Question about Broksonic CTGV-5463TCT TV
Ctgv-2736 satellite connection
Is it possible to connect the satellite receiver to this set and do I have to contact the satellite company that we are using a different television?
  • tkpfinny Aug 02, 2008
    Thanks for your reply but we found out the problem is the satellite box is for HD and this set is not HD.
No need to contact you can use any brand of tv set
Posted on Aug 02, 2008
Can you connect satellite dish directly in a panasonic tx -42d235l
Probably not... the box is programmed to what ever company you are using and if you can then you will need to contact your service provider and set the tv up like the box....
Dec 02, 2014 | Panasonic Televison & Video
Ctgv-5463D
Check if using the cable via the coax fitting on the set that the fitting or the cable wire are not loose------its possible the tuner is bad but look also for video/audio input jacks on the set (some have, some not) If have those connect a DVD etc and see if problem that way.....
Oct 30, 2012 | Broksonic CTGV-5463TCT TV
My blu ray and regular DVD player have sound coming through the tv, but the tv itself on a regular chanel like ESPN, there is no sound. This is a Mitsubishi 73" DLP.
You have completed the proper troubleshooting, and by process of elimination you have determined that there is nothing wrong with your television's sound. The problem lies in cable. The next troubleshooting steps depend upon how you receive your cable channels. If you have a cable box (or a satellite receiver) you may just need to unplug it for 30 seconds to reboot it (or follow the instructions from a cable/satellite company representative on how to properly reboot your particular cable box/satellite receiver model). Also commonly the cable box/satellite receiver is not set to output audio properly. If you are connecting it to the television with an hdmi cable the audio output must be set to hdmi. Also there may be a setting pcm or bitstream. The cable box audio setting normally would have to be changed to pcm.The problem may be with the cable box/satellite receiver itself needing to be replaced or the cable cord connecting it to the television may need to be replaced. It is less likely that the television has a setting the one source input the cable box/satellite receiver is connected to that would affect the sound but confirm that there is or isn't. Last there may be something wrong with the source input you have the cable box/satellite tv receiver connected to.
If you do not have a cable box/satellite tv receiver then rescan your channels, try a different cable cord, and check with the cable company to make sure there is no internal issue at the moment.
May 11, 2011 | Televison & Video
Can i hook up an old tube type tv to a new high satellite dish? i dont care if i get high def picture just want a regular picture.
Yes there is an option for ouptuting 480i signal from most hd receivers. You will need to check the specifics for the satellite dish receiver as to the channel that the TV should be on as well as how to set it to the resolution that you need. (I know some Dish receivers need channel 60 for the SD TV (coax (RF) connection) when it is TV 2 but channel 3 or 4 for TV 1.) Also check your TV so that you can use the best possible input available.
However, you may not be able to read the closed captions unless you enable them on the receiver. (Apparently, the encoding has changed.)
The manuals for some satellite company receivers are on their website. For example, Dish network manuals are here: http://www.dishnetwork.com/supportsection/manuals . Their manual for the Solo VIP 211k describes connecting the receiver to a SD TV on page 91 (page 97 in the PDF version).
I hope this helps.
(I'm not aware of any satellite system that doesn't use a set-top box. If you do not have a receiver, then the above does not apply and you may not be able to get a signal.)
Apr 13, 2011 | Televison & Video
I just purchased a new RCA 32 inch w/ DVD. When starting up it asks if you will use Cable or Air. I have Dish Satellite and picked air. I only get one channel and if I try to go up or down channels I get a...
You should not have had to choose cable or air. When you have satellite it is considered the same thing as cable. Air is over the air rabbit ears antenna free programming. When you are connecting a satellite receiver you only have to turn to channel 3 or pick the correct av, component or hdmi input. Oh you must be connecting more than one television to the same satellite receiver. When that is the case tv #2 usually has to be set on a different channel and the satellite tv company tells you which channel. You still use the satellite remote to change channels and leave this television on one channel at all times. This television is good enough for its own hd satellite receiver connected with component cables or an hdmi cable though in order for you to see its full potential for displaying hd programs.
Jan 07, 2011 | RCA L32HD31 32 in. LCD HDTV
Satellite connection to tv doesnt recognize
At least you know the set does work. I'm also assuming your satellite receiver is working and that all your cables are good.
There are two ways to hook up to the TV: RF (antenna) and the A/V jacks. Maybe the seller was using the RF input (the threaded round connector where you screw on a cable connection, then choose channels with the set's tuner), and you're trying to connect using the A/V jacks (the red, white and yellow RCA jacks). If that's the case you need to switch the TV to those inputs. You may need the original remote to do that if the TV doesn't have a front panel TV/AV button.
The other possibility is you're connecting the satellite receiver to the RF connector and the TV isn't on the right channel (usually channel 3 or 4). If you're using the RF input, have the TV autoprogram and it should find the channel. Most sets can do that from the front panel menu button.
Hope this helps. Thanks for sing Fixya!
Feb 19, 2010 | Quasar SP-3235 32" TV
How do I get digital channels on 27" ctgv 2736 Broksonic
if your tv is not digital nor has a digital tuner then you wil be wasting your time i would advise you to buy a new tv.that is digital.good luck
Jul 12, 2009 | Televison & Video
Myguide 3100 - can't connect satellites
You can not clean the Registry if you could you ruined the whole GPS.
4 solution contact me
Feb 01, 2009 | MyGuide 3240 GO GPS Receiver
I have an RCA F36676ET that has a broken cable connection. TV works fine with DVD player but satellite connection not recognized. Can the cable connection be replaced? Can I do it myself?
If you mean the cable connector is broken off, then yes, that can be replaced. A company called MCM Electronics sells replacement connectors, but the repair requires soldering skills. Incorrectly done, the repair attempt can create even more problems. I suspect your satellite receiver has A/V outputs like the DVD player. Why not connect the receiver the same way as the DVD player and forget about the cable connection? You'll get improved picture and sound that way. If the set has only a single set of A/V inputs, you can cheat and use "Y-adapters" available at Radio Shack to connect the two sources to the same jacks, or you can get an A/V switch to do it.
Dec 03, 2008 | RCA F36676ET 36" TV
Com port missing?
check to see if the computer even has a serial port, most today dont have them and use USB instead. if this is the case, contact the receiver company to see if the have a usb version of the connection cable and software and download it and the manual for it. check to see if it needs a special cable as well while on the site. it might not need a special cable but it disent hurt to make sure.
Aug 04, 2008 | PC Connection Computers & Internet
Broksonic CTGV-5463TCT TV Logo
77 people viewed this question
Top Broksonic Televison & Video Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Broksonic Televison and Video Expert? Answer questions, earn points and help others
