I have a 4gb flash drive. I loaded a few pictures to copy from one computer to another. Upon returing to the original computer to copy additional material to move to a new computer I received the message that the drive was Write Protected. I have used flash drives many times and have never had an issue. Is there a way to wipe out the flash drive and bring it back to a default setting? It doesn't matter if I lose the info on the flas drive. I still have the original material.
  • 27,725 Answers
USB drives can be write-protected by modifying the StoreageDevicePolicies Registry key and WriteProtect Registry value.
click Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
# Remember: do not delete any unknow files in the registry as this will make some programes not work as usual.
also
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
hope this helps
Posted on Mar 16, 2011
    Problem Solver:
  • 17 Answers
Many flash drives have a little tiny switch on the flash drive that allows you to lock it into "write protected" mode. Look on the drive, and if you have a switch, flip it the other way to un-write-protect it.
    Sergeant:
    Champion:
  • 205 Answers
Check the drive for a small switch that turns on/off the write protection. If you get me the Brand name of the unit I can probably find you a manual and tell you if it has one or not.
Hope This Helps.
Zeppelinx12
4gb usb cannot be detected on my computer. how to fix the problem?
Try it on the other pc just to see if its working atleast,if yes then try it back to your PC but using different usb port.or also go to my computer management then check your Universal serial bus controllers if not showing any errors rght click on them and scan for Plug and Play complaint components.
Sep 04, 2011 | HP Computers & Internet
How to savedata on it
Darius,
Remove the cover from the USB head.
2. Insert the drive into USB port on the computer.
3. Start My Computer and locate an additional drive listed in it.
4. This is the Flash drive.
5. Use it as any other drive to copy/paste any data to it from any other drive.
Cheers.
Jan 12, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
I cant copy pictures from my computer to my flash drive im using transcend 2 GB
flash drive may have a locked (read only) so change the lock status to unlocked
try to copy photos again
Apr 18, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Down load pictures from computor to pny 4gb usb 2.0 flash drive
U NEED TO FORMAT IT 1ST INSERT THE FLASH DRIVE GO TO MY COMPUTER GO TO THAT DRIVE IT MYT B NAMED AS STORAGE (E) OR (F) DAN RIGHT CLICK ON IT SCROLL DOWN TO PROPERTIES CHOOSE FORMAT AND SELECT QUICK FORMAT. HOPE THIS IS HELPFULLY. :)
Apr 15, 2010 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Flash drive has a DVD ghost
It is "working as designed" for a 'U3' device.
A 'U3' device is _more_ than just an "ordinary" flash-drive.
You can install software onto a 'U3' device, i.e., a copy of Microsoft Office, and then you can take your data files _and_ your copy of the software _with_ you, and connect to any computer, and access your software and your files.
Jan 09, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
How do i put pictures on a sandisk u3 4gb flash drive
You can put pictures on it the same way you put any other files on it. Plug the flash drive into your computer, then drag&drop any files to/from your hard drive(s).
Dec 13, 2009 | SanDisk ULTRA II 4GB Compact Flash Card...
How do you put files on a memory stick I dont know how to use it. and I'm not fluent in tech talk.
Just plug your device in USB port of your PC/Laptop, and wait for a miniute, after a while a pop-up will appear in the bottom right corner saying "Device Successfully installed and ready to use".
Now open your "Computer" or "My Computer" you will see a Removable Drive" there, thats your USB Flash Drive, paste there whatever you want and port it to any other Computer.
I Hope you have a clear picture now,
Regards, Waqar.
Oct 20, 2009 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
I want to download pictures from my computer to a flash drive.
Open [My Computer]
You will see the flash drive, probably "Removeable Disk" and probably labeled Drive E
Click on the flash drive icon and the main folder on the flash drive will appear.
Create a folder (right-click, [New] [Folder]) and name it something like "photos"
Find the pictures on your computer and copy (drag & drop) them onto the folder on the flash drive.
No, you don't have to make a folder on the flash drive, just a suggestion.
Oct 01, 2009 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Removal of pictures
Have you tried this. Put the flash drive into you usb port. Go to my computer, find what drive your flash is in, open the drive. select the pictures to copy. I know this sounds to simple, but it is sometimes the simple things we overlook.
hope this helps
Feb 02, 2009 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Loading pictures onto flash driver
Drag and Drop
You simply right click on what ever image you wish and while holding down the right mouse button and drag the image from where ever it is to the flash drive. you can select
( copy here ) or ( move here )
Copy is good because it keeps a copy of the image in the original location in case you screw up ...
Sep 08, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Open Questions:
Computers & Internet Logo
71 people viewed this question
David Payne
David Payne
