protected, deselect that option. You should then be able to delete the picture normally.
Alternatively, you could also format the memory card, however this deletes ALL photos and data you have on the memory card. If you are trying to completely clear the memory, this is the best way. After turning on your camera, simply press the Menu button, scroll to Setup, then scroll down to Format. Select Format, it will ask you if you want to format the memory card, or the camera's built-in memory. Format whichever one you want to clear, if you are using a memory card then your pictures are stored on the memory card. It will take a few seconds to format.
Hope this helps.
Dec 05, 2012 | Kodak EasyShare M1033 Digital Camera
My 7 year old daughter has used her camera, and some photos and viseos have a green key on the screen. Is it possible to remove the "lock" so the photos and videos can be deleted? I have loaded...
What make and model camera? On most cameras you unprotect a picture the same way you protected it, possibly by pushing a "protect" button. No matter what, you can clear everything off the card by formatting it. Cards should be formatted each time after you download pictures to a computer instead of deleting individual pictures. FixYa is full of people asking how to salvage pictures from cards they didn't format.
Mar 19, 2011 | Cameras
Camera says memory card is write protected. How can I delete pictures on the card and take new ones?
write protection lock is turned on,, turn it off this maybe 1. a switch located in the camera 2. on off option in the camera menu else plug the camera to memory card reader to delete or format the chip :)
Dec 15, 2010 | Nikon COOLPIX S51 Digital Camera
Canon PowerShot SX20 IS Digital Camera keeps giving me a memory card error. The memory card is a 4gig PNY memory card (lower budget)
Make sure the slide switch on the side of the card is unlocked. Your camera may just want you to format the card in the camera. Download any pics from it first using a card reader if necessary.
Jun 22, 2010 | Canon PowerShot SX20 IS Digital Camera
Protected card pops up and i can't take or delete any pictures, but i can look through the pictures.
remove the card. there is usually a switch on the side. turn it to the other position.
Apr 19, 2009 | Kodak EasyShare V1073 Digital Camera
When I try to delete my pictures, the screen says memory card is write protected. i cant take pictures or delete them
What camera? What kind of card? SD cards have a sliding switch along one edge. Slide it away from the contacts.
Sep 11, 2008 | Nikon Cameras
Memory card locked!??
The card locked usually means 'protected' Check out the manual for image protection - on/off. Or put card back into computer and delete[NOT FORMAT] from there. A more comprehensive manual is usually found the the CD that came with the camera
Jul 05, 2007 | Pentax Optio E10 Digital Camera
Fuji FinePix Z1 Digital Camera Logo
126 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
