Question about Refrigerators
Hi! I have an amana bottom freezer. The freezer wasnt as cold as usual and I noticed some frost on the back of the freezer. I melted it with a hairdryer, and cleaned the back of the fridge with a vacuum. The freezer is working great now, BUT, after I open the fridge door, the frdige makes a loud buzzing sound. It stops after a while if I dont open the fridge door again. Whats going on? Thanks so much! Cindy
  • Refrigerators Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 19, 2011
Hi, My Amana fridge this morning stop working and when i checked the freezer i notice little frost, called a repair guy and after he inspect it he said it`s contorl board. around an hour ago I noticed...
Hello Ben, When the technician was there did he take apart the freezer to melt the built up frost,if he did it will work till the frost builds up again, If it wasnt defrosted perhaps jostling the wires has temporarly fixed the problem with the control but real soon it wont work once again
Gene
Aug 05, 2011 | Amana ABB1927DE Bottom Freezer...
The upper portion of the freezer turns off, causing the ice to melt. And the cooler side bottom drawer turns into a freezer. I can't figure out what's going on.
You have a frost blocked evaporator. Translation: The cooling coils, located behind the back wall inside the freezer section, have plugged up with frost (usually caused by a burnt out defrost heater, located at the bottom of these coils) which prevents the cold air from circulating inside the freezer, and into the top of the fresh foods section. At the same time, this blocked air flow allows very cold air at the bottom of the freezer section to migrate back into the bottom of the fresh foods section, and thus freeze item in the bottom bins of the refrigerator. Unload the freezer, take the shelves out and remove the back panel. Melt the frost with a hair blower, and change out the heater at the bottom.
Jul 08, 2010 | GE GSS25SGMBS Side by Side Refrigerator
Amana AFB2534 freezer is regularly getting frost buildup at the back. first 2 times it was so bad that it blocked the vent & prevented cold air from reaching the refrigerator. Freezer just doesn't seem...
This is either of three defrost parts. The timer, heater or defrost limit switch. Most amana's I fix have a bad limit switch which is clipped to the freezer coils directly. Spin your defrost timer till it clicks and check the same frost laden wall to see if the frost starts to steam and melt. If not, unplug the fridge, then try disconnecting the limit switch and join those 2 wires together. Replug and see if the heater starts steaming. If it doesn't it is most likely the timer. The heater is usually the last thing to die, unless your heaters are encased in glass. In which case a quick visual inspection for decay and separation will pinpoint the problem.
Mar 05, 2010 | Amana AFB2534DE Bottom Freezer French Door...
I have an Amana bottom freezer frig. The freezer is starting to show frost inside and build up. Also I noticed some white snow looking stuff under on the front corner. Its not cold like ice but hard white...
the ref. is pulling in air from the gasket.check gasket by using a dollar bill.shut the freezer door with dollar bill between gasket and freezer.if you can pull the bill out wit ease then you must replace gasket.if frost is on back panel then you have a defrost problem.but it sounds like a gasket.
Mar 05, 2009 | Amana ABB1927DE Bottom Freezer...
Warm fridge
check the fan in the frezer and check the defrost
Nov 29, 2008 | Amana Refrigerators
Amana neither fridge nor freezer getting cold enough
the defrost system has failed. to get it working temporarily, take the back panel off inside the freezer. melt ice off with a hairdryer.
after that, fault can be in several areas - defrost heater, thermal fuse or the main pcb
Jun 30, 2008 | Refrigerators
Amana BX22A2W - freezer works, fridge not cooling
Same problem here with an Amana refrigerator with the freezer on the bottom. I removed the back panels and vacuumed dust and cat hair out. The back panel in the freezer was frosted over with ice on the bottom. I removed the shelves and food and used a hairdryer to loosen the panel. The ice maker made it harder to remove the plastic panel so I pulled it back and saw the cooling fins frozen solid. I used the hairdryer to melt the ice and a shop vacuum to collect the water. It works like new again.
Dec 02, 2007 | Refrigerators
Frig not cold but freezer is ice maker not making much ice either
Is your fan blowing in the freezer? Frost on the back wall of the freezer usually indicates a defrost problem... defrost themostate, heaters, take back panel off and check evap for frost build up and if your fan in working.
Aug 28, 2007 | Amana AFD2535DES French Door Refrigerator
Refrigerators Logo
60 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
