Question about Magnum 257 CB Radio
No power to radio in trk have 13.5 volts to radio 257 magnum
    Novelist:
  • 146 Answers
I believe you are saying there is power to radio from truck but radio does not power on. I am not familiar with the this radio in particular. However i would assume there is a protection diode. That if polarity(-/+) is reversed it will cause a direct ground and burn the diode saving the radio. This in turn blows your fuse in power cord. This is now a direct ground continuing to blow fuses even if you power leads are correctly connected. This diode must be replaced or cut if it is cut and not replaced the protection is gone.
Posted on Jan 21, 2012
    Scholar:
  • 66 Answers
Ensure that the wiring is correct. Also make sure that the CB's AC is still functioning correctly. Charge your truck's batteries and test the CB on a fixed electrical output (indoor outlet). Also check to see if the power cord is the correct wattage output for the radio.
Hope this helps!
Gavin93
Posted on Aug 07, 2008
Tengo un magnum 257 y un micro dm 452 y necesito la combinacion para instalar el micro con el radio
tengo un magnum 257 y necesito la COMBINACION PARA INSTALARLE UN ROAD DEVIL RD104E.
Mar 17, 2014 | Magnum 257 CB Radio
How do i get the magnum 257 80 watt to operate on 11 meters it will be used out of the country thanks bill smith
This radio will need to be converted. Do you know anything about that? If not take it to a shop.
Sep 10, 2010 | Magnum 257 CB Radio
My 257 magnums audio keeps cutting in and out but my receive is fine
hi it may be a dry joint , on the audio driver or power .if mike is power.could be battery hope this helps
May 21, 2010 | Magnum 257 CB Radio
The Magnum 80watt 257
go to cb tricks .com
Apr 20, 2010 | Magnum 257 CB Radio
Magnum 257 which amps will work with.
you can use any amp with any radio.
they must be setup to do so.
Jun 28, 2009 | Magnum 257 CB Radio
Compre un cb magnum 257 pero perdi las instrucciones y quiero agarrar frecuencia con otros radios pero no se como empesar cual es el primer paso des pues de en cender el radio
mira el magnum force 257 es un radio de 10 metros y modificable a 11 metros , los canales mas usados en 11metros son el canal 9 osea 27065 mghz , o si tienes licencia puedes usarlo en 10 metros 28,000 por ahi para arriba se usa mucho 28315 en usb , en 11metros se usa am mucho, busca en yahoo , el manual de servicio para que te familiarizes con el suerte.
Apr 02, 2009 | Magnum 257 CB Radio
Lost buttons/1 and 2FOR 257
Yes, if this is the Magnum 257, then contact the company at 1-877-624-6869
or e-mail them from their site,, https://www.rflimited.com/Site.asp?CID=2
Hope this helps you, let me know,,, Mechanic
Nov 02, 2008 | Magnum 257 CB Radio
Magnum 257 off freq
Colin, here is all the tech info on alignments that your looking for,,,go here;
http://www.cbtricks.com/radios/rflimited/magnum_257/index.htm
Hope this gets you on the right track,, let us know.
Mechanic
Mar 09, 2008 | Magnum 257 CB Radio
Radio Communications Logo
82 people viewed this question
Top Magnum Radio Communications Experts
AnyMHz.com
AnyMHz.com
John Porter
Are you a Magnum Radio Communication Expert? Answer questions, earn points and help others
