I bought a new laptop and it comes with a webcam and it came with the software but when I go to Skype, my webcam will not turn on. The software is on my laptop but no cam! :(
    President:
  • 2,340 Answers
Device configuration setup, the webcam preferences in Skype can be found under 'Tools' -> 'Options'
Reference help:-
1. http://www.onlinehowto.net/Tutorials/Skype/How-to-use-Skype-webcam/620
2. http://www.jerryleventer.com/how-to-set-up-your-webcam-for-skype-video/
Hope it helps.
Posted on Mar 17, 2011
How can i find my cam on asus eee pc 1000h
You need to install a webcam related software like Skype or Cheese.
You can find it on the ubuntu software center or install it directly from a terminal:
sudo apt-get install skype cheese
Aug 12, 2012 | ASUS Eee PC 1000H Laptop
I just bought the Logitech HD Webcam C310 to communicate via Skype. I notice this has its own software. Will this interfere with communicating through Skype? Does skype have its own hardware? As I...
yes, u need it if your OS does't have the driver for your webcam.. just connect your webcam and install the drivers from the cd.. and you can use your skype. it will automatically detect your webcam.
May 10, 2011 | Logitech Webcam
I bought a webcam but I don`t know how to start to go to skype or take picture or connect to computer. Does not have a C D , just usb
Lillianrod1
If the Webcam does not include a CD, the drivers (the software that runs the webcam) should install itself automatically when you plug in the drive. If you are on windows, make sure you have Windows Update enabled so that it can search for the right drivers.
To start using it in Skype, simply open skype, go into the Preferences, and set the webcam as your camera video chatting. To take pictures, you will need software to control the webcam. http://www.yawcam.com/ is a free webcam software that will let you take pictures with your new webcam.
Mar 05, 2011 | Xerox Computers & Internet
Hello. My name is Florina Pop and I am using a Lenovo Ideapad Y560 laptop with Cyberlink YouCam 3 installed.The web cam is incorporated on the laptop.I bought the laptop with all the basic software...
I don't think its your webcam that is at fault. I think it's already in skype. I have the same Lenovo model and there are times skype doesn't transmit video. So, I usually do is turn on and turn off the skype video call for the video to reappear. Can you do the following:
1) Make sure you have adequate lighting. Sometimes if you are in a dark room, skype will also transmit black videos to the other end.
2) Have you checked the video settings in skype? Go to Tools->Options. Click video settings. Click webcam settings and try to tweak your video from there.
Feb 09, 2011 | CyberLink YouCam
I just bought a compaq laptop, then downloaded skype. and my webcam doesnt work..how do i get it to work?
Skype is very particular about having the latest drivers installed so that's the first step
Check your set up
In addition to the webcam software you will need to check the support software - Microsoft DirectX . This comes pre-loaded on most Windows computers but has to be updated - I am currently on version 11
To start the DirectX Diagnostic Tool, click 'Start', click 'Run', type dxdiag in the Open box, and then click OK
Run through the tabs checking the 'notes' windows for information and faults.
The version will be shown on the 'Systems' tab
SKYPE SET UP
Connect your webcam
Test your webcam here to make sure it broadcasts ok - Hit 'Allow' in the top window and check your cam in the left hand panel.
http://www.testmycam.com/
Not working ? - troubleshoot your drivers and software - get your cam working before moving on
Working OK ?
Set your webcam mic as default ( if it has a built in mic)
Plug in the webcam
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
Right click on the volume graph and select 'Show disabled devices' and 'Show disconnected devices'
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
CONFIGURE TO SKYPE
Connect webcam
Its good practice to disconnect and re-connect your webcam before you start (To reboot the webcam software) - if you have been using it elsewhere the SKYPE software may have difficulty in locating it, even if you exited the previous program correctly.
The reason being, the webcam software can remain hooked-up to a program and needs to be rebooted.
Mine, I just unplug it from the USB and plug it back in to reboot the software.
If yours is integral with the computer you will have to re-start the computer, use a keyboard shortcut or disable / enable the webcam from the Device Manager.
Start Skype.
On the 'Tools' menu, click 'Options'.
In the navigation pane of the Skype 'Options' window, click 'Audio Settings'
Run down the list setting your defaults
Select your webcam as the default microphone.
Make a free test call
Click 'Save'
In the navigation pane of the Skype Options window, click Video Settings.
This will launch your webcam
Adjust quality of picture in 'Settings'
Check the correct webcam is shown as default
Click Save
Test your webcam by making a Skype test call.
For more information about how to configure Skype Messenger, please visit the following Skype Web site:
http://support.skype.com (http://support.skype.com)
Before opening Skype disconnect your webcam for a couple of seconds - if its inbuilt restart your computer or disable / enable it from the Imaging folder in the device manager and do not open your cam for a preview but wait and let the Skype software take full control when you start a video chat.
Sep 10, 2010 | Compaq Computers & Internet
I just bought my asus laptop and i do not know how to get the webcam to come on please help!!
It will be detected and used by software that requires a web cam such as MSN or Skype if you use the video conference feature. You can set the preference of your webcam with some menu item of those software. You laptop may come with some utility software you can find in start menu which can help you diagnose your hardware including your webcam. As it is a new one, the webcam will work for you. You just need some software either those video conferencing or picture taking ones.
Sep 02, 2010 | Computers & Internet
I bought an hp G71 laptop and I want to be able to use the webcam it doesnt really look like the laptop has a webcam its just a small shallow hole at the top but the person that sold it to me says it has
The G71 series laptops do have webcams built in. If you download "Skype" you should be able to test it out and chat with people using that.
Also go to the start menu search bar and type in "webcam" and see if there is any preloaded software on the computer.
If there isn't anything preloaded then i suggest you download skype.
Jun 16, 2010 | HP G70-250us Notebook
My laptop webcam wont work with skype
Try to uninstall any other video software that might conflict with the driver of your Microsoft LifeCam
Mar 28, 2010 | Microsoft LifeCam VX-3000 Web Camera
I need basic instructions to operate the Skype and web cam. Thanks I have a new Dell Laptop with web cam and am trying to learn how to operate the web cam and also Skype.
hello:
if your webcam are corectly installed skype wil reconised it bij the software
if you connect sombody in skype there are a tab wit webcam (video chat) only for skype connections.
gr ben
Aug 21, 2009 | Computers & Internet
Boynq Iris webcam microphone doesn't work
Try Skype - Preferences - Audio - Audio input and you should be able to select "boynq iris webcam".
Check out also the System Preferences - Sound - Input and you should also see "boynq iris webcam".
Mar 18, 2009 | Computers & Internet
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
