Question about U-Line Icemaker
CLR 2060 Clear Ice Maker
We had a line leaking and replaced it. When he plugged it back in, it won't freeze. Sounds like compressor kicks in just fine and gets warm to touch. Water runs through, but ice tray doesn't get cold and therefore doesn't make ice.
Any ideas?
Joy Brown
  • ajmartin13 Oct 14, 2008
    I have the same problem we moved the unit now it will not get cold enough to freeze.
    Problem Solver:
  • 10 Answers
Just a guess but did you make sure that the fan under the unit is turning? if you don't get rid of the heat at the condensor the freeze tray can't get cold.
Posted on Dec 19, 2008
U-Line ice maker compressor won't run
Dose compressor fell too hot ? There could be several things wrong. First you will need to get out your Volt meter to make all test. With unit calling for freeze cycle the condenser fan and compressor should be running. Check at the compressor to make sure your getting power to the over load switch and then through it to compressor. if not then check to see if compressor is to hot and has the switch open> If so then unplug unit to let compressor cool down so switch will close. when switch closes plug unit back up and start up unit check to see it compressor starts if so then you will need to see what is causing compressor to over heat. could be dirty condenser, low charge, fan dropping out, Bad compressor.
Mar 07, 2014 | U-Line Icemaker
Uline Echelon Ice Maker P1 error code
P1 is a indicator of a slow or clogged drain check to make sure that every thing is draining good if line is clear make sure pump is coming on to pump the water out of the bin. once all is clear unplug the unit for an hour then plug back in this will clear code unless you still have a drain issue.
Jan 17, 2014 | U-Line Icemaker
Zdis15
check hot gas valve to make sure it is not bypassing when in freeze mode this will not let the evaporator plate get cold enough. need to check refrigerant pressers.
Jun 07, 2013 | Kitchen Appliances - Others
Ice maker runs through cycles but water never
you have a problem with the sealed system it sounds like. either a freon leak or bad compressor.
Apr 23, 2010 | U-Line Icemaker
My clr 2060 ice maker is not doing anything,their is no ice in the storage bin. opened up ice maker and cleaned the condenser coils. Found red light on board lit, with a slow steady blinking green light
HI
It sounds like you have a drain issue. You can do a test with the unit on open the panel with the board and remove the 2 pink leads and make a jumper for those terminals. If the unit comes on 3 min fill then circulating pump and compressor and fan come on then you know you either have a kink in the drain line or a bad pump. If your unit doesnt have a drain pump then the pink lines could be open and it will turn the unit off too.
Sep 13, 2009 | U-Line Icemaker
Not making Ice
Is the freezer at least 10 degrees? Is there water in the ice mold? If not put some to see if it will harvest after it freezes. If no water getting to ice mold Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear. The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
The valve can leak because of sediment in the water preventing it from closing or low water pressure.
Jul 10, 2009 | Marvel Appliance Ice Maker
What freon 134A
The freon in most ice makers are R 410a at this time. You will be able to find the type of freon your model has listed most times on a data plate on the rear of the ice maker cabinet and on or near the compressor. R 134a is not always used in production ice machines because it does not freeze water as productive as
R 410a. The type oil in the compressor also will lead you more in the direction of the type of gas. Now If you need to replace the freon or compressor I can help you determine the exact type of freon gas was existing before the change, Let me know if this has answered your question. Thanks, Sea Breeze
Feb 06, 2009 | U-Line Icemaker
Ice maker (Uline) just stopped working, not freezing, no noise.
U-line does make compressors as long as its not a r12 system. As far as the icemachine turn breaker off for a couple of min then try it. If same results then it could be a board.
Dec 23, 2008 | U-Line Icemaker
U-line CLR 60 B ice maker
U-Line's tech line is 1-800-2547. The compressor, condenser fan and circulation pump operating at the same time?
May 24, 2008 | U-Line Icemaker
U-Line Icemaker Logo
193 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
Iron
Iron
Gil Shultz
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
