Question about HP Pavilion dv9700t Notebook PC
The screen is black and I am worging with external VGA
  • 229 Answers
If the screen is totally blank it means power is cut off totall before getting to the screen. First ensure that the cable connecting the screen is intact. If it is, the problem might be resolved from the board.
Posted on Mar 16, 2011
  • 784 Answers
LCD inverter is faulty- its 90%, And 10 % maybe some lcd connection is not good.
My screen keep going white
To me this is a hardware problem.
Let's diagnose, and see Shunka_Reid.
Connect a VGA monitor to the laptop.
A) Laptop OFF, monitor OFF, connect a VGA monitor to the VGA port, on the laptop.
http://support.gateway.com/s/notebook/2009/gateway/nv/NV78/NV78lv.shtml
Number 3 - External VGA display port
General example of VGA connector (port), and VGA cable,
http://en.wikipedia.org/wiki/VGA_Connector
Scroll down a little for the VGA cable example.
You can use a CRT type of monitor, (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable.
General example of a CRT type of monitor,
http://www.wisegeek.org/what-is-a-crt-monitor.htm
B) Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By factory default settings, the display should show on the external VGA monitor.
IF not;
There are at least 3 display options available;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor.
3) External VGA monitor ONLY.
Press, and hold the Fn key down, and at the SAME time tap once on the F4 key.
The F4 key is the Display Toggle-Over key.
Still no?
Hold the Fn key down again, and tap on the F4 key once more.
Do you get a good display on the external VGA monitor?
Post back in a Comment.
Also, has the laptop ever been cleaned on the Inside, to your knowledge?
Regards,
joecoolvette
Mar 04, 2013 | Gateway NV7923u 173Inch Laptop (NightSky...
MY acer ZD1 screen has gone black how do i connect it to a pc screen blind
1) Laptop OFF, monitor OFF, connect a VGA monitor to the VGA port on the Right/Rear of the laptop.
Example of a VGA connector (Port), and a VGA Cable,
Scroll down a little for an example of a VGA Cable.
Yes. You can also connect an HDMI cable to it, and HDTV with this capability.
Turn the laptop on.
By factory default settings the display should show on the external VGA monitor.
If not;
There are at least 3 display options;
Press, and hold down on the Fn key. At the SAME time tap once on the F5 key. The F5 key is the Display Toggle-Over key.
Regards,
joecoolvette
Feb 19, 2013 | Acer Aspire 5920-6423 Notebook
Can i just remove the monitor assembly toshiba laptop p5085d-s8935 and just use a n external monitor
You could do that. Here is an excellent guide to replacing that model laptop's lcd which will show you basically how to remove it as well.
http://www.laptopinventory.com/LaptopInventory.php/Toshiba/Satellite/P505D-S8935/LCD
Dec 07, 2012 | Toshiba Computers & Internet
Hp pavilionn dv6700 screen goes black after a while
If you shine a flashlight on your black screen and look real hard for the icons on the desktop. If you can faintly see them that means your LCD Inverter is bad. You'll have to disassemble the LCD Screen to get to it. In the mean time you can attach another monitor (LCD Flat Screen or the Old style fat CRT) with a VGA cable to the vga port on you laptop. Once you have it connected hit the FN (Function Key) + (F1 thru F12) key that that corresponds to the external display. Hold the FN Key while you hit the Function Key that is for the external display. The key might have the words LCD/CRT on it or it might show a display symbol. That's the key you want to hit while holding down the FN key. This will cause the desktop to display on the external monitor and verify that there is no problem with your Video Card inside the laptop.
Mar 15, 2012 | Computers & Internet
I have a toshiba satellite a355-s6935 the lcd screen was replaced as it had been smashed. Now there is no display on new screen or if I attach an external monitor. All I get is black screen, is it...
Most laptops have a "toggle" to control the video-output:
* only to the internal LCD,
* only to the external VGA port,
* to both internal and external.
Toggle to activate the external VGA port, and connect an external monitor.
If you don't get a picture, then the computer's video-adapter is the problem.
Take the laptop into a darkened room, and look at the LCD screen.
If the inverter is dead, there still should be a VERY-FAINT picture.
Jun 06, 2011 | Computers & Internet
When I connected an external VGA monitor to my IBM thinkpad 760 C the external monitor works.. but the internal/original monitor goes black what to do?
It's supposed to do that. The internal VGA card doesn't have enough power to support both screens at higher resolutions than intended.
Mar 25, 2011 | IBM ThinkPad 760 EL Notebook
My screen on my laptop went black.
Theres is a lot of reason associating to a black screen. First lets just assume it the screen and not the laptop. Check to see if you still see any image in the screen, you might want to do this in a lighted area. If you do, but is very dark, then your backlit light is dead and your screen needs replacement. If you don't see anything, then use a external monitor such as a computer monitor, a Tv and connect via VGA port, or HDMI if you have one or a svideo to an external souce and see if you get picture, If you do, then your Inverter is bad, or either a loose connection wiring somewhere between your comuter base and your screen. ( Because laptop tend to open and close alot) If you don't get anything via external source through your VGA, HDMi or s-vdeo, then this is something involved with your laptop. Could be from cpu, chipset, ram, or simply the motherboard itself.
Jan 28, 2011 | Computers & Internet
My dell xps m1530 turns on but the screen stays black. Did my screen break?
Connect it to an external monitor with a VGA connection. If the external monitor comes on, yes your screen is broke.
Nov 04, 2010 | Dell XPS M1530 Laptop
Black screen
You need to borrow an external monitor and connect it to the VGA connector on your PB. If the system outputs video to the external monitor, then either the backlight or its inverter has failed.
Nov 11, 2008 | Packard Bell Easy One Silver 2120 Notebook
Address of acer service center in patiala
Watch out that you haven't switched off the screen by accident. One of the function key combinations toggles between the built-in screen and the VGA socket on the back or side panels to allow the use of either an external monitor or video projector. The key combination toggles three ways: 1) internal screen, 2) external VGA, or 3) both. On my Acer Travelmate 2200, the key combination is <Fn> + <F5>. Please try this first.
Nov 12, 2007 | Acer TravelMate 2300 Notebook
Open Questions:
HP Pavilion dv9700t Notebook PC Logo
95 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
