Question about Samsung Refrigerators
The ice is no longer coming out cubed - just a big clumped together mess on my Samsung Bottom Freezer's internal ice cube maker
  • lisa imperati Mar 16, 2011
    it is Samsung Bottom Freezer Model: RF217ACPN
  • Samsung Master
  • 3,740 Answers
Hi and welcome to FixYa, I am Kelly.
This symptom is caused by a water inlet valve that is bypassing water when it is supposed to be shut off. The inlet water valve is not repairable and must be replaced when this symptom occurs. There can be yet other problems with he ice-maker itself, but changing the water inlet valve will correct this about 95 % of the time. Changing the inlet water valve is the first step in troubleshooting. Should you call for in home service; the tech will change the inlet water valve before doing any other troubleshooting and will most likely have to return after 24 hours to continue ice-maker troubleshooting.
If you need help locating a replacement inlet water valve I will need your complete model number.
Thanks for choosing FixYa,
Kelly
Posted on Mar 16, 2011
  • Kelly
    Kelly Mar 17, 2011
    Sorry for the delay. My house was within 1 inch of flooding and we spent the day moving stuff. Water is now receeding!
    I hate to ask questions vs answering questions but is this a UK or AU model? Somehow I get the feeling this a 220V water vavle.
    Kelly
  • Kelly
    Kelly Mar 17, 2011
    I finally found the correct water valve for your unit and you can find it here:
    http://www.searspartsdirect.com/partsdir... $39.99
    The part number is there but there is not an item number reference for the water valve.
    Kelly
Why does Ice in ice maker sticks together, forms clumps. Jams, then kicks latch open
I'm pretty sure there's an owners manual section on adjusting the ICE-MAKER's fill level... (url @ bottom)
Every-other caution SEZ
"Thou shalt not RESET more often than 24 hours"
Over-filling can cause the cubes to be strongly connected... and cause clumping issues in the bin...
Also look to see that the cubes are not hollow... that is a different adjustment.
Make small adjustments... you will be happy...
Big (evidently FREQUENT) adjustment can cause more trouble than inviting the Samsonite gorilla in to SERVICE your appliance...
(I'm just saying)
http://support-us.samsung.com/nas/storage/201406271751003%5Estorage_attachment%5EHow_To_Reset_The_Ice_Makers_In_Samsung_Fench_Door_Refrigerators.pdf
Apr 05, 2016 | Samsung RF26XAEWP 26 cu. ft. French Door...
Ice maker leaking out the bottom and refreezing ice cubes to a big glob
are the cubes coming out of the unit? Sounds like the heating element is not activating, to release the cubes prior to refilling. Check electrical connections at the rear of the unit against the freezer wall that they are together. If ok then defrosting element may be defective, Replace unit.
Aug 27, 2013 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Ice maker makes ice but will dispense through door. Checked and it is not clogged.
Good day!!!
This could be because the ice is clumped in the ice bin. When the automatic defrost cycle occurs, heat is transferred to the freezer area. This can cause the cubes to melt slightly and refreeze back together. You can take the bin out and give it a good shake, or simply discard the cubes and start over with a fresh batch of ice cubes. By increasing the amount of food in the freezer compartment, you may be able to buffer the heat that comes from the defrost cycle and avoid clumping issues. If you have a large ice bin and hardly use any ice, it is possible that the cubes have gotten stuck together just from the weight of the cubes on top of others.
I hope this information will be helpful...Thanks for using fixya...
Sep 09, 2011 | Hotpoint HSM25GFRSA
Ice from ice maker sticking together. Is the temp in the freezer to high or to warm causing this?? The ice is just one big clump of ice cubes all stuck together!!
to warm or maybe staying in deforest to long if you don't have a good amount food in the freezer it will warm up in deforest and make ice to lump
Sep 29, 2010 | Frigidaire Refrigerators
Kenmore ice maker problem
the problem is an unlevel icemaker to prove this do you see little droplets of water freezing from the icemaker or a remote possibilty is do you have to an R/O system and have you change the filter if unit has one.
Aug 19, 2009 | Kenmore Freezers
Samsung model RF265ABPN waxy looking piece fell into ice tray
The waxy piece has a clear plastic bracket, if its not connected, look around your freezer. The waxy piece fits inside the bracket, and attaches to the ice maker, just in front of the ice tray.
The white wire fits inside the waxy piece. It is the thermostat that tells the ice tray when to dump the ice.
This is impossible to feel around for, so you will need to remove at least the bottom freezer compartment as well as the ledge piece from just inside the freezer door. If you are a relatively thin/small person, you can extend the top tray fully outward, and slide underneath. Looking up at the ice maker, the plastic bracket should have a little prong. This prong will attach just behind the ice maker, with the thermostat facing the ice tray.
Jul 05, 2009 | Samsung RF265AA Bottom Freezer French Door...
Clumps of ice cubes in back of ice bucket
sounds like your just might not be using enough ice and they are defrosting and clumping together.figure your pulling ice from front of bucket the the backs hardly get used espescially in winter your not using as much ice. or ice maker is slightly over flilling water and dripping over rear of unit
Jan 20, 2008 | Amana ARB1905C Bottom Freezer Refrigerator
Refrigerators Logo
423 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
