Question about Dishwashers
I have new Bosch dishwasher..lassic electronic....the check water level keeps coming on because water is not pumping out....tried to reset and it still willnot pump out....any suggestions
  • 135 Answers
Check the drain connection.....if it is connected to a garbage disposal make sure the drain plug knock out is removed otherwise the dw will not drain. Also make sure the drain hose is not pinched or kinked.
Posted on Aug 02, 2008
Dishwasher will not take in water
On bosch dishwasher if the base senses a water leak the unit will not fill & the drain pump will come on. I recommend checking for water in the base & locating the source of the leak if you see water in the base. Other possibilities; fill switch, water level switch or water valve. There is no reset for this problem.
Mar 08, 2009 | Bosch Dishwashers
Bosch S9GT1B not taking water
check electro valve,water-level switch.
Feb 15, 2009 | Bosch Dishwashers
BOSCH DISHWASHER Flooding
Removing the water level sensor it is not a difficult operation, it is held with one bolt at the base of the floater arm.
The problem is that you cannot be sure that the floater is not working unless you find out that the floater is filled with water or stuck.
There is an electronic test to verify if water level switch activated by the floating sensor is working. Instructions here: Bosch dishwasher helps.
You can find replacement water level switch , and schematics on websites below:
BSH - Bosch Customer Service
Appliance411: Repair Parts
how to mend it .com - ~~ Wiring diagram for BOSCH Dishwasher.
Feb 07, 2009 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Bosch dishwasher not taking in water
May be open circuit water valve. Appliance will go to error mode if water level has not reached a certain height after a preset time. Check coil continuity with a multi meter. Should be looking for about 200 ohms.
Nov 11, 2008 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Check water light comes on
is your appliance a miele? normally this is causeb by blockages ( bit of plastic or paper wrapping/ milk bottle tops etc) inside the impeller of the main circulating pump (motor) restricting the flow of water the only solution is to fisically remuve the obstraction by temporarelly remuving the motor and cleaning not a simple job
Jul 25, 2008 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Bosch dishwasher adjustment
yes try tuning it to the level you need i had the same problem myself.
Jun 19, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Wont drain!!!
Check first the drain lines and the drain pump.
If the drain pump is working, and there is no problem in there, then the problem is usually because the water level switch activated by the floating sensor is stuck.
You probably need to have the water level switch replaced.
You can find parts on websites below:
Jan 06, 2008 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Pump Runs On After Water Is All Drained Out?
If the cycle does not stop draining that is usually because of a faulty water level switch that controls the water level in your appliance.
The faulty sensor cause the machine to think that there is still water inside, even when water has drained completely.
Check if the floating sensor is stuck or faulty.
Some machine may use a membrane switch instead of a floater.
Aug 12, 2006 | Bosch SHU9915UC Dishwasher
Dishwashers Logo
Top Dishwashers Experts
