Question about Crosley (CR62) Corded Phone
Can the coiled cord be replaced - Crosley (CR62) Corded Phone
Cord replacement
Replacement cord for model HQ6690 can be found at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/cords-chargers-and-stands/philips-norelco/universal-shaver-cord-coiled-for-most-models-p-268.html
Dec 08, 2013 | Philips HQ6990 Electric Shaver
How to replace pull cord
The pull cord is in the top cover to your engine.
Remove top cover and any attachments such as oil filler tube and fuel tank. With cover off you will see the old cord or whats left of it. Remove old cord. Put tension on the spring by turning the coil assembly. Put the pull handle on one end of cord, and insert the other end of the rope into the coil assembly. Let the cord retract into the coil assembly. This should do it. GOOD LUCK>
Jun 28, 2011 | Mtd Garden
Replace starter cord on echo cs345 chainsaw
This is a messy frustrating job, and if you had to put a price on the hassle that it is, it is probably better to pay somebody else to do it. That said, remove the starter cover with the cord and pulley inside. If there is a plate holding down the cord pulley, remove it and carefully lift out the pulley, try not to dislodge the recoil spring as this is where the frustration part comes in. Remove the old cord and insert the new cord end into the hole and copy the old knot - pass the other end of the cord through the eyelet in the cover. N.B. At this time take note of the direction that the recoil spring coil is orientated. Wind about 3/4 of the cord around the pulley and attach the start handle to the outside end of the cord. Carefully fit the pulley over the spring and place the cord into the cutout in the pulley. Wind up the pulley so that it engages in the curl in the inside of the recoil spring and further wind up the pulley in the opposite direction of the normal pulley start pull, holding the cord in the little cut-out so that the cord does not wind up as you wind the spring. It probably takes about 5 extra turns on the pulley to get the recoil tension right. Always hold the pulley in place to prevent the spring from jumping out. Release the cord so it can retract and replace the retaining plate. This is all if the spring does not jump out - which it so often does.
If the spring jumps out, hold it by the inside portion and start winding it up, pulling it tight to keep the coil small enough to fit back into its receptacle, . Once the spring is wound up and will fit into its position the problem starts. I found that gripping the spring with an alligator jaw vice grip will allow you to replace the spring and carefully release it without it going wild again, engaging the outer hook in its retaining slot or around its peg. Trying to feed the spring into position coil by coil seldom works, it has to be wound up outside and then inserted, especially on a small motor.
This procedure is as difficult to explain as it is to carry out. I have done many cord replacements and always dread the next one. If you have any problems, feel free to come back to me.
Apr 12, 2011 | Garden
I am replacing the metal spring for the fly wheel. What is the best way insert the coil and recoil rope without the coil unraveling?
Take the pull cord off of the spool, then wind the spring CCW until it seems strong enough to return the cord when it is pulled out. Wedge the spool so that it doesn't unwind the spring, and work the cord into the spool. If you have to form any knots, be sure to melt the cord end so that it prevents the knot from slipping off. Hope this helps!
Sep 13, 2010 | Garden
How to sort broken pull cord on petrol strimmer
Hi Baz, i will tell you a generic way of doing this as i don't know the model of your strimmer.
on the pull cord housing you will have 3 or 4 screws to secure the housing to the motor body, undo these. the housing will lift away from the main motor body, underneath this cover you will see a spring canister, there may be a screw or clip keeping this in place or some are just secured with the outcover. remove this canister you should see a coil spring in the middle and a groove around the outside where the cord goes. you should see a knot inside the cord grove where the cord is threaded through to secure, remove thisand remove old cord. Now the trickky bit! some times it helps to have a helping had, you will need to turn the coil spring so it tights up to its full tightness, then thread the new cord into the secureing hole where the old cord was located, then when you release the spring this will coil the cord round the cord groove. replace the pull handle on the end of the cord so there is no slack and replace on to motor in reverse order. Hope this helps.
Sep 04, 2009 | Ryobi ZRRY30550 Factory-Reconditioned 30cc...
Electric cord will not retract
I found the solution from another web site. Removed the reel coil, cleaned it of lint, etc. replaced it and it is now working. Thank you for your relpy
Jun 26, 2008 | Vacuums
Crosley (CR62) Corded Phone Logo
24 people viewed this question
Top Crosley Lands Phones Experts
Lisa Demont
Lisa Demont
Level 1 Expert
Are you a Crosley Lands Phone Expert? Answer questions, earn points and help others
