Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
My blades are always running and wont shut off. Also they are running so slow that it wont even cut a blade of grass!!!!
    Brigadier General:
  • 3,911 Answers
There is generally a clutch for the blades, made with a spring loaded pulley or electrical device. when you move the lever (pulley type) or move the switch (electrical type) it engages the belt which drives the blades. You have a problem there and someone with mechanical skills needs to look at it and repair it. I suspect a spring loaded pulley type, it sounds like someone took the belt off and put it back on wrong. There is no magic button to fix this.
Posted on Mar 18, 2011
Cant get blades to full RPM replaced all idlers all belts greased spindles new elec. clutch new blades when cutting grass it leave rows of uncut grass
if the blades wont get up to speed or not cutting grass you have a belt that is slipping. could be the pulley is damaged or just a worn out belt. if it is leaving a strip of uncut grass you have a blade that is wore down on the ends not cutting the full path
Aug 05, 2017 | Garden
Have a Cox Stockman ride-on lawnmower that wont cut. Just added 2 new blades (using 4 high lift blades) and still have to go over 100mm grass 3, 4 or more times to cut it down.
check for slipping drive belts
check that the cutter spindle bearings are in good condition as they may be failing and slowing down the cutter blade speed
Dec 16, 2016 | Garden
Cutting Blades going too slow
if it is an older mower or has a lot of hours on it it is possible that the deck belts have stretched or wore out. if it runs fine in short grass but slows down in taller grass that is a sign of a wore belt. replace and it should be good. also be sure your blades are sharp. that will have a effect on its cutting capability.
May 06, 2016 | Garden
Why does the engine slows down when engaging the blade
check fuel filter and pump pressure starving for gas
Jul 02, 2014 | John Deere Garden
Wont start
If you were cutting long grass it sounds like you may have burnt the motor out. It may have over heated. they are not made to cut long grass. You don't say whether the motor runs but not the blades if this is the case you may have sheared the shear pin in the blade assembly.
May 02, 2013 | Black & Decker 18", 6.5a Electric Mower
Blade slows down when grass gets thick
The reason the blade slows down when the grass gets thick is simply because the mechanism operating the blade is weak and cannot move fast when on thick grass.
I suggest you troubleshoot the mower. After that, the blade should work fine when the grass gets thick.
Also, some mowers normally gets slow when grass gets thick, so after troubleshooting, if the mower does the same, then you already know it has to be slow when trying to cut thick grasses.
Take care
Sep 09, 2010 | Toro Personal Pace CARB Walk Power Mower
The riding mower doesn't cut evenly...one side cuts higher than the other...
The following steps will make any riding mower cut evenly.
1. The rear tires must be the same diameter i.e. same tread type and the same tire pressure (check it before each mowing).
2. Level the deck following the instructions in the manual and recheck it occasionally
3. Make sure the blade(s) are not damaged and kept sharp, rounded blades tear instead of cut.
4. Make sure the deck and its attachment points are not bent or damaged.
5. Drive at a slow walking speed with the engine at cutting speed.
6. Over lap rows in amounts sufficient to lift and cut the tire tracks from the previous pass.
7. Cut the grass at intervals that ensures you never have cut more than 1/3rd the total length of the grass.
8. Make sure the underside of the deck is clean.
9. Use a blade style that matches the type of grass you most often mow.
Jun 18, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Riding mower
If the grass is very tall (more than 10") you will have to slow down to less than 1 mph, if you have a mulch kit on this unit, remove it to get the grass out as quickly as possible. Also, sharp blades & a level deck are important.
Sep 23, 2009 | Garden
Airens Zoom 1944 ZTR Blades Slow Down In Bahaia Grass
You mention many PM issues but do not mention a blade sharpening. I don't get on my ZTR without a freshly honed blade installed. "That's" what cuts bahia grass...the blade. You can put all the horsepower you want behind the lade but if you're trying to cut grass with a 2X4 it rips more than cuts grass.
Jun 30, 2009 | Ariens Garden
My Toro mower is 7 yrs old. 3 speeds, blade
I've noticed that when the blade get dull it work harder a cutting tall grass. I just put a new blade on mine and now it runs and sounds like a brand new mower. also if the inside of the deck is coated with old grass that makes a differance too
Jun 23, 2009 | Toro Lawn Mower With Toro Power Tools
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
96 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
